SOURCE: says:ink system failed,unable to copy,fax,print
It means you are out of ink and on newer printers, it can be only one color that will cause ink failure.Check your ink levels and replace the color that is empty.
SOURCE: error oxc18a0106
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide to purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: Ink System Failure
I had this problem, was about to buy me a new printer but than found the perfect solution. Just excuse my english (I am German). I have to translate the menue German into English and I hope I do it right.
Push the Setup and the arrow that shows to the left at the same time! Than push ok. A menue opens that says something with support. Push the arrow right button until system configuration appears. open it with the OK button. Now it should show the hardware failure status. If not look for it with the arrow button. When found the hardware failure status, again push OK button. Than something like clear inquiry should appear, push OK. As soon as the "hardware failure status cleared" appears, you can leave the menue by disconnecting the printer from the powercable.
Reconnect it with the powercable and it should work again.
SOURCE: cannot print
Try the following steps to remove HP Printer Error Code 0xc18a0001 :
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
