My battery was dead, the yellow and green where on and what I did was i unplgde it a few times it stop working no lights come on anymore what can the problem be
The flashing green indicator is telling you (and the notebook) that the battery is almost fully charged, but then by switching immediately to flashing orange, the status has changed to "battery charge is low". This is not normal behaviour and probably indicates a serious issue with the battery. My guess is that the charging is initiating some kind of rapid battery self-discharge. Ref - Knowledge Base
Notebooks will power up and work without a battery just fine. Ref - Laptop Battery Basics dummies Try to operate yours this way. This will eliminate the battery from the loop as a potential cause of the BSODs you are seeing.
The ambar lights are warning you the battery is becoming to dead, it means in a short time, if it has not happens now, the battery won't retain the charge anymore, it is time thinking in a replacement if you use your laptop without plug in the power outlet.
Hello, The CMOS battery supplies energy to the Real Time Clock when the computer is not connected to the electrical socket, and does not have the battery inserted. It should not prevent the computer from starting up. You will however be asked to reset the time and date of the computer. Hope it helps.
Nope! The internal battery is not plugged-in correctly. Unplug the APC unit and open the access door to the battery (it is not dangerous to do).
Re-seat the two wire clips (red & black) to the battery. The positive post has a red mark on it.
Close it up and charge for a few hours before using.
Leave it plugged in for a little while. When it's yellow it means that your phone is dead and it's charging up the battery. It will eventually turn on and the light will turn green.
Let the battery go all the way dead. You may have to adjust the settings in your bios so that the laptop will stay on until the battery goes completely dead. Then charge the battery. Do this a few times if it does not fix the problem you do need a new battery.
I purchased a Genuine Dell Battery, It arrived dead with 1 test light on battery itself at 0% charged, It only lasted 2 mins before the laptop died running on battery, It doesn't charge the Dell battery at all The replacement battery only shows a 1% charge every 7 hours or so, nor do I have a yellow, green, orange light, The only time I get a light on the battery led is if i'm running on batteries and the battery level is below 10%, Its orange for low battery.
Thanks in advance to anyone who could help me.
