Fitbit Charge HR Heart Rate and Activity Tracker Sleep Wristband Small Logo
R
Richard Hite Posted on Feb 04, 2016
Why can't I get it to sync with my iPhone 5? - Fitbit Charge HR Heart Rate and Activity Tracker Sleep Wristband Small
Angelina DiRe
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 04, 2016
Angelina DiRe
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
234
Points
Make sure that your Bluetooth is on (you can find that option in your settings).
2answers
How do I sync my iPhone 5s with my desk top
1.Download iTunes to your Mac/PC
2.Plug in your iPhone to desktop
3.Open iTunes, it will find your iPhone
4.Click your iOS device
5.On the Summary tab, select "Sync with this [device] over Wi-Fi."
6.Click Apply, then disconnect the USB cable
7.Choose which items you want to sync, then click sync.
Sync your iPhone iPad or iPod touch with iTunes using Wi Fi
2answers
Sync Contacts in Address Book from computer to iPHone.
On your iPhone, make sure that
  • in the Settings app
    • Mail, Contacts...-->iCloud has Contacts enabled (green button)
On your Mac, make sure that
  • System Preferences-->iCloud has Contacts checked.
If the iPhone still doesn't sync,
  • connect the USB cable from the iPhone to the Mac,
  • open iTunes,
  • make sure that "automatically sync iPhone when connected" is checked in the Summary window of your iPhone (in iTunes);
  • and click "sync" in the lower right corner of your iTunes window.
If you need further help, reach me via phone at https://www.6ya.com/expert/john_77bb351c0c06b354
2answers
Sync iphone and ipad
Hey friend. What kind of files do you want to sync between iPhone and iPad? Let's say, if you're planning to sync music from iPhone to iPad, you can simply rely on iTunes.
Please note that if you have hundreds of thousands of songs in iTunes Music Library, you'd better create a separate playlist for the songs you want to transfer. Then you can choose the playlist when you sync music to iPad with iTunes. The following guidance will show you how to transfer songs from iPhone to iPad with iTunes.
1. Transfer Purchased songs from iPhone to iTunes Music Library.
Sync Music
2. Connect iPad to computer with USB cable.
3. Click the iPad icon and choose Music.
4. Check Sync Music, and choose the iPhone music playlist.
5. Click Sync at the right bottom.
3 Ways to Transfer Music from iPhone to iPad
Why won't my iphone 5 sync?
You should make sure you are using the Apple certified cord that came with your phone for all syncing/updating. Start with that. Try re-booting your computer and phone. Make sure you have the most current version of iTunes.
How to transfer photo from view nx2 to iphone 5
You can export photos on view nx2 to computer first. And then transfer photos from computer to iPhone with iTunes/iCloud or other tools. As for transferring photos from computer to iPhone, you can follow the below steps.
Using iTunes to sync photos with iPhone is also easy. As a media management center, iTunes helps you easily manage data and files (purchased and non-purchased) on your iOS devices (iPhone, iPad and iPod). You could easily sync data and files to iPhone with iTunes. But you should be very careful of the syncing function of iTunes because it is a double-edge sword. Once wrong click, you may lose data in your iPhone. You'd better back up your iPhone to iTunes before you try to sync photos to iPhone with iTunes. The following steps are going to show you how to transfer photos from PC to iPhone with iTunes:
1. Plug your iPhone into computer via the USB cable. Launch iTunes if it doesn't launch automatically. Make sure that you have the latest version of iTunes.
2. Click on the device icon in iTunes.
3. In the sidebar on the left side of the iTunes window, click Photos tab under your iPhone.
4. Click the box next to "Sync Photos". If instead you see "iCloud Photos is On", all of your photos and videos are already on all of your devices that use iCloud Photos. You don't need to sync them through iTunes.
5. Choose the app or folder that you want to sync from. If you choose to sync a folder with sub-folders, the first level of sub-folders will appear as albums on your device.
6. Choose to sync all photos and albums or selected albums.
7. Select "Include videos" to sync the videos from your app or folder too.
8. At last, click the "Apply" button.
For more methods, check: How to Transfer Photos from PC to iPhone
3helpful
2answers
Iphone 5 music sync
This way should fix the issue about sync music from iPhone 5 to PC without iTunes:
- After your iPhone 5 connected to PC, launch the program you will see the right UI.
- Choose the list and music files you want to transfer , Click the "Export" button.
- After you clicking the "Export" button, the following window will pop up, you can choose transferring to computer or iTunes directly. You can set the output folder at Advanced->Options before transferring.
- When the transferring finished, the following window will pop up.
Done!
2helpful
6answers
How do you delete photos from ipad?
To delete photos in 1st generation ipad tap photos,tap photos again then tap photo you would like to remove.When in full mode trash can is available.
For 2nd generation and new ipad,tap photos then edit.Tap each photo to add check then tap delete to remove all checked at once.Please Rate
3helpful
How do i sync my new iphone 5 to my itunes music libary
All you need to do is go to your music library and under the edit button on the top tool bar select "select all" then click "copy".
Then go to your iPhone 5 music library under the "devices" section in ITUNES and click on the MUSIC folder, once your in this folder select "paste" under the edit menu. And your music will then start to transfer.
More sources: Sync iPhone 5 to iTunes music libary
IPhone Smartphone: iphone won't sync with laptop...
1. try another USB port.
2. try restarting iPhone and laptop while both are tethered together.
3. Update USB drivers on your laptop.
4. try reinstalling iTunes.
5. Try restoring your iPhone.
13helpful
9answers
How to sync contacts from iphone to outlook 2003?
When you connect your iPhone to the PC that you always sync with, Go to Info tab, Check the box Sync Contacts with: and select Outlook. Then make sure that you check the box Put new contacts created on this phone into the group: and select a subfolder in your main contacts folder.
This way, all the contacts from your iPhone will be saved into another folder in your main contacts folder of your Outlook PST.
Let me know if you have any questions.
Thanks
Sandeep
Top Fitbit Exercise & Fitness Experts
SmartAviator
SmartAviator
Are you a Fitbit Exercise and Fitnes Expert? Answer questions, earn points and help others
