Question about Magic Chef 31000 Gas Kitchen Range
How does the top open is it lifting from front of stove top or threar of stove top
Can only light 3 burners but wont stay lit and dont know how to light oven
Posted by Lori Hodson on
ray gallant
    Top Expert:
  • Magic Chef Master
  • 66,947 Answers
Call a repairman being a GAS unit I will not recommend DIY the explode if not done properly SORRY
Posted on Mar 07, 2016
Pilot lights will not stay lit on stove top or oven. Can light burners with match. Crosley c3100paw
You need to clean thermocoupling off it what the pilot lit uses to stay lit. you canuse sand paper or brush May need to replace, clean gas tubes on pilot also could be that
Dec 12, 2011 | Crosley Kitchen Ranges
Right, front flat burner does not light and barely heats. My Hotpoint stove is five years old and gets very little use. What's wrong? Can I fix it? Can you help?
Hello and Welcome to FixYa!
Please provide us with the model details of your unit and What exactly, you are facing. Is the burner properly getting the supply. And is it partially lighting or didn't lighting at all. Is the unit repaired ever since the problem started? Some details of the trouble, you are facing, will help suggesting more precise solutions to the problem,
Feel free to Ask,
Concerned.
Jul 15, 2011 | Hotpoint Kitchen Ranges
I have a GLEF379DQA glass to stove and I want to know how to lift the top to replace the burner.
1) Unplug unit 2) Remove back plate covering controls on back of oven 3) Notice 2 brackets, 1 on each end holding 2 screws-remove the screws 4) On front remove 3 screws underneath front ledge directly above where oven door closes 5) lift top up about an inch, and pull forward towards front of oven 6) You can now lift it to service - beware wires are still connected - dont pull too far forward and up
Nov 29, 2010 | Frigidaire GLEF379D Electric Kitchen Range
My stove lights very slow with a low flame. Should the igniter stay on after it lights oven
Yes the ignitor stays on even after the burner is lit. The ignitor is wired in series with the oven valve. It sounds like the oven valve isn't opening all the way. A new ignitor should solve this problem. The old igniter builds up resistance and doesn't let the correct voltage through to the oven valve for it to open properly.
Tom
Aug 16, 2010 | Magic Chef CGR3725 Gas Kitchen Range
I smell gas and my burners wont light - is there a pilot light in these ranges?
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
May 20, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Tappan stove model # 30-3053-23-02. How do I remove the stove top?
For Tappan stove model 30-3053-23-02.
Each burner (4) is mounted to the stove top with three 4.5mm hex screws. All 12 screws must be removed, which is easier said than done. In my case, of the 12, 6 heads snapped off. The other 6 heads had to be drilled out. The metal is very hard (tempered from long exposure to high heat?), so use a carbide/diamond high-speed drill bit (1/8" or 3/16").
The front corners of the stove top are each held by a clip. After removal of the burner mount screws (or heads at least), lift straight up on each front corner of the stove top to release the top from the clip. An alternate method is to use a screwdriver as a lever to pry the corner off the clip. Once released from the clips, the front pulls up, while the back is "hinged" (like lifting an auto hood). Using a stubby phillips screwdriver, unscrew one of the back hinges. At this point, the stove top can be lifted off.
If you are fortunate, the burners were unmounted by simply removing the screws. But if they broke off or had to be drilled out, it seems the best thing to do is just purchase new burner assemblies ($20-$30 each). In either case, also buy new screws specifically for mounting the burners.
Dec 22, 2009 | Kitchen Ranges
Holiday Stove Pilot Light won't stay lit.
Wow this problem sounds exactly like my landlords problem only he is just now saying he is learning of the problem. You even have the age of the stove correct.
Jun 16, 2009 | Cooktops
Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
May 30, 2009 | Kitchen Ranges
Pilot lights, main burner will not. Replaced gas valve, no change
I had a problem with the same stove,same model no. etc. Needed new valve. Will replace tomorrow, I will let you know how I make out.
Apr 06, 2009 | Vermont Casting VCS4017 (NG)
Ketchen aid kgst 307
There are several screws under the front lip of top of the range. You will have to open the oven door to see them. Once the screws are removed, the top should just lift up. Of course, if it has been a couple of years, grease and oil can creep into the seams along the sides and cause the top to stick. If this is the case, carefully take a putty knife along the side seams and lift up at the same time on the front. The top should open. Now, if ALL your burners are not lighting, that sounds like a bad spark module. Do you hear a clicking noise when you try to light any of the top burners? If not, the spark module not the igniters, is the likely suspect. The spark module provides a voltage to ALL the igniters simultaneously. Removing the top will not be necessary if this is the case. The spark module is usually located in the back of the oven cavity under bottom pan of the oven. Or, it may be located behind the panel in the rear of the stove. Let me know if this helps you.
Jul 29, 2007 | KitchenAid KGST307 Gas Kitchen Range
Magic Chef 31000 Gas Kitchen Range Logo
99 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
John Tripp
John Tripp
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
