Question about HP Photosmart C3180 All-In-One InkJet Printer
Scanning photo or text image appears with purple/striped background
This past summer i was scanning documents without issue, now when i scan either a photo or document it appears as a purple background in the preview.
i've tried everything to change it, but without success.
also, when i push the scan button, it doesn't allow me any time to change settings or destinations.
any help will be very much appreciated!
Posted by lmk07 on
  • Anonymous Mar 21, 2014
    When I scan documents or photos, a 1 inch wide stripe runs the length of the scanned material. This does not happen when I print, but severely restricts the size of what I can scan
Anonymous
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
Drivers do not conflict with the program. If necessary, uninstall and then reinstall the program. BACK UP YOUR FILES IMMEDIATELY USE A VIRUS-SCANNING PROGRAM TO CHECK THE HARD DRIVE, FLOPPY DISKS, OR CDS SAVE AND CLOSE ANY OPEN FILES OR PROGRAMS AND SHUT DOWN YOUR COMPUTER THROUGH ...
Posted on Nov 18, 2007
  • 1 more comment
  • Anonymous Nov 18, 2007
    CHECK THE SOFTWARE DOCUMENTATION OR CONTACT THE SOFTWARE MANUFACTURER FOR
    TROUBLESHOOTING INFORMATION
    • Ensure that the program is compatible with the operating system installed on your computer.
    • Ensure that your computer meets the minimum hardware requirements needed to run the software. See
    the software documentation for information.
    • Ensure that the program is installed and configured properly.
    • Verify that the device drivers do not conflict with the program.
    • If necessary, uninstall and then reinstall the program.
    SAVE AND CLOSE ANY OPEN FILES OR PROGRAMS AND SHUT DOWN YOUR COMPUTER THROUGH THE
    F YOU RECEIVE AN INSUFFICIENT MEMORY MESSAGE
    • Save and close any open files and exit any open programs you are not using to see if that resolves the
    problem.
    • See the software documentation for minimum memory requirements. If necessary, install additional
    memory (see page 65).
    • Reseat the memory modules (see page 65) to ensure that your computer is successfully communicating
    with the memory.
    • Run the Dell Diagnostics (see page 46).
    http://www.fixya.com/support/p348570-del...
    this is an important link go through this
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
How do I scan with HP psc 1210
Answer is on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&lc=en&dlc=en&cc=us&product=90764#N305
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 24, 2011 | HP PSC 1210 All-In-One InkJet Printer
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Aug 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Question about copying direct from scan to a Word document
Check if your Canon software creates a PDF image. A scanned image is a RASTER image, a series of dots, that 'appear' like text or drawing. You cannot use Ctrl-C or Ctrl-v. If the software creates a PDF file, you can cut & paste. Usr any good OCR (Optical Character recognition) software ad convert the raster image to editable text. Then you can cut & paste.
S. Moha, Chennai
Dec 02, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
When scanning color document, blue tone is present as background shade
Have long experince with PixEdit program using Kodaks. PixEdit usually comes around it after a firmware upgrade on the scanner. Not sure about this specific model but at least OK on other models of Kodak.
Sep 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Edit a scanned picture
Take it into photoshop cs3.Type the text over the scanned text that u want to erase.resize the typed text to match the scanned one.
2)make a layer copy of the background layer.Turn off the original background layer.then, create a layer mask for the copied layer.and paint black over the area u want to erase, with the layer mask active.
If u don't no photoshop OR in case, u couldn't figureout what i said,then mail me ur scanned image and the text file to [email protected]. i ll fix it and mail u back the edited copy.THANK YOU!!!
Jun 24, 2008 | Microsoft Computers & Internet
I press scan it it wont scan my picture.
1. To load a picture, lift the lid and place the original face down on the left front corner of the glass, with the sides of the picture touching the left and bottom edges.
2. Close the lid
Scanning a text document
  1. Load the original.
  2. From the HP Director , click Scan Document .
  3. From the HP Scanning dialog box, select the desired options and Scan to destination.
  4. A preview of the image will appear in the HP Scan window. Make any edits from the HP Scan window and click Accept .
  5. Click Scan . The document will open in the selected Scan to destination.
Scanning a picture
  2. From the HP Director , click Scan Picture . A preview of the image will appear in the HP Scan window.
  3. Make any edits from the HP Scan window and click Accept . The HP PSC sends the scan to the HP Photo & Imaging Gallery , which automatically opens and displays the image. The HP Photo & Imaging Gallery has many tools to edit the scanned image. For more information about using the HP Photo & Imaging Gallery , see the onscreen help that came with the software.
Stopping a scan To stop scanning, press Cancel on the front panel. Hope this helps. Good Luck.
Apr 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
EpsonCX3900 NOT SCANNING TEXT AND SAVING AS TEXT IN Vista
There is absolutely nothing wrong with either your system or the scanner device, its just quite normal the scanned document are often saved in PDF or a image file formats, All you need is a text converter software (OCR) through which you can convert the scanned image or PDF file to text document and the best part is that you can even edit the text of the scanned document and make changes if you would like to as well. Here is the link for the text converter software download.
http://www.charactell.com/scanstore/InstSocr.exe
Click on the link to download and install the software that you require.
Alternatively you can also copy and paste the link in your web b browser address bar and hit the enter key to start downloading wizard.
Regards
Malik Khan
Jan 21, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
181 people viewed this question
Ekse
efs_perpends
efs_perpends
