Question about Spalding 72351 Portable Basketball System with 44-Inch Polycarbonate B
How to get system to not pop up and retract automatically?
Hi. I am pretty sure I have assemble everything right, but every time my son makes a shot, as soon as the ball hits the backboard or rim, the locking mechanism snaps out, and the entire system collapses back to the storing/closed position. It seems that the locking mechanism is not keeping a secure and tight lock on any of the pre drilled holes in the tube. PLEASE HELP, thanks! Brian
Posted by Brian Feldman on
Adjustable basketball hoop
push on the back board up to get it to lock. Use the catch plate to bring it down.
Jun 14, 2016 | Spalding 72351 Portable Adjustable...
We got the top pole back to front..how to separate the poles ?
As silly and bizarre as this may sound... just take the pole and raise it to shoulder height and throw onto the grass at an angle. It may take a few attempts but the pole WILL come apart. I know you think I'm crazy ...but it does work. It's almost like a Chinese finger trap.
Jul 24, 2015 | Goalsetter GS60 60 Inch Glass Wall Mount...
How do I fix a wobbly in ground basketball hoop
I would clear any loose debris, repack around pole with a dry concrete mix then add water to it make sure pole is level, brace if necessary and give 24 hours to set up.
Apr 18, 2014 | Basketball
Score calibration
take it to the store or true it off and take the wire then put it back and then try
Dec 25, 2013 | Rhino Play Double Shootout Basketball Game
What the Problem
You need to give us a better picture and description of your problem. It looks like you are working with a basketball goal that is laying down on the ground. Do you really mean only the "Net," or are you using the word net to mean the whole backboard mechanism? Are you talking about hooking the strings of the net to the orange "hoop?"
Is this the first time you have tried to raise it, or has something changed after you have used it successfully for awhile? Is this new and you put it together yourself? If so, you probably made a mistake. Review the instructions, or ask a mechanical friend to look at it.
Often the answer is easy - its asking the right question that is the hard part! Hopefully you can understand that you have not yet asked us the right question.
May 26, 2013 | Basketball
How to setup a rawling softee hoop set
Unfortunately, I couldn't find a manual or instruction guide online. Here is the contact page of the Rawlings website. They should be able to help you assemble it.
Feb 24, 2013 | Rawlings Michigan Wolverines Slam Dunk...
How should I clean my basketball uniform?
You should wash it on a regular cycle. It does not to be gentle because the fabric can take a lot of pressure and sometimes need it. You can even put the detergent directly on certain spots to get rid of stains. I just suggest that you don't use bleach and that you use cold water so that the colors don't run.
Feb 06, 2013 | Basketball
This is my first year as a basketball coach and I don't know how long I should make each drill last. Any ideas?
It is important to keep your practices fast paced. By doing each drill for no more than five minutes, you allow each player to maintain a high energy level without getting tired of the specific exercise.
I need a instructions on a lifetime portable basketball goal that i can praint out
Here is a link to the manual you are looking for. I found it on the manufacturer's official site.
Jan 29, 2013 | Project Runway Lifetime 48" Portable...
How to install above the rim basketball hoop system
I believe this is the product you are referring to. The link is to the item on Sears' website. You should be able to find a manual there.
Jan 28, 2013 | Basketball
Spalding 72351 Portable Basketball System with 44-Inch Polycarbonate B Logo
319 people viewed this question
Top Spalding Basketball Experts
Anon
Tom Chichester
Are you a Spalding Basketball Expert? Answer questions, earn points and help others
