Televison & Video Logo
Question about Panasonic Televison & Video
SB-WA350 WANT TO CONNECT TO VIZIO TV WITH OUT THE DVD UNIT
I WANT TO BY PASS THE DVD UNIT AND JUST MAKE THE PLUG BY SODERING STRAIT TO THE PINS
Posted by Jesus Leon on
Steve K
    Genius:
  • Panasonic Master
  • 1,054 Answers
You can't. There is no amplifier in the tv to drive a subwoofer.
Posted on Feb 08, 2016
Why will my vizio E421VO not turn on?
Please remove all extra devices (ie video game console, dvd platyer) and turn on your tv again. If not working, please attempt to change channels on your remote or remotes.
If still not working, please setup the tv like you did when you first bought it. Thank you.
I need the system cord for panasonic sb wa 350 could you tell me where to find
The SB-WA350 is the sub-woofer for the SC-HT900 home theater system. See the manual here at Panasonic's support page, https://shop.panasonic.com/support-only/SC-HT900.html , or ManualsLib, https://www.manualslib.com/manual/266877/Panasonic-Sc-Ht900.html?page=2#manual . The manual lists the system cable as part K1HA25HA0001.
I've found the cable listed at E-bay and here: http://salestores.com/pak1sucak1ha.html . However, Panasonic has discontinued the SC-HT900 and the cable is out of stock at most vendors. I hope this helps.
Add dvd to vizio smart tv
chechk ou ece or cec settings
How do I connect the speakers to a sb-wa350 subwoffer
Usually, it's the "stereo-audio-output" from your amplifier that goes to the sub-woofer, and then outputs from the sub-woofer to the left/right speakers. Or, if your amplifier has a separate output labelled "sub-out", then your connect your sub-woofer to that mono-channel output.
I HAVE A 32" VIZIO LCD I PURCHASED 2 YEARS AGO.
You should buy a sodering kit and remove the buldging capacitors yourself. Find a local electronics store, I used Radioshack, and see if they can match the capacitors. I had this happen with my Samsung lcd about a year ago and just help another friend with the same issue yesterday. The sodering is not as hard as you'd think. The capacitors should be under $5 v. paying a few hundred for the power board.
1helpful
I do not know how to connect my DVD to my 42 in
Tries use a RCA cable plug 2 connections ports holes red,white audio out input connected ur DVD player,connnect the other side the RCA to TV audio in input.Use a S-Video cable for video connection to get video.If u have the new version of a DVD player just use a HDMI cable plug one end to the DVD player the other to the TV.
Hi, advice me where I can find the system cable for an SC-HT900?
the system cable you are looking for is called: K1HA25HA0001 If you google it you'll get a number of places where you could buy, including ebay but their not cheap, hope this helps
8helpful
HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
