I HAVE TRIED TO RESET THE ERROR BY HOLDING RESET AND TPUSHING POWER THEN TOUCH RESET TWICE THE WHEN GREEN LIGHT GOES SOLID PRESS RESET 4 TIMES HE POWER TWICE EVEN TRIED ONCE
Fix the problem first! You have a mechanical jam.
http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5b00
5B00/5B01 - Orange and green light blinking 7 times
Description:
A service error has occurred.
Resolution:
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
SOURCE: Current Problem on Printer """E5"""
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
SOURCE: s9000 canon printer ink tank full
Hi
Try this see if work for you.
may work
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
SOURCE: I had a paper jam Problem with the PIXMA? iP6009D
there might be some paper stuck in the rollers or which is blocking the sensor hence the msg. just give it a good check
E 4 or E5 for PIXMA is ink cartridge not recognised by printer. Try to take out ink cartridge (one by one) and check the brass connectors (at cartridge and the printer ink holder). If nothing suspicious, put cartridge back gently in and close lock firmly. Normally have to do this 2 - 3 times. If problem still occurs a simple trick put a piece of paper (with a bit of thickness) before locking the ink holder. Detail tutorials available here. Problem is due to the cartridge and ink holder connectors not aligning properly between one another.
