Question about Samsung GALAXY S4
We have a blue flashing light at the top left hand side what is it for and how do i turn it off
Posted by janis farrugia on
Eddie Tam
  • Samsung Master
  • 284 Answers
Samsung Galaxy S4: Flashing Blue Light:
Hello. By default it means that you got a text message or some kind of notification. If you are on the home page after opening the lock screen and your text messaging app doesn't show that it received a text message (if it shows it received a message there would be a one next to it, near "Messaging" app)
We have a blue flashing light at the top left hand - blue-flashing-light-top-left-hand-side-kyzl0pi20tqzz121bvlihxv0-1-0.jpg Then, with one finger.. touch the screen at the top of the phone and move finger down the screen (while still touching the screen).. you should see the notification area.. under the settings of that area it will show what is alerting you:
notification screen:
We have a blue flashing light at the top left hand - blue-flashing-light-top-left-hand-side-kyzl0pi20tqzz121bvlihxv0-1-5.png0pi20tqzz121bvlihxv0-1-5.png" alt="blue-flashing-light-top-left-hand-side-kyzl0pi20tqzz121bvlihxv0-1-5.png" class="h_mi" /> If you still want to turn this off.. go to:
Settings>Device>Display>uncheck LED indicator:
tipLEDindicator.mp4
Posted on Feb 01, 2016
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Alba LCD32HDF TV won't come on blue light just keeps flashing. Tryed unplugging it but won't come on
just had the same problem blue light flashing no sreen what i did was press the standby button on the side of tv very fast about twenty times and it came on but now have a little black shadow on the left hand side
Aug 09, 2012 | Televison & Video
Jag 2005 diesel 2.0 where is the fuse front right headlight
found this, hope it helps!
X-Type Fuse/Relay identificationpicture.php?albumid=77&pictureid=795
picture.php?albumid=77&pictureid=796
Engine compartment fuse box - fuses
Fuse Fuse Rating Colour Circuit
No. Type (amps)
F1 Cartridge 20 Blue Dip beam, High Intensity Discharge (HID) light relay.
F2 Cartridge 50 Red Ignition relay feed.
F3 Cartridge 60 Yellow ABS.
F4 Cartridge 30 Pink Rear window heater/heated mirrors relay.
F5 Cartridge 30 Pink Automatic transmission control module relay.
F6 Cartridge 30 Pink Heater blower relay.
F7 Cartridge 50 Red Power supply to passenger compartment fuse box.
F8 Cartridge 80 Black Blower module.
F9 Cartridge 50 Red Engine management system power relay.
F10 Cartridge 20 Blue Headlight power wash pump relay.
F11 Mini Not used.
F12 Mini Not used.
F13 Mini 30 Green Heated front screen right-hand side.
F14 Mini Not used.
F15 Mini 30 Green Heated front screen left-hand side.
F16 Mini 20 Yellow Left-hand dip beam, day time running lights, autolights.
F17 Mini 20 Yellow Right-hand dip beam, HID lights.
F18 Mini 20 Yellow Throttle motor supply.
F19 Mini 15 Blue Screenwash pump, rain sensing system.
F20 Mini 5 Tan Navigation display.
F21 Mini 15 Blue Side (Parking) lights.
F22 Mini 20 Yellow Accessories relay.
F23 Mini 10 Red Air conditioning compressor clutch.
F24 Mini 15 Blue Door lock power.
F25 Mini 15 Blue Direction indicators (GEM).
F26 Mini 15 Blue Horns.
F27 Mini 10 Red Automatic transmission control module, transit relay.
F28 Mini 15 Blue Ignition switch.
F29 Mini 30 Green Starter motor solenoid.
F30 Mini 30 Green Accessory sockets.
F31 Mini 10 Red Engine management relay coil.
F32 Mini 5 Tan Engine management control.
F33 Not used.
F34 Diode D3 Not used.
F35 Diode D2 Engine management control relay diode.
F36 Mini 10 Red Canister purge valve, airflow meter, throttle motor relay, power wash relay, air conditioning relay.
F37 Mini 15 Blue Engine management system, blower speed controller, road speed sensor (if fitted).
F38 Mini 30 Green Oxygen sensor heaters A.
F39 Mini 5 Tan Variable intake valves.
F40 Mini 15 Blue Automatic transmission control module.
F41 Mini 10 Red Injectors.
F42 Mini 30 Green Oxygen sensor heaters B.
Passenger compartment fuse box - fuses
No. Type (amps)
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear tail lights.
F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, Jaguar diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster.
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front fog lights, master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit.__________________
02 X-type 3.0l
04 S-type 3.0l
07 X-type 3.0l
Apr 05, 2012 | 2004 Jaguar X-Type
My watch is stuck on military time somehow. I would like to know how to change it back to normal time. My watch is a Armitron Alarm/Chrono WR 165 sports watch. The number on the back is 45/6915. Thanks for...
Welcome to Fixya,
The Armitron WR165 is a digital watch that includes a 24-hour alarm, hourly chime, stopwatch feature, countdown timer and is water resistant up to 165 feet. With a rubber wristband and rugged style, the watch is meant for outdoor enthusiasts and athletes. The WR165 can be found online, in some sporting supply stores and in certain department or general home stores. Setting the Armitron WR165 only takes a few steps to perform properly.
1 - Push the top button on the left-hand side of the watch until the seconds flash on the display.Press the top button on the right-hand side to zero the seconds.
2 - Push the bottom button on the left-hand side of the watch until the hours flash and then the top button on the right-hand side of the watch to increase the hour on the watch display. Note that "PM" will appear on the watch display for PM times, but there is no "AM" indicator on the display.
3 - Press the bottom button on the left-hand side of the watch until the minutes flash on the display.Press the top button on the right-hand side of the watch to increase the minutes on the display.
4 - Repeat to set the month, date and weekday on the watch. Press the top button on the left-hand side of the watch to return to time mode.
5 - Press the bottom button on the left-hand side of the watch to enter the stopwatch mode. Press the top button on the right-hand side of the watch to start the timer. Press one more time to stop timing. Press the top button on the left-hand side of the watch to reset the stopwatch to zero and the bottom button on the left-hand side of the watch to return to time mode.
6 - Press the bottom button on the left-hand side of the watch twice to set the alarm. Press the top button on the left-hand side of the watch until the hours flash on the display. Press the bottom button on the left-hand side of the watch until the alarm number flashes. Press the top button on the right-hand side of the watch to choose Alarm Time 1 or Alarm Time 2. Push the bottom button on the left-hand side of the watch again until the hours flash. Push the top button on the right-hand side of the watch to choose the alarm hour, followed by the bottom button on the left-hand side of the watch to change to minutes. Press the top button on the right-hand side of the watch to advance the alarm minutes. Press the top button on the left-hand side of the watch to set the alarm time and the bottom button on the left-hand side of the watch to return to time mode.
I hope this will help you.
Thank you for usinf Fixya.
Feb 21, 2011 | Watches
Model ld3270d Indicator light rapid flashing blue/red t.v will not turn on
hi there.you will need some capacitors replacing on the power supply board.they arent expensive at pennies each...yuor local repair shop may do the job if you take them the board along...
or easy to do yourself with a little knowledge of electronics and a reasonble soldering iron!!
regards,steve
Oct 22, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
How to test check engine light on a 1991 honda accord? Computer has no light on it like most honda's
These utilize a jumper connector(scs) in order to retrieve codes. It's location is just a little different for different models of hondas and acuras but generally speaking there relative to one location.On your car if you go to passenger front seat area and find the lower rt hand kick panel(to rt of your foot if sitting in seat)reach your hand just to the top edge of the panel you'll find a small blue 2pin connector.sometimes its got a small piece of tape holding it loosely to a wire cluster ,just pull it free of tape. With ignition key in off position,jump terminals together at connector with jumper wire,paper clip works fine.With jumper installed turn ignition switch into on position,not start just in run position.Observe check engine light.If DTC is stored check engine light will flash in series of pulses which are numbers of DTC. One long pulse is equal to ten, short pulses equal to one,example would be one long pulse pause followed by 2 quick flashes.this would be code 12 (EGR Problem). It will repeat this set of flashes 3 times,with long long pause between each.if multiple dtc are stored each DTC will be shown once,one rt after other,than will repeat series set over again for three series repeats then light will stop flashing.
NOTE:As i was saying about scs location,it is always found on Hondas/Acuras on passenger side seat area.it will be in one of following spots. 1.at back top edge of carpet where it meets up to dash area,to back edge of (ft side)center console piece(by left foot),behind rt kick panel as above or where lower hinge side if glove box meets dash,resting in that seam.always blue or grey 2 pin connector not connected to anything.Good Luck!joel
Nov 11, 2009 | 1991 Honda Accord
Our NLT32HDB2 has decided not to turn on. The
The flashing LED is showing a fault code and you need to know what it means and you will have to get into the TV and I presume you know nothing about how TVs work get it repaired by a TV technition
Oct 30, 2009 | NEC NLT-22HD3 22 in. LCD TV
Problems with my sony kv32fx20u tv
sony kv36xbr400 wega I have a 5inch black line across top and bottom & gray side to side making a smaller picture.
Nov 16, 2007 | Televison & Video
Samsung GALAXY S4 Logo
85 people viewed this question
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Michael Thomas
Michael Thomas
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
