If you mean that the machine is tripping the circuit breaker then that is an indication that the water is creating an electrical current path to Earth. The heating element is normally enclosed in a metal sheath but if this is compromised then water will get in and current will then leak to earth, causing the circuit breaker to trip. The heating element can be replaced, but the cause of the damage to the element should also be determined to prevent it happening again. The rotating drum can become partially detached from it's mount and end up hitting the heating element when spinning, causing the element to be damaged. The drum mount (often called a SPIDER) may therefore also need replacing. If you machine was making a lot of knocking noises when in spin cycle then it would certainly indicate a broken mount.
SOURCE: Hotpoint Aquarius 1000 WM62, fills then trips the house electrics
This sounds very like you've got an insulation breakdown in the heating element, or in the wiring that leads to it. When the water level gets high enough, the machine switches the heater on to start warming things up - at which point the fault gets taken into circuit and blows everything. You already know all the stuff about switching off and unplugging before you start. If you hadn't just been working on the machine, I'd have said just to lash out £23 on spec. and fit a new element. Under the circumstances, it might be worth doing a few checks first: 1. Although you're sure you've replaced all the wires correctly, just triple-check you haven't swapped live and earth at the element. 2. Inspect the wires that run to the element to make sure none of them are chafed or trapped, and that none of the connectors are fouling anything they shouldn't be. 3a. If you can get hold of an insulation tester, use it to check the element earth-live resistance (with all wires disconnected). This should be of the order of a Megohm or more - but will be much less if the element casing has leaked. 3b. On the assumption you haven't got an insulation tester in your back pocket, try this instead: Carefully disconnect the live wire from the element, make it safe with tape if you need to, then try to run the machine. If the machine now fills properly without taking the trip out, then this is a pretty good pointer towards needing a new element. A.
SOURCE: hotpoint aquarius WMA58 spinning but
Suggest you check pump filter.
you will find it located at the rear right side of the m/c.
Remove lower rear panel, there you will see a large black hose, remove securing clip, and detach hose, the filter is located inside, remove and clean, make sure you put everything back in the same order you took it off.
This should solve your prob. Make sure the drain hose is not clogged and the outlet is clear also.
Plz rate my solution.
Thanks.
SOURCE: Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Thanks.
SOURCE: Hotpoint Aquarius WD440 tripping out as soon as program is select
it sounds like you have a direct short in the wiring some where on your machine.the only other option is the main control board needs to be replaced
SOURCE: hotpoint aquarius banging about when spinning
hi take the top of the machine and check the brick at top or bottom of the machine they sometimes come lose .
