Question about Yamata FY14U4AD
How to use the pieces of the Power Machinery scissors
Bobbin case jammed, cannot see thread, how do I release mechanism?
Remove the needle. Then, remove the needle plate and try to remove the bobbin case from the machine. Otherwise, very carefully snip thread wads with small scissors and remove the clipped thread pieces with tweezers.
May 21, 2017 | Sewing Machines
My bernette has quit picking up the bobbin thread. Does the piece on the left do that or what? If so it hasn't any "spring" to it. When we touch scissors it has a terrible grinding noise..
If your top thread is no longer picking up the bobbin thread, it has probably been knocked out of time. It sounds like you need to take it for service.
Mar 16, 2017 | Sewing Machines
My sewing machine is jammed how can i solve it
Loosen the needle, try to remove the presser foot. Then try to remove the bobbin case from the machine.
Otherwise, if it is jammed with a wad of thread, you can try using very small scissors and tweezers to remove the pieces of thread.
Jan 21, 2017 | Juki Sewing Machines
Scissor button stick hand wheel won't turn
Sewing Machine Measuring Tape Scissors Iron Button ...
www.amazon.com/Sewing-Machine...Scissors.../B00K...
28 Sewing Hacks That Will Change Your Life
www.seamsandscissors.com/28-sewing-hacks-that-will-change-your-life/
Nov 1, 2014 - We here at Seams and Scissors have compiled 28 Sewing Hacks That Will Change ... Use a hair straightener to press fabric between buttons or embellishments. 17. ... Have a spool that is too big for your sewing machine? ..... My hint: I like to sew with the serger cones, so I just stick a drinking straw over the ...
Amazon.com, Inc.
Rating: 5 - ‎2 reviews
Quantity: 1 bead at listing price. Bracelet is not included. Last image shown as example; Compatible with all major brands charm bracelets, such as Pandora, ...
Search Results
    the handwheel on my sewing machine is stuck solid and won't turn ...
    https://answers.yahoo.com/question/index?qid...
    Feb 27, 2009 - Update: hi all, thanks for all your advice but it is the actual handwheelthat has seized up completly, i have no needle, thread or fabric in the ... Turned sewing machine hand wheel backwards, now it will not sew ...
    Nov 2, 2011
    Sewing machine: needle won't move up or down, even with ...
    Feb 23, 2010
    Sewing machine needle won't move up or down?
    Feb 1, 2009
    Sewing machine wheel jammed!?
    Sep 21, 2008
    More results from answers.yahoo.com
    Help me diagnose and fix a problem with my sewing machine - Sewing ...
    artisanssquare.com > ... > Sewing Machines
    Jul 31, 2012 - 14 posts - ‎6 authors
    The foot pedal doesn't make the needle go up and down, either. I unthreaded the ... I'm traipsing in the dark here, I'm assuming the power turns on ? ... There could be a bunch of thread inside the balancing/hand wheel.I found ...
Jan 25, 2016 | Sewing Machines
How to fix a bobbin case that is jammed in place by a piece of thread--case will not come out.
Very gentle persuasion with small (embroidery) scissors to cut the thread then tease i out per strand so you dont do damage to the timing mechanism. Often happens if you wind a bobbin and leave the needle threaded without locking the needle which should be done when yo wind a bobbin. If you send me the make and model Of the achine as long as it is not a computerised one, I may be able to suggest an alternative.
Oct 26, 2015 | Sewing Machines
The top left side piece has come off my machine. I need directions of reattaching it back on my machine. It is connected to the machinery the wire connecting to the light bulb.
How did it come off? What was holding it on there to begin with? Screws? Glue? If it's a clean break it might be possible to weld it back together.
Jun 01, 2015 | PfaFF Tiptronic 2030
I replaced cutter blade on Elna PRO DC 5. New blade won't cut fabric. how do I adjust it?
All sergers have 2 blades. Just like scissors. Only 1 blade of scissor is sharp = not good cutting.
Feb 14, 2014 | Elna 1010
How do I get my sewing machine apart? I have all the screws out but it's tight around the wheel and I can't get it apart.
i am alwase taking things apart and when that happens i drill a small hole where there is no circuit boards, wires, or machinery and put a flat head screw driver in the hole and peel the two pieces apart
May 28, 2012 | Brother XL-3500
Machine stopped running, its getting power but wont run.
Are you sewing or embroidering? If you are embroidering, the machine automatically stops and shows scissors in the window, for you clip the jumpstitch. Then just push the "Run/Stop" button.
Dec 13, 2008 | Husqvarna Rose
Yamata FY14U4AD Logo
Top Yamata Sewing Machines Experts
Kelley Buchanan
Kelley Buchanan
TCHNICAL SUPPORT FOR...
Ekse
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
