SOURCE: fiery cannot transfer the printing jobs to dc-12
have you tried replacing the cables maybe they are in a incorrect position wen you do this switch off the fiery and the machin.
SOURCE: cmyk dots on the print
There are several causes of those.
So go to Xerox.com
Click "support and drives"
then in the product name box, Type DC12
Then any line click support
IN the search box type "spots" and read the relevant solution.
SOURCE: free solution of black bars on paper while
Most likely this indicates a drum cleaning blade failure. This is especially true if the black Bars run up and down the page and get worse on multiple copy runs. So if you run 10 copies the last one out will be worse than the first one out. If this is the case, cleaner blades are pretty in-expensive at around $40.00.
Good Luck and Thank You for using Fixya.
SOURCE: What is the solution of black bars on paper while
Most likely a drum cleaning blade. If the streaks are verticle, up and down the page and if they get worse as you run multiple copies. So on a 10 page copy run the last copy out will be worse than the first. Cleaner blades are cheap at around $40.00
