My air recycle button just blinks. Also when i turn on the Auto button my AC turns on even though it is winter and 40 degrees outside
6ya staff
SOURCE:
jumptrout51
steve
  • 3361 Answers
SOURCE: Carrier PTAC Condenser ices over.
You are describing normal operation for a heat pump unit.
Posted on Mar 09, 2009
Anonymous
SOURCE: outside ac compressor not kicking on when ac turned on
Most of the time the capasitors are bad but it could be that the commpressor is bad or if it is a heatpump the low pressure switch could have it locked out or the contactor could be bad also
Posted on May 02, 2009
Anonymous
  • 400 Answers
SOURCE: AC unit outside turns on but no air blows through the vents
Your indoor unit pc board is bad, replace it.
Posted on May 08, 2009
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
The first problem sounds like the wiring is wrong up at the heating unit not turning on the blower fan in the heater when you call for cooling. Most typical is either something has chewed the wires or the wires have been stripped b something else. The AC not cooling your house can be either it is low on freon or the system is to small for your house. Also check your filter and make sure that it is not blocked and everything is clean with the filter
Posted on May 28, 2009
Anonymous
  • 340 Answers
SOURCE: I have a goodman CPE30-1AB and when i turn the
the compressor may not be running turn the unit off get it serviced
I do not know the service rates for the area where you are to find out what is wrong For me to show up in Minnesota 80.00 call reputable co. Tom
Posted on Jun 22, 2009
One of my ac's light is blinking and wont turn on. Is not the control batteries, what could it be?
Laptop Won't Turn on, Blinking lights - HP Support Forum ...
h30434.www3.hp.com > Laptop & Notebook > Boot
Solved: Hello My laptop is an HP pavillion dv6z-1100, its running a 64 bit version of windows 7 ... Message 1 of 38 (164,169 Views) ... Upon attempting to turn it back on (while being plugged into the ac adapter) the computer would power up, ...
Air conditioner light blinks - Discussion on Topix
www.topix.com > Chevrolet Malibu
Jul 11, 2006 - my 2001 Malibu has this problem, blinking A/C light. ... On the control panel for the air conditioner, the ac button(the one with the little green light) blinks on ... The ac will turn itself back to outside air after it has been running on ... 2002 A\C Blinking
May 14, 2007
2003 Toyota Camry A/C button flashing
Apr 10, 2007
More results from www.topix.com
Dec 25, 2015 | Computers & Internet
Tip
Windows and windshield fogs up in the winter
the real solution is to turn on and up the fans BUT you must use the fresh air from outside instead of recycled air. This is done by selecting or deselecting it using its own button. On my Toyota 2006 RAV 4, there's a button you push which is on the center of the climate control knob. By pushing it, you are using fresh air instead of the air being recycled. Any questions, let me know.
on Sep 12, 2010 | Toyota RAV4 Cars & Trucks
Ac unit keeps freezing up
what a heat pump is designed to do is reverse the evaporator inside coil and condensor outside coil. it trys to pick up heat from outside and transfer it inside. they work fairly well down to about 40 degrees ambient then not so good. that is why you have auxillary heat i.e. 15 kw. when it was shaking as you saw the compressor is trying to pump liquid instad of vapor as it's designed to. you either have a control issue or it's overcharged.
Feb 03, 2014 | Goodman Heating & Cooling
I installed an RTH2300 this winter to replace an old mercury thermostat. It worked fine for the heating season. I turned it to Cool for the first time today and my AC and furnace blower will not turn...
Maybe turn selector switch to off.see if every thing shuts off.if yes. turn FAN selector switch from (auto) to (on) mode.does the outside unit come on or does just the furnace blower only run ? the inside fan should be the ONLY thing on.if not, reverse the (G) & (Y) wires inside the new thermo.
Jun 07, 2011 | Heating & Cooling
A/C comes on every time I start vehicle. Not in auto mode. Even when dual climate knobs are turned to high, A/C still comes on. Why ???
Check to see that you have not depressed the AC on button its a small push in button bellow climate controls also on your temp setting turn it to the far right this is the warmest setting this will prevent auto kick in to the AC you may also turn blower knob to off This position turns off the blower motor and outside air
will not pass through any outlets.
Sep 27, 2009 | 2004 Jeep Grand Cherokee
AC/Defroster issue....
Turn the heat level up for a few minutes. It will dry out the ducts.
Aug 08, 2009 | 2007 Nissan Altima 3.5 Sedan
DURING DAYTIME WHEN HOT OUTSIDE 35-40 DEGREES C, AC TRIPs off
units are not able to work properly above 90, 1.0 T not go for more than 1 room. is outside of unit clean? if not turn off power to unit then spray 409 or simple green or something along those lines of cleaners on the coil part (soak it real good) it should cover entire coil as much as possible. let cleaner sit on it for about 10 minutes then use water hose to rinse as good as you can. wait about 10 minutes then try unit - so work better.
Jun 15, 2009 | Heating & Cooling
Will not heat below 40
2nd stage heat should kick in on auto defrost ,sounds like bad sequencer or relay
Jan 27, 2009 | Intertherm P3RA-036K Air Conditioner
AIR CONDITIONER ONLY BLOWING COLD ON ONE SIDE AFTER DISCONNECTING BATTERY
Turn your AC off. Turn the car off Crank the car turn ac on drivers side to 60 passenger side to 90 press auto wait 1 minute turn AC off (very important) turn car off turn car back on switch driver's side 90 passenger 60 press auto wait one minute turn AC off( very important) turn car off turn car on AC 70 both sides press auto your ac should be blowing cold If not, you have an expensive problem
Aug 25, 2008 | GMC Sierra Cars & Trucks
Heating & Cooling Logo
114 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
