Question about Pride Health & Beauty
Pride colt plus mobility scooter light flashes 7 times battery fully charged frewheel lever in correct position and there is an audible continueous horn type noise but the scooter will not move
Posted by marie williams on
  • Rob Hill
    Rob Hill Feb 20, 2018
    hi, 7 Flashes is because there is a fault with the wigwag or throttle lever as it known, it has to be dead centre when turned on otherwise it produces the fault you describe, could be fault wiring leading down to the controller. Regards
Rob Hill
  • Pride Master
  • 1,414 Answers
Hi , 7 flashes mean the there is a issue with wigwag also known as the throttle lever now can you confirm the year of the colt please ?
Regards
Rob
Posted on Feb 13, 2016
3 Related Answers
Ironfist109
Iron
  • 3018 Answers
SOURCE: I have a pride gogo
  • What that flash code indicates that there is that the battery voltage is to high to operate the scooter. This can happen for a number of reasons and from out of no where. The manual says you should contact GoGo for this problem. But I know a couple things to try and if they do not work then you need to contact GoGo.
  1. First remove the battery connectors for 5 full minutes and see if that resets it.
  2. You may have a wire that got caught up somewhere so check all wires for breaks in the insulation, cracks etx.
  3. Check the fuse as well.
  4. Push in the main circuit breaker reset button (see diagram)
  • Here is the GoGo Pride Scooter website should you need to contact them and if what I listed does not work then you need to. The things I list are some at home troubleshooting tips GoGo does not offer. They say to contact them immediately. http://www.pridemobility.com/contact.asp
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jun 16, 2011
Dan Hudson
  • 118 Answers
SOURCE: NO DRIVE ON MY PRIDE REVO MOBILITY SCOOTER
You can try to do this with the cover off, just in case it is not seated properly and holding the lever from fully engaging. The actual swithc is a small microswitch down at the brake, and it can get dirt in it and that will stop it from working, or it may even fail, and need to be replaced. So I would:
1) try it woth the shroud off the motor using.
2) look for dirt around the switch.
3) take a paperclip and jump the scooter side of the switch to bypass the microswitch on the scooter, be careful not to short the jumper to the scooter frame.
Let me know how you make out.
Dan
Posted on Jun 11, 2012
lpfaff1
L Pfaff
  • 11573 Answers
SOURCE: light flashes 7 times battery fully charged the scooter is making an audible noise but it wont move at all i,ve checked the freewheel button and its in the correct place please help
Marie, scooter may need service, best to call a technician
Posted on Feb 08, 2016
Hi, i have a pride colt xl8, it makes a continuous beep when switched on, status led is fine , not flashing to show a fault, how can i stop this beep?
Make sure the disengage lever is in the correct position. If it is, then the position switch on the lever is bad.
Jul 22, 2016 | Pride Health & Beauty
Green ready light on Pride Sonic three wheel scooter wont turn on. What turns it on?
Hi if it is similar to pride x the circuit will shut down if key is left on for 20 minutes u will still have lights. Remove key for a short time then replace it & turn on ..goood luck
Jan 21, 2016 | Pride Sonic 3 Wheel Portable Scooter
Why won't my pride legend start?
The legend has a Curtis controller. The flash codes you provided points the problem to a faulty throttle pot. If a new throttle does not fix the issue, then your problem is the controller itself.
Sep 03, 2014 | Pride New Mobility Legend 4 Wheel Scooter
Pride mobility scooter celebrity x flashing 5 times not working
Hi remove key put freewheel lever into drive & replace key .turn on...,... good luck.,
Nov 04, 2012 | Pride Celebrity X 3-Wheel Electric Scooter...
I turn key on celebrity scooter. everything looks normal. all lights on, but does not run.
Are the lights flashing or steady? If they are steady and indicate that the battery is charged, make sure that the freewheel/manual brake release lever is in the drive position. If the lights are blinking, then you can visit this site to locate the type of controller on your scooter to try and determine what the problem may be: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
If you continue to have problems, please contact Pride Mobility Technical Support for assistance.
Dec 22, 2010 | Pride Mobility Products Pride Mobility...
Battery new cahrging good green light flashes
Hi. How many times does the light flash betwwen pauses? this is a fault code. Check free-wheel lever. Check motor and battery leads and connectors.
Check the resistance through the motor with a multi meter.
Good luck. Neil.
May 09, 2010 | Pride Sonic 3 Wheel Portable Scooter
Pride celebrity 4 wheel wont turn on
Hi
Please Check that your Freewheel Lever is Fully in Position as if is Slightly out of Position it will Not Work,
Gerry.
Nov 02, 2009 | Pride Celebrity X 4-Wheel Electric Scooter...
Hogh - low speed switch is incorrectly wired , but i dont know how it should be wired - Pride Hurricane scooter
Hi, I take it been taken then, do you get a error codes ?
see below
DIAGNOSTIC FLASH CODES
The diagnostic flash codes for your scooter are designed to help you perform basic troubleshooting quickly and
easily. A diagnostic flash code will flash from the status LED in the event one of the conditions listed below
develops.
NOTE: Your scooter will not run unless the flash code condition is resolved and the scooter has been
turned off, then turned back on.
Any electromechanical device occasionally requires some troubleshooting. However, most of the problems that
may arise can usually be solved with a bit of thought and common sense. Many of these problems occur because
the batteries are not fully charged or because the batteries are worn down and can no longer hold a charge.
FLASH CODE CONDITION SOLUTION
! (1) Battery charge is low. Charge batteries as soon as possible.
! ! (2)
Batteries are too low to operate the
scooter.
Charge batteries.
! ! ! (3)
The scooter’s battery voltage is too
high to operate the scooter, or the
charger is still connected to charger
port.
Unplug charger and/or turn key off, then
back on again.
! ! ! ! (4) Current limit time out.
Turn the scooter off for a few minutes,
then turn your scooter back on.
! ! ! ! ! (5)
The manual freewheel lever is in the
(forward) freewheel position.
Remove the key from the key switch,
then push the manual freewheel lever to
the (rear) drive position, and restart your
scooter.
! ! ! ! ! ! (6)
Throttle control lever not at center
position at start up.
Return the throttle control lever to center
position, turn scooter off, then back on.
! ! ! ! ! ! ! (7) Speed pot error.
Contact your authorised Pride Dealer for
assistance.
! ! ! ! ! ! ! ! (8) Motor volts error.
assistance.
! ! ! ! ! ! ! ! ! (9) Other internal errors.
Regards
GeWiz.
Oct 20, 2009 | Pride Hurricane 4 Wheel Personal Mobility...
Health & Beauty Logo
564 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Mike
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
