Question about Connex Radio Communications
How do I convert my connex 4400 turbo from 10 meter to regular cb channel. I have the module to do so, but not sure what to do with it.
Posted by Mark Moyes on
Mike Charette
    Genius:
  • Connex Master
  • 1,847 Answers
Your connex should have a know with letters on it A,B,C,D,E,F, Look at the counter and set that knob to C whick should be the CB frequency.
Posted on May 16, 2016
4 Related Answers
Anonymous
SOURCE: Frequencies
i have a 4600 connex and if i turn the mic gain all the way up i get alot of modulation.can someone tell me how to fix that?
Posted on Sep 05, 2010
anymhz
AnyMHz.com
  • 500 Answers
SOURCE: how to convert a connex
That needs to be done by someone that knows how, theres soldering involved. most cb shops will do it for $free-$10.00... Don't pay any more than that.. there are no parts nor is it hard so they shouldn't charge much.
Posted on Mar 01, 2011
Ironfist109
Iron
  • 3018 Answers
SOURCE: can i get a connex turbo 4400 users manual
  • Yes you can. This is actually a service manual but it covers the basics found in the users manual in the first part of the first link. Also with a service manual you can dissect the radio to perform repairs.
  • Part 2 -
http://www.cbtricks.com/radios/connex/cx_4400_cx4400hp/graphics/connex_cx4400_cx4400hp_sm_pg16_pg33.pdf
Regards, Tony
Posted on Apr 30, 2011
normis101
  • 69 Answers
SOURCE: just bought a connex coyote hunter.the antenna i have is for cb i know that for 10 meter radios you have to have a antenna thats tuned.on cb band shouldn't i be able to hear On cb band? With cb ant?
To recieve signals on 10 or 11 metres with the same antenna is usually without problem, it's when you try transmitting that the correct antenna length is vital. If it's not correct, you can , at the least, get very little power being radiated, and at worst, the power going back into the transmitter and cooking it. If you have to ask these questions, you should not be on the 10 m amateur band anyway.
Posted on Dec 24, 2015
Converting connex 4400 turbo to a cb
If you disable any part of the radio that does not pertain to CB then you could actually do damage to the radio. the best thing to do is leave it on the CB band and don't touch it.
Mar 05, 2017 | Connex Radio Communications
Wanting info on my connex 4400 turbo how to peak and tune
unless you have the equipment to do this.. please take to a radio store. have them do it.. its free. or they shouldn't charge to do that service.. unless it needs a major factory alignment.
also they shouldn't take out or clip anything in the process if they do find you another place LOL..
Dec 24, 2012 | Connex 4400 320-Channels Base CB Radio
There is no power to the cb
I hope by now you have sent it back to be repaired or found out what the problem is.
Sep 04, 2012 | Connex 4400 Turbo High Power 10 Meter...
Can i get a connex turbo 4400 users manual
  • Part 2 -
Regards, Tony
Apr 30, 2011 | Connex 4400 320-Channels Base CB Radio
How to convert a connex 3400 hp to cb radio band from 10 meter band.
Feb 12, 2011 | Connex 3300 240-Channels Base CB Radio
My friend would like to purchase a Connex CX 3400 HP. The store told him that it has to be converted to a CB radio. But they can't do it because its illegal. Can you explain this to me?
These radios are know as what's called 'export' radios. They are imported under the auspices of being a 10 Meter Amateur radio and then through a typically easy modification are made to allow the selection of US CB channels. usually the modification involves plugging in a loose connector inside the radio radio chassis and/or removing a jumper wire soldered to a circuit board. If there is a nearby CB Shop they will usually do this for a modest fee.
Keep in mind that a radio needs to be Type Accepted by the FCC to be legal to use on the CB band in the US and export radios typically are not. Be sure to check the rear label for an FCC ID number.
Feb 12, 2010 | Connex 3300 240-Channels Base CB Radio
I need diagram connex cx 4400 power out put.
1-SHIELD
2-AUDIO
3-TX
4-RX
YELLOW-N/C
MAYBE THIS WILL HELP
Sep 26, 2009 | Connex 4400 320-Channels Base CB Radio
Can anyone explain the band knob and the pa/fm/am knob for my connex 4400 hp???
p.a. stands for public address,you need a pa horn for this. F.m. is for frequency modulation alot of ten meter radios offer this now it's mostly line of site communication if you have somebody else with fm though it sounds alot better. A.m. is amplitude modulation it's the standard way cb's have communicated since the beginning.I hope this helps.Good luck. Dan
Jul 25, 2009 | Connex Radio Communications
Frequencies
Feb 01, 2008 | Connex 4600 Base CB Radio
Radio Communications Logo
1,020 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
