Question about Sony Kv-40xbr800 Fd Trinitronr Xbrr Wegatm Color Tv
Where can I find a A1300319A Board. Because the tech took the board out, and said something wrong with the board.
Posted by Sandra Smith on
johhnywilliam123
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • Sony Expert
  • 72 Answers
Customer care support SERVICE number+1-
-833'''272''''0777,,,,,,,,,,,call them
THIS SONY A-1300-319-A COMPLETE PC D BOARD IS DESIGNED TO WORK WITH SELECT SONYTELEVISIONS.
Posted on Dec 05, 2018
Andrew Taylor
    Top Expert:
  • Sony Master
  • 33,969 Answers
It is a Power Supply board and is a part shared with some Sony televisions.
Sony Power Supply Board A1300319A KV32HS500 ... - eBay
www.ebay.com > ... > TV Boards, Parts & Components Sony Power Supply Board, A1300319A, KV32HS500, KV34XBR800... (280925870381) in Consumer Electronics, TV, Video & Home Audio, TV, Video & Audio ...
Sony A1300319A SONY A-1300-319-A COMPLETE PC D ...
www.amazon.com/Sony-A1300319A-A-1300-319-A...BOARD/.../B001... THIS SONY A-1300-319-A COMPLETE PC D BOARD IS DESIGNED TO WORK WITH SELECT SONY TELEVISIONS. PLEASE FOLLOW THE LINK ABOVE FOR ...
Sony A-1300-319-A D Board, Complete - Encompass Parts
https://www.encompassparts.com/.../Sony/A-1300-319-A/D_Board,_Co... Image, Manufacturer, Part Number, Description, In Stock, Part Price. Pts Modules, A-1300-319-A, Sony - D Board (Deflection & Power), 271.90 ...
A1300319A, A-1300-319-A Sony TV Module, D
www.tristatemodule.com/A1300319A-A-1300-319-A-Sony.../a1300319... US$148.00 Part Number: A1300319A. Board Numbers: . TV Models: KV-32HS500, ... Home > TV Parts > PC Board > A1300319A, A-1300-319-A Sony TV Module, D ...
Posted on Jan 30, 2016
Blue screen, no picture. What's wrong?
The board where the power button is located (same board for the other buttons too) is probably bad. It's all one board, which tells the power board to come on. If this happened after a power surge, and you're not using a surge protector, multiple boards can be bad. (You can't just plug these fragile TV and Blu-Ray players into the wall outlet. Eventually a surge will destroy them). Ps... A lot of people are suddenly making this same complaint with Vizio TV's.
Mar 03, 2016 | Vizio Televison & Video
IS the power board A1300319A under another number,because tristatemodule said they don't have the board anymore. and It's not on amazon ether.
Hi, I hate to say this but I think you should get a new TV. They are getting cheaper in stores. Sony is not making those TV's anymore.
Flat panels are in now a days. If you still want to repair it. Try ebay or other sites. Good luck.
Jan 30, 2016 | Sony Kv-40xbr800 Fd Trinitronr Xbrr Wegatm...
Where can you buy the A1300319A Board. I cant find one.
You are correct. What is the issue with the one that you have?
Jan 29, 2016 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Janome mc10000 pc board
Who told you that you needed a pc board? your neighbor.. or your Janome Tech? It may be a known issue... check with janome hotline.
Mar 19, 2013 | Janome Memory Craft 9500 Computerized...
I was cleaning out dust within my printer, i took out the motherboard to clean out some dust that was stuck in the printer and resitted the motherboard as it was, but when i start it up, the indicator or...
Yes you did something wrong. You pulled out a board not knowing what board you pulled out. HP printers don't have "mother boards". I am guessing that you removed the formatter(left rear on the printer).
Hopefully you had power off and you grounded yourself.
Since it isn't working now, power down and remove that board again and slide it back in to reseat it. Make sure that it slides in correctly. Screw it in and power up.
The green lights where the network cable plugs in should be blinking if you can get it to initialize.
Hopefully, the board didn't blow and it works now.
Apr 14, 2011 | HP LaserJet 9040mfp Printer
Sony FD Trinitron
The part number that you reference is teh complete D board and is available from tritronicsinc.com for $313.49 with a DUD return of $115.00 This means that you return the bad baord and get a credit of $115 when the board is received back at tritronicsinc.
I can only verify the interchange if you supply the original model number of the set involved.
Thanks,
Dan
Jun 27, 2008 | Sony Televison & Video
Mitsubishi flashing light replaced capasitors that were blown tv still has flashing light
The four cap replacement in DM module repair is simplistic
and incomplete, as you found out. ALL defective DM modules
have bad SMC's ( small "top hat" caps) AKA surface-mount
capacitors that can be changed only by the most highly skilled
bench techs. We used to change out hundreds years ago in
camcorder circuit board repair.DM board repair is a much more
accessible,thus more "do-able". For more info.............T.
Sep 26, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Sony Kv-40xbr800 Fd Trinitronr Xbrr Wegatm Color Tv Logo
195 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
