Question about BenQ Cameras
Benq camera . Zoom out of the camera no longer operate and emits sound as if there is something aperture of the lens ..... Please reply disadvantage , and how to fix it
Posted by Beshoui Medhat on
Willie Mondo
    Sergeant:
  • 311 Answers
Hi Beshoui,
I believe your zoom lens is not extending when you power on. In most cases like this, there is likely a foreign body (sand) or similar objects lodged between the lens tubes or the camera has been subjected to a knock (dropped, bumped against a solid surface) that caused the lens tube to miss-align. All you need to do is:
1. as you switch on the camera, give a little knock/ tapping with your fingers around the lens.
2. if that fails, apply a little pressure to the sides of the lens ring while powering on your camera.
Lets hope that will help to dislodge the foreign body or the lens tube miss-alignment.
Posted on Feb 08, 2016
5 Related Answers
Anonymous
  • 76 Answers
SOURCE: zoom lens won't retract
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
Posted on May 11, 2007
Anonymous
  • 225 Answers
SOURCE: Coolpix S200 lens error message
A piece of sand had worked it's way into your lens machinery. Replace the whole lens, or find the grain of sand in a gear somewhere.
Posted on Nov 13, 2008
alternozzz
SOURCE: hp photosmart r742-lens error
Press the lens till the little doors close but not at all, i just fix it these ways 2 min ago! I SWEAR, just press it with a little hard and cross ur finger =D it work for me!
Posted on Jan 11, 2009
Anonymous
SOURCE: zoom lens is stuck on my camera
Hey, my husband just fixed it! You just wiggle/bend the zoom lens, and you feel a "pop", and then the zoom retracts and you're fine! I was afraid to "break" it, but someone on vacation had the same problem and told him this solution a few weeks ago. So don't be afraid to use a little force-at least, in our case, it worked! Good luck.
Posted on Feb 13, 2009
Anonymous
  • 126 Answers
SOURCE: FE-280 Lens Blurry Photos and no zoom turns off
You have a bad lens. Unless the camera is in warranty the cost of repairing the lens is higher than the value of your camera. The strange noise you hear is the lens motor trying to move the lens. One solution is to blow compressed air around the lens. Sometimes dust and dirt may jam the lens.
Posted on Jul 02, 2009
I have a Quantaray 28-200mm AF zoom lens Nikon, I use Nikon D80, are they compatible?
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same was as with a lens without an aperture ring.
Jul 14, 2014 | Quantaray 28-90mm F3.5-5.6 Autofocus Zoom...
Zoom and aperture problem
What lens do you have on the camera? Many zoom lenses have a variable maximum aperture. This means that the maximum aperture varies depending on the focal length. If you set the lens to its maximum aperture and then zoom, the aperture may change.
Feb 11, 2013 | Nikon D3100 Digital Camera
Sigma 15-30 aperture
The lens has an aperture range from f/3.5 to f/22 at the 15mm end of the zoom range and an aperture range from f/4.5 to f/32 at the 30mm end of the zoom range.
If you have some other question about the aperture, please ask it.
Nov 24, 2012 | Canon EOS Elan 7 35mm SLR Camera
NIKON D3100 zoom problem
The D3100 doesn't have digital zoom capabilities. The zoom range depends on the lens you have fitted on. The 5.6 sounds like the aperture. The maximum aperture also depends on the lens.
The S3100 does have digital zoom capabilities. Is this the camera you're referring to? Or are you confusing the specs of the two cameras?
Sep 23, 2012 | Nikon D3100 Digital Camera
Can i increase the focal length of the 75-240 lens if i add a mount or something like that? Please let me what you suggest.
Hi. Yes, you can increase your focal lenght with photo converter x1.4 or photo converter x2 so it would be 105-336mm with x1.4 and 150-480mm with x2. But consider that mounting such converters you increase the minimal aperture. Thus you will have to use higher ISO or longer shutter speed.
Apr 28, 2011 | Nikon 75-240 F4.5-5.6D AF ZOOM-NIKKOR Lens
Hello, I just brought my sigma macro 105mm lens and Im having trouble getting it to work probably on my nikon d90, they only way I can get it to work is turn the aperture on the lens to f32 I cant change...
Turn the aperture ring to f/32 and leave it there. After that, forget the lens has an aperture ring at all. You can let the camera control the aperture in any mode except the M and A modes. In the M and A modes, you control the aperture by turning the command dial on the front of the camera, the same way you control the aperture on a lens without an aperture ring.
Mar 06, 2011 | Sigma Telephoto 105mm f/2.8 EX Macro...
I have a Sigma 70-300mm lense which, when I attach it to my D300 gives me an error message of FEE. I was assured when I bought the lense that it would work. Am I doing something wrong?
You didn't specify which Sigma 70-300mm lens (Sigma has at least five different versions, and I'm not referring to the lens mount), but from the error message I assume the lens has an aperture ring. Turn the aperture ring to its smallest setting (largest f/number) and lock it in place. Control the aperture from the camera, the same way as on a lens without an aperture ring.
If the lens doesn't have an aperture ring, please reply to this post specifying the exact model of the lens. That's all of the numbers and letters around the 70-300mm, like AF, DGO, f/4.5, etc.
Feb 27, 2011 | Nikon D300 Body Only Digital Camera
I would like to set at the largest aperture. I have an aperture of 5.6 but I know I can get a larger aperture can you tell me how? thanks
The aperture can't be larger than the number printed on the lens. For example, if your lens says it's an 1:3.8 - 5.6, then the aperture can't be larger than f3.8. Since your lens is a zoom lens, it can only open that far at the 18mm setting. The farther you zoom out, the smaller the aperture will get.
Feb 16, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Nikon N80 error message appears when I turn on camera. Message is f EE in top right corner. New batteries installed did not fix problem
Your camera is telling you that the lens has not been set to it's minimum aperture.
As the camera body controls the aperture, the lens must be set to the minimum (highest number) aperture in order for the camera to be able to select any aperture between maximum and minimum.
If the lens is already set to minimum aperture then please report back for further options, but if my reply has solved your problem then please rate my answer.
Apr 03, 2010 | Nikon N80 35mm SLR Camera
Quantaray 28-200mm Aspherical IF
If I read this right, your lens is a 28 to 200mm zoom lens with aperture of f:3.5 - f:5.6. What this means is that at 28mm it has a maximum aperture of f:3.5. When you zoom out to 200mm, the maximum aperture is now f:5.6. This is perfectly normal for a zoom lens of this type.
Typical situation in Shutter preferred mode. I have the shutter set at 1/125 of a second and the f:stop is f:3.5. When I zoom out to 200mm, the shutter speed is still 1/125 of a second, but the f:stop is now f:5.6 and I have decreased exposure (darkened the picture) by almost 2 full f: stops.
Realizing this, I think that "turning off the camera" really isn't a fix. The problem is realizing that the aperture will change as the focal length of the lens changes (as you ZOOM in or out on your subject). Try the aperture preferred mode and you should note that the shutter speed will change as you zoom in and out.
Most important, pay attention to shutter and f:stop info in your viewfinder. FYI : Zoom lenses that hold aperture at all ranges cost several thousand dollars, and canon makes them - they weigh a ton.
May 29, 2008 | Quantaray 28-200MM F3.8-5.6 Lens for Canon...
Cameras Logo
51 people viewed this question
Top BenQ Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
Daniel Dollive
Daniel Dollive
Are you a BenQ Camera Expert? Answer questions, earn points and help others
