SOURCE: COD MAN TGA EDC
EDC Electronic deisel control
03050 After run test, zero quantity
03 implausible
SOURCE: I have problem with my MAN truck TGA 33.400 It
EDC 03779-10 = Fuel pressure too low in the common rail.
Start by checking the fuel filters and the likes for deposits or leaks. Then take it to a repair shop and have them check the fuel pump itself. Finally they will have to dismantle the common rail and the injectors to check for abnormal wear.
This is a big job and if the pump will have to be replaced, very expensive.
difficulty in find a web page that has the codes properly explained
one site I found ---techtransa.It has a list or the numbers before the under score and what the fault areas are
To get there I went google and typed in--mandiesel model tga-18-350 fault codes--
there are other pages that make reference to fault codes but are not specific to your model
reading around the fault codes are specific to man and it seems that a normal obd-11 scanner will not be accurate
you might have time to down load a good site when you find one , but as I consider a heavy vehicle should be out earning income , time off the road costs money so, in the mean time and until you can find a down load for the faults, maybe you should take it to a service dealer and have it fixed
possible even to get a copy of the codes from the technician
1.EDC:00959-01
>seconds-Action-Tachometer has lost memory and is not aligning with the Edc
Control unit. mixture of time and date>Tachometer to be reprogrammed.
2. EDC:00960-01>minutes-
Action-Tachometer has lost memory and is not aligning with the Edc Control
3. EDC:00961-01>hour-
4. EDC:00962-01>Day-
5. EDC:00963-01>Month-
6. EDC:00964-01>Year-
