Question about Sharp XR-10X Multimedia Projector
Projector does not start, standby lamp and lamp indicator still remains on after replacing new lamp,tried to reset but no respond
Posted by Samer Aly on
2 Related Answers
Anonymous
  • 630 Answers
SOURCE: projector does not start, standby lamp and lamp
Have you reset the timer?
Reset the lamp timer.
• While simultaneously holding down
MENU/HELP, ENTER and R on the projector,
press STANDBY/ON on the projector.
• “LAMP 0000H” is displayed,
Posted on Jun 12, 2010
Rinoo Kumari
  • 2973 Answers
SOURCE: Hi i just replaced the
Ravi,
I just read the manual for the projector. It clearly says that the lamp, if used for more than 2400 hours, will send the projector into standby mode. And then it should be taken to the nearest Sharp Service Center. Please do that. It means that the breakout from the standby mode is very technical and should be handled by trained technicians of Sharp.
Posted on Jan 14, 2011
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
  • Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
  • Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
  • Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
  • Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
  • Press the "Menu" key to exit the menu system.
  • Read more : http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
    How to Reset Sony Projector eHow
  • Turn on your Sony projector after replacing the lamp.
  • Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
  • Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
  • Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
    Jul 02, 2015 | Sony VPL CS4 Multimedia Projector
    Sharp projector timer unable to reset after replaced lamp.
    1,Connect the power cord.
    2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
    "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
    Have a nice day!
    We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
    motherboard, powersupply ... with high quality and competitive price.
    Jerry
    Lampdeng Limited
    Mar 07, 2015 | Sharp XV-Z9000, XV-Z9000E, XV-Z9000U...
    I am unable to reset the timer after replace projector lamp- there are no screen. How to reset the timer?
    Have a nice day!
    Jerry
    Lampdeng Limited
    HOW RESET THE TIME OF LIFE HRS TO THE LAMP INSHARP ANC55LP PROJRCTOR
    Have a nice day!
    Jerry
    Lampdeng Limited
    Feb 08, 2013 | Sharp ANC55LP Projector Replacement Lamp
    Projector sharp XR-H325SA indicating lamp I replace tha new lamp but still indicating ineed to reset lamp timer but how?
    hi,
    for resetting the lamp hour do the following
    1. Plug the power cord into the AC socket of the projector.
    2. While simultaneously holding down MENU/HELP, ENTER and DOWN ARROW button on the projector, press STANDBY/ON on the projector.
    3. "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
    ok
    Jan 24, 2011 | Sharp XR-10X Multimedia Projector
    My projector wont turn on and the lamp light is flashing but i got a new lamp at the start of the year
    Have a nice day!
    Jerry
    Lampdeng Limited
    Nov 12, 2010 | Sharp BQCXVZ100001 Projector Lamp for...
    Jun 12, 2010 | Sharp XR-30X Projector
    XV-Z10000I change the lamp with a new one it doen't turn on ofter replacing with the bulb, does it need rest and how can be done Thanks Zia
    Have a nice day!
    Jerry
    Lampdeng Limited
    May 18, 2010 | Sharp BQCXVZ100001 Projector Lamp for...
    Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
    that model has a history of bad ballasts. you'll need to replace it.
    Mar 03, 2010 | InFocus LP350 Multimedia Projector
    NEC LT240 has Power, Status & Lamp indicators lit & wont turn on!
    If your bulb finally reaches it's end before you have the chance to replace it you unit will shut itself down and go into a permanent standby mode. Changing the bulb alone will not remedy the issue. The solution is quite simple but not posted in the manual or anywhere else that I could find for that matter! All that is required is to hold down the HELP button on your remote for 10 seconds while aiming at the infrared sensor on the unit. This will reset the units bulb timer and remove it from the standby mode.
    Dec 10, 2008 | NEC LT 240K Multimedia Projector
    Sharp XR-10X Multimedia Projector Logo
    94 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    k24674
    George Mclaughlin
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
