GolfBuddy Golf Buddy Voice GPS Voice Rangefinder - GB7VOICE Logo
Question about GolfBuddy Golf Buddy Voice GPS Voice Rangefinder - GB7VOICE
How do I change from meters to yards
Posted by Max Peek on
Randi Fisher
    New Friend:
  • 3 Answers
Anytime you need Conversions Google has a Converting Tool that is very helpful and I will include the link that will be most helpful to you. https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1CHNY_enUS674US674&ion=1&espv=2&ie=UTF-8#q=meters%20to%20yards%20google
Posted on Feb 03, 2016
Change meters to yards Bushnell Tour v3 slope
UNIT OF MEASURE OPTIONS The YARDAGE PRO TOUR can be used to measure distances in yards or meters. The unit of measure indicators are located in the upper right portion of the LCD. To select between yards and meters, look through the monocular, depress the "mode" button (left side of the unit underneath the BUSHNELL YARDAGE PRO logo) and hold it down for approximately 2 seconds. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the letter M for METER indicator while the YD for YARD indicator is turned off. If you are changing from meters to yards, the opposite will occur. Note: The YARDAGE PRO TOUR will return to the last setting used, each time the unit is turned on.
How do I change golf buddy WtX from meters to yards
5.1 Distance : Unit of Measurement This setting allows you to change your distance measurement from yards to meters. The default setting is set to yards. ? The tab next to "Distance Unit" in the tools menu, shows the current unit of measurement that your unit is set to. To change from yards to meters and vice-versa, touch the tab, and then touch "Done" on the bottom of the screen, to save the setting. https://golfbuddyglobal.com/doc/usermanual_worldplatinum.pdf
Mar 13, 2019 • Buddy GPS
Have golfbuddy wtx how to change yards to meters.
Yard to meters
1 yard = .9144 meters
I am guessing that is not the answer you want but more like how to change the reading from yards to meters on your compact 800 measuring unit
read the user manual to find the mode button and select distance or yards and change to meters
no manual , download one from the web site for the manufacturer
V3 change meters to yards
MODE and UNIT OF MEASURE OPTIONS
The TOUR V3 can be used to measure distances in yards or meters. The unit of measure indicators are located in the lower
right portion of the LCD. To select between yards and meters, press and hold the POWER/FIRE button. The display will
begin to cycle through the setup options: Yards w/JOLT, Yards, Meters w/JOLT, Meters (for details on the JOLT feature,
see "About JOLT"). When the units and JOLT mode you want to use are displayed, release the POWER/FIRE button to
select it. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the
M for meter indicator while the Y for Yard indicator is turned off. If you are changing from meters to yards, the opposite
will occur. The TOUR V3 will return to the last unit of measure setting used each time the unit is turned on.
V3 not jolting
The TOUR V3 can be used to measure distances in yards or meters. The unit of measure indicators are located in the lower right portion of the LCD. To select between yards and meters, press and hold the POWER/FIRE button. The display will begin to cycle through the setup options: Yards w/JOLT, Yards, Meters w/JOLT, Meters (for details on the JOLT feature, see "About JOLT"). When the units and JOLT mode you want to use are displayed, release the POWER/FIRE button to select it. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the M for meter indicator while the Y for Yard indicator is turned off. If you are changing from meters to yards, the opposite will occur. The TOUR V3 will return to the last unit of measure setting used each time the unit is turned on.
Feb 12, 2014 • Optics
How can i change yards into meters
1 yard = .9144 meters yards * .9144 = meters
2answers
Can my bushnell yardage pro rangefinder be calibrated. It is 4 yards off at 30 yards and 7 yards off at 40 yards. So on and so forth
I would send this unit in for repair to have it inspected you can reach their customer service at 800-423-3537 option 1.
Top GolfBuddy Optics Experts
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Marvin
Marvin
Are you a GolfBuddy Optic Expert? Answer questions, earn points and help others
