Question about Ricoh Office Equipment & Supplies
How to reset Ricoh mpc2550 copier sc508 error
Posted by lasantha on
Freckled legs
    Habit-Forming:
    Scholar:
  • Ricoh Expert
  • 129 Answers
By-pass bottom plate error.
1. Check or replace the harness.
2. Replace the by-pass motor.
3. Replace the by-pass tray HP sensor.
Posted on Feb 03, 2016
5 Related Answers
Anonymous
SOURCE: ricoh copier aficio 401 error sc 419
How do i clear SC 548 error on aficio 1022 copier machine
Posted on Jul 09, 2008
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
Bernard D'Souza
  • 164 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
Ickoajnc
OfficeServiceAjnc
  • 211 Answers
SOURCE: Error Code ''SC441'' on Ricoh MP4000 Copier
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good if this not help it will need to be checked by a technician
Posted on Jan 22, 2010
Rick Kasper
  • 2072 Answers
SOURCE: what is error code sc548
SC548 means the machine it not seeing the fuser unit. Open the Right side and front doors. Check the fuser unit to see if it is mounted properly.
There is some connection on the fuser module not making good contact. Reseat the fuser and power the machine off and on.
If you need to reset. Press Clear all, 107 and hold the pink button until you cee copy sp page displayed. Press copy sp, then while on that page turn the machine off and back on.
Posted on Jul 19, 2010
I want ricoh mpc 2030 printer serial number
The serial will be on the configuration or counter pagel
Mar 23, 2017 | Ricoh 841502 Aficio Mpc2030 Mpc2050...
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
I go ricoh mpc2550 machine but black printing very light printing
no problem u just cleaned scanner's 3 mirror.
and laser unit cleaned with brush comes with machine
Dec 06, 2014 | Ricoh Office Equipment & Supplies
How can i enter sp mode in mpc2550 ricoh
To enter service mode is the same for all ricoh's .... Press the yellow "clear" then numbers 1 - 0 - 7 then press and hold the red "Stop/Clear" till the screen changes.
May 22, 2012 | Office Equipment & Supplies
- A045 Wide Format Copier Copier: i have a code sc508-00 on a gesttener a045 its bas...
You can try to go to hardware store and take the sample with you and try to find the similar one. Its most cheapest way.
The best solution would be a new cutter assy.
Pls. rate
May 03, 2010 | Office Equipment & Supplies
Error sc508-00
Feed motor problem, lift motor, or height detector sensor error
Apr 09, 2009 | Gestetner Office Equipment & Supplies
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
1,579 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
CheckitRight
CheckitRight
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
