Dishwashers Logo
Question about Electrolux Dishwashers
I have an error code on my Electrolux dishwasher EO?
Posted by Judy Fink on
  • Melissa Martin
    Melissa Martin Feb 07, 2016
    Hi Judy Fink, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Model number please
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Hello Judy, thank you for your post!
I understand that your Electrolux dishwasher is displaying an error code of "EO". The error code "EO" means that you could have a possible issue with the flow controller. I would recommend performing a reset on your dishwasher and this could help clear out any potential miscommunications. You can reset the dishwasher by disconnecting power from it for at least ten minutes. If the reset does not help correct the error code I would recommend having a professional technician out to perform a full diagnosis. Hopefully this information is helpful to you. -Matt
Posted on Feb 09, 2016
How do i fix electrolux dishwasher when error code 1 is flashing
Hello friend, thanks for your post!
I see your Electrolux dishwasher is displaying an "E1" error code. "E1" stands for a leak detected which means your dishwasher base has detected a leak. If you can't see a leak you may want to perform a reset on your dishwasher you can do that by disconnecting the power from your appliance for roughly ten minutes.
If that does not correct the issue you may want to seek assistance from a technician. They would need to come out to diagnosis and repair your dishwasher. I hope this information has been helpful. -Matt
1helpful
Have an error code 01 on my electrolux dishwasher
Good Morning Friend, I am happy to assist you!
Typically error code ER01 indicates that a water leak has been detected under the tub of your Electrolux dishwasher. Your dishwasher may possibly need a hydraulic kit. Try unplugging your dishwasher or flipping the household circuit breaker off first. It is good to wait approximately ten minutes and turn on your appliance. If the error code continues to display, then I recommend contacting a professional to make a precise diagnosis. Best regards! - Z
Error code 01 after problem has been fixed on electrolux dishwasher
I understand you are receiving an error code "01" on your Electrolux dishwasher, even after the problem was fixed. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why you are still receiving an error "01" on your dishwasher. Hope this is helpful.
-Best Regards-
WP
More than one error code 01 on electrolux dishwasher
I understand you are receiving more than one, error code "01" on your Electrolux dishwasher. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why you are still receiving an error "01" on your dishwasher. Hope this is helpful.
-Best Regards-
WP
2answers
Electrolux ewdw 6505error code "02"
Owners manual. Will be in the back. Google is your friend
I’m happy to assist further over the phone at https://www.6ya.com/expert/josh_8f8ad0a8f7e0e6d3
1helpful
Error code eo
Hello Gary, I am happy to assist you! I see that your Frigidaire dishwasher is displaying error code EO; however, is it possible that the code is missing a number or character(s)? Typically error code "E0" is follow by another number. In the meantime, you can reset your dishwasher. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on your appliance. If resetting the power does not correct the issue, could you please advise me of the new error code or if it continues to display "EO"? With this information I can better address the issue at hand. Thank you! - Z
Dishwasher electrolux wt30 error code c8
Hello Said Raji - Are you certain the error code is C8? Could it possibly be CE? If so, it typically indicates that the dishwasher has detected a configuration error. A professional will need to check the wiring connections between keypad and main control board.
24helpful
5answers
Top Electrolux Dishwashers Experts
Mike
W.L.
mark warfield
mark warfield
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
