Question about Yamaha MSP5 Studio Monitor Studio Active
What can I do about my flood-damaged monitors?
I have a pair of Studio Monitors that were recently damaged in a basement flood. They still play, but with a significant crackling effect (also, when plugged in, one of the speakers always has the power light on, whether it is switched on or not. I am very partial to them and would refer to restore rather then replace them. What are my options?
rhodesworks
    Top Expert:
  • Yamaha Master
  • 3,157 Answers
I would strongly suggest putting an insurance claim and replacing them. Water damaged cabinets may swell and come unsealed over time, as well as the speakers themselves and the electronics degrading faster than you might expect.
Posted on Feb 08, 2016
  • Maud Guckin
    Maud Guckin May 09, 2016
    It will take more time and require some tools so you have to hire professional flood restoration service, you can visit our sitehttp://www.officecleaning.irish
Speaker monitor will not power up
Most likely bad electrolitic capacitors from it sitting for a long time
Feb 10, 2012 | JBL LSR 2328P 8" Bi-Amplified Powered...
Hi my names jason and i have a crackling problem with one of my krk rokit 5 g2 played a few tune's and the one speaker won't stop poping please could you help me with this i don't...
Try swapping the monitors inputs. if the other speaker starts popping on the same output it'll show that the mixer may have a problem. otherwise return for repair.below is a link to the manual. check out the troubleshooting section pg 13
http://www.krksys.com/manuals/rokit/rpg2_manual.pdf
Sep 12, 2011 | KRK Rp5 Rokit 5 G2 Studio Monitors Rp5g2...
I have a problem with my behringer b3031a truth studio monitors.Slightly before a sound it's played (and during the playing) they make a little buzz. Ex. I turn on Windows Media Player and as long as...
The fault is not with the speakers... It is with the noisy audio system common in computers. Get a decent USB audio interface and use balanced interconnect cables to solve the problem.
Aug 02, 2011 | Behringer B3031A 2-Way Active Studio...
Just bought a pair of used Beringers Truth b2031a monitors. one of which doesnt work anymore at all... opened the back of it (took those 6 screws out) and saw that the power connection has been cut of......
Here is the service manual schematics for your speakers:
http://elektrotanya.com/behringer_b2031.pdf/download.html
Scroll doen to "get manual" and click on it to download the manual... Do not click on the other downloads at the site, they are for viewers you don't need.
Take the schematics to a COMPETENT electronic service technician to get units repaired. You obviously bought units that had been hacked before...
Jun 21, 2011 | Behringer Truth B2031a 225-watt Powered...
I have recently purchased a set of M-Audio Studiophile BX8a Deluxe studio monitors. I can't register them for warranty because I can't find any serial number on the monitors or box that they came...
Call M-Audio and ask them about it... It is POSSIBLE that your speakers are counterfeit. It has been happening with high value audio equipment. There has been some failures of this product as well. Also contact the company you bought them from. There is a lot of grey market stuff on Ebay... I hope that wasn't your source.
May 30, 2011 | M-Audio Studiophile BX8a Deluxe active...
Static and crackling noise from the right speaker
It could be that the input jack is or cable is damaged. The input to the right speaker is from the left speaker via speaker cable. Check that wire and try a new one. All speakers are susceptible to some type of interference. Make sure the cables aren't tangled and free from other powered equipment.
Hope this helps
Mar 30, 2011 | M-Audio Studiophile AV 40 Monitor Studio...
My behringer b203a is making a loud muffle mono feedback sound when i am trying to use it. what could be the problem? please help!
this is normaly a wiring or amp issue. if it was the speakers they wouldnt make any sound or they would crackle or buzz
Jan 31, 2011 | Behringer B3031A 2-Way Active Studio...
I hooked up my Mackie MR5 Monitors to my MacBook Pro through an audio interface, I use it to record my band in the studio I use out of my basement. Except everytime I try to use the monitors they give me...
try hooking headphones to the output and see if the crackling is still there.
then, try it with the speakers, at a lower computer voume level and higher speaker volume level. perhaps the headphone output is too loud and distorting in the speaker inputs.
Nov 28, 2010 | Mackie MR5 MR5 Reference Monitor
I have a Fender Cyber Twin (1st edition, dont have serial number to hand) which I purchased 2nd hand from Ebay. Lately it has had a fault which started off as quite intermittent but has got worse. When...
Check for degradation of C144 a 2200mfd/16volt cap.
This is power source for the 5 volt digital hardware. Check for excess ripple with a scope. The voltage should NOT go below 8 volts. If the voltage dips, the DSP will go nut-case.
Sep 30, 2010 | Music
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
Aug 18, 2010 | Yamaha Full-Size Keyboard
Yamaha MSP5 Studio Monitor Studio Active Logo
50 people viewed this question
Top Yamaha Music Experts
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
