Vizio E701I-A3 70-inch LED-backlit LCD TV - Smart TV - 1920 x 1080 - 1 Logo
J
Jeff myers Posted on Feb 07, 2016
Picture went out watching it.. I replaced the t con bord and the main board and still have no picture???
2 Related Answers
Terry Corrow
johnny rebel
  • 10875 Answers
  • Posted on Jul 25, 2015
SOURCE: I have a 70 inch vizio model # e701i-a3e..just over one year old an picture went black an then lost sound.. T con board or main board or both?? Help please
contact vizio,they may fix it for free
rostit
  • 746 Answers
  • Posted on Sep 02, 2015
SOURCE: I got a vizio E701I-A3 an it doesnt show a picture when it powers on,but it does light up . I replaced the main board an t con board on it already.
Probably a bad panel. Those vizios are terrible. I worked on a 55" that was 9 months old with the same problem. replaced all the boards, ended up having a bad panel. See if you have voltage on the wires going to the panel. if so, its most likely bad
LED TV has sound but no picture, backlights are on, replaced T-con. It is the panel dead or could it be the main board?
Hi Pat, I'd test F1 on the tcon board to see if it's blown, if it tests ok try a main board, only way to know for sure if the main is outputting video to the tcon would be with a scope
Model UN60J620DAFXZA. Why did picture suddenly go blank?
There are many websites for you to find the ones you need to visit, but you should visit this website. I think you won't be disappointed. paper io 2
Vizio D650i-B2 lost picture
with the green issue I would think main. t-conns bad too. are you sure its not cable box ? we have had many with green picture issue and sound loss
1helpful
Vizio E701i-A3 Has no Picture/No Audio-backlight is on. I replaced the T-Con with no resolve. Help.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
I have a Samsung Smart TV. Owned it for 3 years and everything has been great with it. Recently the picture went out, I have audio but no picture. I need help replacing what has gone bad? T-Con board?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
My Proview RX-326 lcd tv Has sound & picture but Picture mix colers brite
There is some incompatibility issue. Did you check the format is set correctly for PAL/SECAM etc.?
1helpful
The picture goes to gray after an hour or so. Sound still works, but no picture. Picture starts to go bad...then goes gray. Is this a heat issue? Work good for about one hour...then goes gray.
When it goes gray, means that the T-CON goes bad after warm up or it does not receive the 12vdc feeding it from the main board, or the main board is bad, try running the TV with the back open with small fan blowing in the back, otherwise you can get a can of cold spray for electronics troubleshooting fro Radio Shack or repia shop and try cooling the T-CON bord or the main logic board with it to see will the pictures come back on. Also check the power supply for bad DC filter caps.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
