Question about Brother MFC-9130CW Wireless Color All-in-One Laser Printer
Trying to set up new printer. What does 'machine error D900' mean?
Posted by veronique dube on
JonSnell Electronic
    Top Expert:
  • Brother Master
  • 31,782 Answers
Could be debris on the touch screen.
Brother MFC 9130CW Service Manual Page 118
Posted on Jul 01, 2017
MY TOSHIBA E STUDIO 451c HAS AN ERROR F100 CODE. WHAT DOES IT MEAN?
That code error meaning that you have a problem with HHD
1st you reboot your machine with push 0+8 than 690 start 2 set(interrupt).
If it don't wok you mast replace your HHD with a new one from Toshiba.
Aug 11, 2012 | Toshiba E-Studio 3511 Color Copier
Error c-0510 shows on screen
Code C-0510 means a low fuser temperature. Most probable cause for that - the fuser lamp is probably defective. Try first to clear the error code (if the lamp is close to its life's end the code may pop up after a long print) so do this: power machine off; turn on the machine with the stop key held down; turn off, then on again. If this doesn't fix it then you need a new fuser.
Jul 05, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Message on machine states error 77, unplug and call brother?
Error 77 basically means- Heater thermistor short circuit. However, the message is sometimes incorrectly shown. You can try this- power off the machine, take out the cartridge, close the door and power up. The machine should notice either the toner or the front door is not in place. Now open the door and place the toner. This might solve the problem. You can also try to soft reset the printer. If none of these works, you might have to change the thermistor.
Apr 06, 2010 | Brother MFC 9700 All-In-One Laser Printer
What is error code E000 mean
Solution:
Press "Additional Functions",
Press "#", then press the "Right Arrow" button till it says, "Printer",
Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
Then press "Set" again, the display will ask you "Yes" or "No".
Press the "Left" arrow for "Yes", then press "Set".
Now, unplug the power cord and wait 5 seconds and plug back in.
If this don't work, get a new fuser.
Feb 04, 2010 | Canon imageCLASS D880 All-In-One Laser...
Charger port seems faulty and wont take a charge SGH a 437
Umm, that means it was exposed to moisture or is water damaged.
The water dmage may have caused the charg port on you D900 to short out.
If it is the charger port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay
For more information and links to the parts check the following link below.
Samsung SGH-D900 charging problem repair
Dec 04, 2008 | Samsung SGH-D900 Cellular Phone
SMS sending error!
if its a new phone / sim then you might need sms / wap settings sent from your service provider to set the sms message centre number in your phone etc.
Alternatively some SP's require you to call them and register a payg phone to enable full functionality, call your customer service line and explain, they will fix it right away.
Jul 29, 2008 | Samsung SGH-D900 Cellular Phone
I have a samsung D900 that has a problem where the bluetooth light is flashing red likes its trying to send / recieve but when i try and switch it off the phone just hangs and I have to turn it off then on...
i have a samsung D900 that has a problem where the bluetooth light is flashing red likes its trying to send / recieve but when i try and switch it off the phone just hangs and I have to turn it off then on again. I have tried re-setting factory settings with no joy. It means I...
please tell me how to fix it
Jun 30, 2008 | Samsung Cell Phones
Sgh d900
could have a code on it or the card is corrupt try a new card
Jun 01, 2008 | Samsung SGH-D900 Cellular Phone
UNABLE TO PRINT
press menu then start bk copy then fourtimes arrow-up button (tel.index) quick after another.
machine will be in maintenance mode and lights will flash.
press start bk copy in case machine wont directly display the error code.
Error starting with 4 means defective print head.
Error starting with 5 menas defective purge station or cycle problems.
both error series means: you need a new printer...
Feb 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
Samsung D900
this may help you set up the wap settings http://uk.samsungmobile.com/supports/configurephone/wapSetting.do?&menuIdBody=00000000000016&menuIdTop=00000000000003
riz.
Oct 28, 2007 | Samsung SGH-D900 Cellular Phone
Brother MFC-9130CW Wireless Color All-in-One Laser Printer Logo
410 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
