Question about Lifesmart Renew Infrared Quartz Heater LS1500-4 1500W LS-HPTC15PB
What does E01 error code indicate?
Will run for days and then for no reason it stops and says "EO1"
Posted by Sarah Goucher on
What causes it to shut off?
I found nothing... iHeater 1500 Advanced...
(MY fault: strongly suggest the TELEPHONE)
Try
officialiheater.com
http://officialiheater.com/
or follow contact instructions (below)
Please be sure to read and follow all of the service
procedures outlined in this owner's manual. If you have
any questions concerning your iHeater, contact the
iHeater Customer Service Department at 1-800-469-0456
1-800-469-0456
iHeater, LLC.
5789 Park Plaza Court, Indianapolis, IN 46220
www.officialiheater.com
Carnac the Magnificent
Jan 02, 2016 | IHeater 1500 Advanced Infrared Heater...
My iheater (iH1500) seems to be missing a fusable link located in the back center of the unit. Can I get one to replace it. The unit doesn't power up.
If you believe it is not powering up because of a blown or missing fusible link, you can simply BYPASS the fusible link with a (large) piece of wire, briefly turning the power on to test the unit. If the unit powers up with the bypass wire (and it does not blow the fuse or breaker to that outlet)... leave the bypass wire there!
May 14, 2015 | IHeater 1500 Advanced Infrared Heater...
I tried the little buddy heater in my golf cart and as soon as I move the cart the heater goes out what can I do to stop this
This is not going to work in your golf cart. This is propane based heater with a pilot light. It will go out if you drive because of the wind blowing on it. I also believe all Mr. Heaters have a tip hazard turn off. I know the two I have do. If you really want heat in your cart I would recommend an extra battery, an inverter and a porcelain electric heater. Could be made to work very nicely in your cart.
Dec 25, 2014 | Mr Heater Base Camp BaseCamp Little Buddy...
I have a I heater that will not turn on. Last time it worked fine. What should I check ?
first check the outlet its plugged into to be sure there is actually power there, if not check your breaker box, it may have overloaded the circuit and popped the breaker. if all good there, check the unit for a fuse, which may be blown.
Oct 11, 2014 | IHeater 1500 Advanced Infrared Heater...
My iHeater shuts off
Our heater cuts off after 2 mins or less and it shoe 90 on the temps diplay. Had it for a couple of years. It's been vacuum and clean and still the same results. I don't have the schematic or the owners manual..
Jan 17, 2014 | IHeater 1500 Advanced Infrared Heater...
My fahrenheat fuh-54b won't stay running long enough to heat
Most likely defective thermostat or heat sensors on the unit
Nov 28, 2013 | Fahrenheat 5,000-Watt Unit Heater FUH54
I followed the instructions to a T. I turned my iHeater on using the--O switch located on the back. I adjusted the desired room temperature to 74 degrees. I adjusted the room size to Large. The iHeater...
I would read the customer reviews on this product , looks like nearly 70% of consumers are less than happy with this unit.
1500 watts is the units peak output, and drops to around 600 as it warms up. My hair blower puts out more power.
1500 watts is LESS than the output of a small element on your stove top. The real measure of heat is not watts, its BTUs and btus from gas are much cheaper than they are from electricity.
Nov 12, 2013 | IHeater 1500 Advanced Infrared Heater...
Heater runs 1 cycle then turns off
Replaced 301 80C 16A thermostat, purchased on ebay for $6.00, fixed problem. to Fix standing at front, Remove left side panel, two small screws hold thermostat in place. LifeSmart wants $36.00 for same part. Fixed problem.
Oct 18, 2013 | Lifesmart Renew Infrared Quartz Heater...
Lifesmart Renew Infrared Quartz Heater LS1500-4 1500W LS-HPTC15PB Logo
1,118 people viewed this question
Top Lifesmart Patio Heaters Experts
Tom Chichester
Lawrence Oravetz
deton8 von Splosion
Are you a Lifesmart Patio Heater Expert? Answer questions, earn points and help others
