Question about Sharp Mx-2600n MFP Copier
Sharp MX-2600n has an E4-11 code. How do I fix that?
Shift motor error.
Posted by Neil Spicher on
Claude Kayser
    Top Expert:
  • Sharp Master
  • 9,098 Answers
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Posted on Feb 03, 2016
How can i dix error c1101 on bizhub 750?
Finisher related error code. The shift unit that slides the paper to create the offset sorting does not shift in the correct time. Possible causes would be foreign material blocking shift gates, mechanical failure of drive motor, failure of home position sensor, and failure of controling board.
Apr 29, 2014 | Office Equipment & Supplies
Tip
Error codes related to Canon ir 2200/2800/3300
E000 Heater temperature fault
(fails to increase)
E001 Overheating detection error
E002 Heater temperature error (fails to reach
specific level; inadequate increase)
E003 Heater temperature error (abnormal
drop; low-temperature detection)
E007 Fixing film rotation error
E010 Main motor rotation error
E014 Fixing motor rotation error
E019 Waste toner case full, sensor error
E032 DA unit communication error
E051 Horizontal registration HP
detention error
E064 Power supply voltage error
(high-voltage error)
E100 Laser BD error
E110 Polygon motor rotation error
E202 No. 1 mirror base HP detecting error
E204 ADF image leading edge signal
detection fault (absent)
E220 Lamp ON error
E225 Standard white plate/edge white
plate read error
E240 Mcon-Dcon communication error
E243 Mcon-control panel
communication error
E248 Backup (EEPROM) error
E261 Zero-cross signal error
E302 Shading error
E315 Image data processing error
E601 Image transfer error
E602 Hard disk error
E604 Image memory fault
E605 Image memory battery fault
E606 HDD error
E674 Fax board error
E677 PDL board mounting error
E710 IPC initialization error (Rcon)
E711 IPC register error (ctrl)
E712 Communication error (with ADF)
E713 Communication error (with sorter
finisher)
E716 Communication error (with pedestal)
E717 Communication error (with ASSIST)
E719 Card reader, coin vendor
communication error
E732 Reader communication error
E733 Printer communication error
E737 SDRAM error
E740 Ethernet board error
E741 PCI bus error
E742 RIP1 board error
E743 Mcon-Rcon communication error
(Rcon detection)
E744 Language error
E746 Resolution conversion board error
E803 MPWS power supply voltage error
(low voltage error)
E805 Fan rotation error
E901 Pedestal main motor rotation error
[ADF]
E420 Back-up data read error
E421 Back-up data write error
E422 IPC error
[Saddle Finisher-G1]
E501 Communication error (Punch unit)
E505 Back-up RAM
E510 Feed motor
E514 Delivery motor
E530 Width plate shift motor
E531 Stapler motor
E532 Stapler slide motor
E537 Alignment motor
E540 Tray ascent/descent motor
E577 Paddle motor
E590 Puncher motor
E592 Puncher sensor error
E593 Puncher shift motor
E5F1 Saddle folder motor
[Finisher-J1]
E500 Communication error
E514 Stack handling motor
E530 Rear alignment motor
E531 Stapler motor
E537 Front alignment motor
E577 Delivery motor
E580 Delivery tray ascent/descent motor
E585 Stack handling error
If the thermistor has a short circuit, the indication in service mode
(COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C
for the main thermistor; FIX-E=310°C for the sub thermistor.
Error codes from E000 to E003 can be in some cases reseted from service mode: PROCEDURE:
Press*
Press2
Press8
Press*
Navigate to: COPIER>FUNCTION>CLEAR>ERR.
Turn off and on.
on Aug 03, 2010 | Office Equipment & Supplies
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
Ricoh aficio 2060 sc738
738 = Finisher shift tray lift motor error.The stack height sensor does not activate within a certain time after the shift tray lift motor turned ON.Posible cause: shift tray motor defectiove or too much load.Turn the operation switch or main power switch OFF and ON.
Jan 03, 2012 | Ricoh Office Equipment & Supplies
I am getting an area R jam followed by SC726-00 service code. The paper is cleared but the machine won't run with the service code notification. Turning off and on again recycles through the R jam and...
SC726: Finisher Shift/Lift Motor Error
Definition [B']
1) Tray shift does not finish within a certain time after the shift motor turned on.
2) The stack height sensor does not activate within a certain time after the shift
tray lift motor turned on.
Possible Causes
• Shift motor defective
• Shift tray lift motor defective
This is a problem with the finisher shift motor normally.
Feb 21, 2011 | Ricoh Aficio 450 Copier
Model SF2530 photocopy Erroe F1 how to reset
F1 00 Content Sorter communication trouble Detail Communication line test error occurs when power is turned on or after the exit of a simulation mode. Improper communication with sorter Cause Improper connection or broken wire of connector or harness between copier and sorter Sorter control PWB defective Control PWB (PCU) defective Malfunction due to noise Check and remedy Clear by turning the power supply OFF/ON. Check communication line connector and harness. Replace sorter control PWB or PCU PWB. F1 02 Content Sorter transport motor error Detail Transport motor drive trouble Cause Motor lock Check and remedy Check transport motor operation with SIM3-3. F1 03 Content Sorter guide bar rocking motor trouble Detail Sorter guide bar rocking motor drive error Cause Motor lock Motor speed error Overcurrent to motor Sorter control PWB defective Check and remedy Check guide bar motor operation with SIM3-10. F1 04 Content Sorter indexer lower limit detected Detail Indexer has exceeded lower limit. Cause Sensor defective Sorter control PWB defective Check and remedy Check sensor with SIM3-2. F1 05 Content Sorter indexer upper limit detected Detail Indexer has exceeded upper limit Cause Sensor defective Sorter control PWB defective Check and remedy Check sensor with SIM3-2. F1 06 Content Sorter bin shift motor error Detail 1) Bin shift is not completed within 2.5 seconds after bin shift request Cause Motor lock Improper motor speed Overcurrent to motor Sorter control PWB defective Check and remedy Check bin shift motor operation with SIM3-4.
Jan 11, 2010 | Sharp AR-5316 Advanced Digital Imager...
Wath can i do,if the machine Canon Image Runner 9070 send the follow error message: E000532-0001
E532 Main cause Stapler shift motor (M10) Stapler shift home position sensor (P16) Detection The stapler shift home position sensor does not go OFF when the stapler shift motor is driven for 4 sec. The stapler shift home position is not detected when the stapler shift motor is driven for 4 sec.
Nov 16, 2009 | Canon imageRUNNER 8500 Copier
Error code sc726 savin copier 2545
SC726 indicates a finisher shift tray malfunction.
Nov 02, 2009 | Ricoh Aficio 1035 Copier
ERROR CODE
hi there, it means that the tray shift motor(the tray that holds the paper out) of your finisher has jammed.
you may put some lubricants on those of gears and guides connected to tray shift motor.
pls let me know if this helped you
Jul 18, 2008 | Panasonic DP-6010 All-In-One Printer
Aficio 1035 ps
Finisher 1 tray lift motor error.
It should be looked at by a technician to see if the sensor or motor needs to be replaced.
If you want to use the machine for now and bypass the error. Turn the power off on the copier. locate the finisher cable in the back of the machine. Pinch and release the cable and turn the power back on.
Jul 11, 2008 | Ricoh Aficio 1035 Copier
Sharp Mx-2600n MFP Copier Logo
589 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
