Question about Garden
Need to know what kind of oil is used in 2.0 cid gas chainsaw?
5 Related Answers
Anonymous
  • 52 Answers
SOURCE: craftsman chainsaw ps00376 2.0 cubic inch oil/gas ratio
Hi rbv1222,
40:1 is the ratio.
40 parts Gas to 1 part oil.
3.2 oz of oil per gal gas.
Glad to be of assistance. Please rate the solution because I can learn from your rating.
Thank you
Posted on Nov 09, 2008
J. Bradshaw
  • 121 Answers
SOURCE: I need to know oil/gas mixture for husqvarna chainsaw
40 to 1 is the ratio.
Posted on May 05, 2009
Anonymous
SOURCE: oil
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
Posted on May 25, 2009
Editor925
Dean
  • 285 Answers
SOURCE: need to know what kind of oil to put in ryobi
If it is an electric chainsaw (not gas powered) then the only oil you need is chainsaw bar oil, which lubricates the chain and bar during use (self feeding system). This goes into the chamber at the top of the saw. You can buy chain/bar oil for chainsaws at any good hardware store or outdoor power equipment store. You can use any brand of chain bar oil, most are pretty good.
If it is a gas/petrol operated model, I will need to know the model number to advise on that.
Posted on Jul 03, 2009
Anonymous
  • 548 Answers
SOURCE: Gas Oil Mixture
Fuel Mix: Add 6 oz. McCulloch custom lubricant or 1 PT. S.A.E. 40 (16:1) to 2 U.S. Gal. Regular Gas
Posted on Aug 25, 2009
What kind of oil and gas mixture to I use for my stihl kombi?
When you buy the 5L of unleaded Petrol (the same as a car uses), mix with the recommended amount of 2 stroke Stihl oil as marked on the container that the Stihl 2 stroke oil comes in.
Do not use any make of oil other than Stihl or Husqvarna 2 Stroke. I have come across so many people who have tried to cut corners by buying cheaper oil. If you are asking the question you are obviously not going to use the saw to cut down hundreds of trees so for a few pence/cents more for each fill, give the saw the best chance to last.
I always mix the can with 2 stroke oil as soon as I arrive home from the petrol station and MARK the can very obviously as 2 stroke. If you don't use the mixture within 1 month, it is a good idea to use it up in your garden mower. That is as long as the mower does not have a catalytic converter. It will work fine on the very weak oil mixture that modern saws require.
I need the oil gas ratio mix for a McCulloch eagar ****** 2.0 cid chainsaw. Thanks in advance!
McCulloch chainsaws are 40:1 ratio
128 Oz per gallon
3.2 oz 2-cycle oil per gallon gas
1helpful
2answers
What kind of gas/oil mix does this use
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
3helpful
Need to know the oil to gas ratio for a 056 stihl chainsaw?
Stihl chainsaws are 1:50 oil to gas ratio. Make sure you use good high-quality 2-stroke oil, preferably that which is made by Stihl.
Oil & Gasoline
Hi Thomas, you can find bar oil for the chain at just about any hardware store. Just tell them you need chainsaw bar oil. The oil that mixes with the gasoline is called 2- cycle mix. They will have that also. You can find the 2- cycle mix at a lot of gas stations too but a lot of guys caution not to use the 2 - cycle mix that is made for outboard motors. . Hope that answered your questions.
5helpful
2answers
Need to know what kind of oil to put in ryobi chainsaw
4helpful
2answers
I dont have the manual and Im not sure what ype of oil I should put on this chain saw. On the left The nob sais oil (which kind?) and on the right side it sais oil/gas mix (which kind?) what do i put on...
The Left knob needs chain oil. Available in most hardware stores. The right is gas mixed with 2 stroke motor oil. Usually a 50:1 mix. Ie. 50 parts gas to 1 part oil. 2 stroke oil comes with a built in measuring tool and directions printed on the bottle.
Jun 03, 2009 • Garden
1helpful
2answers
What kind of oil do I use in the oil reservoir of my chain saw?
I believe the reservoir you are talking about is for the bar chain oil. You can get it most anywhere. As for mixing the gas and oil mixture, you will need 2 cycle oil. It is available most everywhere also. Most modern chain saws use a 50:1 mixing ratio which means 2 1/2 ounces of oil to 1 gallon of gas. Hope this helps.
Garden Logo
Top Garden Experts
Jay Finke
Jay Finke
john h
wadingriver
wadingriver
