Chevrolet 1999 Chevrolet Tahoe LT Logo
G
Gary Fournier Posted on Feb 08, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The intake manifold gaskets have been change and the distributer has been taken out and put back truck will crank over but will not start like it is not getting a spark
Jerry Ross
Level 3:
  • Chevrolet Master 1,121 Answers
  • Posted on Apr 27, 2016
Jerry Ross
Chevrolet Master
Level 3:
Answers
1121
Questions
7
Helped
355438
Points
2563
Did you align the rotor in the dist. to #1 cylinder in the firing order if not you will not get fire to spark plugs. Is the unit backfiring when you turn it over or does it just roll over. Let me know.
Replaced intake manifold gasket in 96 chevy Tahoe now it cranks very slow but wen it starts it runs great already burned 2 starters
You should check to see if the timing is not to advanced that will make it crank slower. Also check to see if you did not forget to put the ground cable back on the manifold it should go on the second bolt or stud on the right side of the motor.
1helpful
I have a 1987 924s porsche..i had an intake leak at the intake manifold gasket but it ran pretty good considering for 20 thousand some odd miles with a little mis. So i replace the intake manifold gasket...
If you have spark and gas it should at least fire unless you don't have any compression. I would make sure that you have spark on all cylinders at the spark plugs.
2helpful
Were to start when changing cylinder head gasket
put in time and remove valve cover, front engine cover, timing belt ,exhaust at manifold, intake manifold and remove head bolts, pull head clean all surfaces replace gasket after head ck for cracks follow specs on bolts and put back together in a shop in would take about 4 to 6 hrs to do .
Adjusting Timing Chain
Push rod,you have two different size,or firing order is wrong. The intake push rod are 5 3/4 inch long, the exhaust are 6 inches long,Disable the spark and crank the engine the sound should be smooth and even,if its not correct the push rods.If it is correct the firing order
1helpful
Just replaced the starter on a 2002 Acura RSX. had to remove the intake. after the motor warms up the RPM's start to hunt. Did not replace the intake gasket. could this be the cause?
If the RPM's are going pretty low to where the car seams like its about to die, then it could be a vaccum leak. Whick could be cause by a bad gasket or something maybe didnt get sealed right when putting everything back together. If you do decide to change the gasket, i would recommend the "Hondata Intake Manifold Gasket". Its thicker and not made from metal and also keeps your intake manifold cooler.
2answers
94 towncar cranks and bogs down pops in the intake manifold . minutes before it started fine and ideled great . put in drive and it quit . when it start it runs great . sometimes it quits rounding a slow...
you have a bad intake gasket are a platuim gasket under the throttle body give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your car wish you the best of luck Michigan Man.
2helpful
2answers
Why won't my car stay runing?
bring it back and tell them the prablem or in ur case a differnt car may need to tow i t
Crank but no start
Check all vacuum lines to the parts that were removed
Intake manifold gasket change
You do not have the dist. in correct or plug wires are crossed. Please check wires 18436572 is firing order.
Top Chevrolet Heating & Cooling Experts
Paul Carew
john h
Are you a Chevrolet Heating and Cooling Expert? Answer questions, earn points and help others
