Panasonic SC-HT730 System Logo
Question about Panasonic SC-HT730 System
How can I correct F61 error?
System shuts down.
Posted by John Hogan on
Ravi
  • Panasonic Master
  • 1,682 Answers
See page 37 of the user manual.
Get from lil given here.
Error F61
Check and correct the speaker cord connections. If this does not fix the problem, there is a power supply problem. Consult the dealer.
http://service.us.panasonic.com/OPERMANPDF/SAHT730.PDF
Posted on Feb 06, 2016
System shut down suddenly while playing music , when i restart f61 error appears and suddenly shut down
Most users report this to be a fan error. It tends to blocked with dust and fluff. Cleaning the fan solves the problem.
I HAVE A PANASONIC CD STEREO SYSTEM AND THE DISPLAY SHOW: F61; WHATS THE MEANING???
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C. from overheating.
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
6helpful
2answers
What does f61 mean?
Pls rate my help.
16helpful
6answers
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
F61 error
I Have a panasonic mdvd home theater modl#SA-HT920, WHEN I RAISE THE VOLUME IT SHUTS DOWN AND INDICATES F61 ON THE LCD SCREEN HOW CAN I SOLVE THE PROBLEM
1helpful
F61 error
The F61 error message is effectively a "protect mode" message indicating that a problem was detected and that the system hasbeen shut down to prevent further damage. This is typically caused by a bad output amplifier pac or regulator. If you can post the specific model number, I'll try to get you the part numbers and costs.
Dan
2answers
SA-HT680 F61 Error
Typically the F61 error is a protection error indicating that there is a problem with the output amplifier section. The failiing part is usually IC501 (part number RSN311W64D) which costs about $95. Have this unit checked as there are other possibilities.
Dan
1helpful
Sa-ht680 service manual
The F61 indicates protect mode. There is a problem with the output stage of the amplifier section and the unit shuts down to prevent further damage. This unit will require service of the amp section. You can try to contact Panasonic for the service manual.
The output amp pac is an RSN311W64D at a cost of $95 plus shipping.
Dan
4helpful
2answers
F61 error
Hello....
Isolate problem by disconnecting Amplifier ic (RSN),if f61 still appeares after disconnection of RSN ic ,than check voltage supply rails ,may be one of them has irregularities.
Gopali
9helpful
2answers
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Top Panasonic Audio Players & Recorders Experts
Marvin
Marvin
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
