Question about HP Officejet 5610 All-In-One InkJet Printer
No Connection Sign
I was printing, changed my mind, and pushed "cancel". Now it will not print at all. Note says "no connection". How did I lose the connection to my computer and how do I get it back
Posted by gymap on
Anonymous
I connect Hp 2015dn printer to a router( cisco 10/100 ) and my computer also to the router ; however, I can't get my printer to print. Please advice.
Posted on Mar 18, 2008
Anonymous
    Problem Solver:
  • 8 Answers
HI Gymap,
you can check the status of the printer in control panel, printer and faxes, in XP and in windows 98 or ME go to printers in control panel.
if the printer status shows paused or off line, then double click on the printer and then click on file then click on use printer off line and that should change the status.
If still no go then make sure there are no documents in the printer que when you double click on the printer icon, then deleat the printer icon and disconnect the usb cable of the printer and restart the computer, then connect the cable, that should fix the problem.
Let me know if you still have any issues.
take care bye
Posted on Nov 20, 2007
How do i change the language bak to English? And how do i print from my macbook laptop onto the printer
TO CHANGE THE LANGUAGE:
From the printer control panel, press the 'Spanner' icon.
Press the right arrow button, and then press OK
Press OK again.
Press the arrow buttons until the language that you want appears on the display, and then press OK.
If you are sure, press the right arrow button, and then press OK to change the language.
To print from your macbook laptop you may have to install additional software onto your laptop from the installation CD. Insert the CD and wait for the 'Welcome' screen to appear. (Note if the 'Welcome' screen does not appear after a minute, then click the CD icon on the desktop). Double click 'Install' and follow the screen instructions.
Some additional notes that may apply to your machine(s):
If the printer is connected to a desktop computer through the rear USB port and you decide to connect a laptop computer to the printer through the Quick Connect laptop port, then the Quick Connect laptop port connection overrides the rear USB port connection. The active print jobs on the desktop computer may be cancelled. Pause or cancel active jobs on the desktop computer before switching between ports.
To summerise:
Pause or cancel active jobs on the desktop computer.
Connect a USB cable to the laptop computer and then to the Quick Connect laptop port on the front of the printer.
Warning-Potential Damage: Do not plug in or remove the USB cable from the Quick Connect laptop port while a memory device is being accessed by the printer.
If you have not yet installed the printer software on your laptop then install it now.
Hope this helps
Jul 14, 2011 | Lexmark X6675 All-In-One InkJet Printer
I would like to cancel a print job without losing all of my memory card picture selections. Seems rather silly to lose all your selections if something goes awry with your printer output.
If you are using Windows, you can cancel a print job by opening your Start menu (usually the bottom left corner of your screen) then open Devices and Printers or Printers and Faxes depending on your version of Windows.
Double left-click the name of your printer
Right-click the name of the print job you want to cancel and select cancel print job or right-click a blank part of the printer box and select cancel all print jobs.
Apr 12, 2011 | HP Photosmart 3310 Printer
I just changed my ink cartridges. The test page will print, but the computer page I'm trying to print...won't. In the bottem righthand corner the printer icon keeps blinking along with a left facing...
hi,
First of all would like to help you so that you can cancel your print job.
On the bottom righthand corner where the prinetr icon blinks simply right-click it and select "cancel," after which the print job status commences to display "deleting..."
So you shoud not be worried about loosing your receipt as you can print it again.
Also
  1. I would like you to unplug the USB wire connected from your computer, turning the device off and then connecting everything from scratch. You can also restart the computer.
  2. Then once the computer is on please click on START and go to RUN and type in services.msc and then on the right side of the page find print spool and right click, then choose restart.
And then try for fresh prints.
Please let me know if the above information helps.
Feb 09, 2010 | Office Equipment & Supplies
How to cancel a print order
use the control panel on your computer, pick the printers, double click on your printer and it should list documents currently in Q. Highlight the print jub and pick the documnent ta b at the top left of the window and pick cancel.
Nov 03, 2009 | HP DeskJet 3650 InkJet Printer
Printed, now not printing nothing changed...
Try shutting down your computer and restart Make sure the printer is on before restarting the system
Have you cancelled the print que?
May 04, 2009 | HP LaserJet 2420 Printer
Cannot cancel copy process keeps on printing even when I press cancel button prints the same document over and over I want to print a picture from my computer can I download a picture from my camera...
Try doing this
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Nov 18, 2008 | HP Office Equipment & Supplies
How to cancel a printing
Go to Start-> run . Type in services.msc. Find the print spooler service, right mouse click and choose stop. Open Explorer and go to c:\windows\systerm32\spool\printers and delete all files.
Go back to services.msc-- Print spooler. Right click and start service
Apr 06, 2008 | HP Deskjet 3845 InkJet Printer
My printer isn't printing
ok i suppose it printed before and i suppose you have the ink and paper in it ok the printer is in standby mode in the print que soclick the print que button on the tray start printing click start printing in the taskbar and never pusg print 2 0r3 times or more then pages in you que become ready to print if not start printing in the print ques turn off the printer unplug it wait for 30 seconds restart pc then the print que is empty
Apr 04, 2008 | HP PSC 1315 All-In-One InkJet Printer
Lost Connection after 1 print-job
Please check the print queue in the computer. Clear it. Then restart the printer and the print server. See what happens...
Oct 24, 2007 | U.S. Robotics USR7500A Print Server
HP Officejet 5610 All-In-One InkJet Printer Logo
149 people viewed this question
Ekse
efs_perpends
efs_perpends
