Question about Music
I need to know where to put the pickup wires and ground inside a 2006 jazz bass.
I'm replacing the old wiring and need to know where the pickup and the ground wires go.
Posted by john vierno on
rhodesworks
    Top Expert:
  • Music Master
  • 3,157 Answers
Here is the place to find any wiring diagram-
Wiring Diagrams Seymour Duncan Seymour Duncan
Posted on Jan 31, 2016
Testimonial: "Thank You for your professional help. the diagram was easy to read and most important to understand. I will have no problems because of your help.Thank You."
Wiring change from Fender
Standard J-Bass wiring is parallel. Not series.
http://www.mojotone.com/support/Schematics-for-Pickups-and-Guitars/Jazz-Bass-Wiring-Diagram
To run the pickups in series, the ground of one pickup would feed into the hot of the next. That's not what comes from the factory.
Mar 15, 2016 | Fender Music
How do I test for a poor ground wire as opposed to a bad ground wire on electric guitar wiring?
You are going to have to set that meter for ohms and not k ohm etc. When you check for resistance it should be close to 0. Check the wires one at a time and make sure that they are all pretty close to the same reading. Any one wire that is off from the others is suspect. Be advised that this could be a pickup issue or a signal wire that has floated to ground as opposed to an open ground.
Jan 23, 2015 | Guitar Research Music
Hello im re placing volume and tone pots on a
The braided wire is "chassis ground", and should be soldered to the case of one of the pots... the other two are from the coils.
If your guitar has two pickups, you will need to determine which wire is which to determine phase. Different pickup makers use different colors...so you can't tell by the color. One of the colored wires will be tied to ground as well. Hook up the pickup wires one way first (temporarily), then switch them. the louder thicker sounding way is in phase. If it sounds thin, it is out of phase.
Hey, since you are doing this anyway, why not put a phase switch in it?
You can easily find the schematic online. It will double the amount of sounds you can get.
Oct 13, 2014 | Music
Soldering barcus berry bridge pickup
Solder the white wire to the shortest terminal and the ground/exposed wire to the outer/largest/ground terminal.
Jan 08, 2013 | Barcus Berry 1320 Violin Bridge Pickup...
I am replacing an input jack on Dean ML. However, the old one was not there and I need to know which wire is positive and which is negative. There is a clear coated wire and a silver white coated w
With standard color coding of wiring, the clear coated should be the negative ground. However, this is not always a guaranteed bet. If you just want the pickup polarity, use a meter on ohms or continuity and test each wire to the pickup body, presuming the body is metal. The body should be ground. Otherwise try http://guitarelectronics.com/guitar-wiring-resources/
or pininterest.com or ultimateguitar.com which have detailed wiring sketches of many pickups and associated wiring.
Jan 17, 2018 | Dean Guitars Music
Ephiphone guitar pickup wiring
Or a bad solder connection on the ground wire on the jack, or shell/sheild on the guitar.
Here is the list you seek.
http://www.gibson.com/en-us/Support/TechSupport/Wiring Diagrams/
Feb 03, 2012 | Epiphone Les Paul Studio Electric Guitar
Need adiagram for replacing 3 wire factory humbuckers with 4 wire seymour duncans
These are for the seymour duncan JB pickup which uses an extra switch for a coil tap. If you tie the leads of the switch you can avoid using it in which it would become a normal humbucker.3_8_2013_7_29_41_pm.jpg
Sep 26, 2011 | Music
I have multiple wires disconnected on a Dean Vendetta and need a schematic to show where they go.
this should be what you need, albeit for a different guitar. 1 vol, 1 tone, and a 3way pickup switch. your wire colors may be different, but follow them from place to place and youll be good to go. any nonshielded wire from a pickup is a ground, as well as generally one other wire from the pickup will be a ground. if there are 2 wires from the pickup, and both pickups are the same, it doesnt matter which you choose for a ground and lead, as long as you do the same for each pickup.
http://www.irongear.co.uk/2%20x%20humbuckers(4-wire),%201%20vol,%201%20tone,%203-way%20toggle,%20no%20coil%20switching%20igwatermark.gif
Sep 14, 2011 | Dean Vendetta XM Electric Guitar
I'm trying to wire passive pickups in my Schecter Tempest Hellraiser. The problem I'm having, is that there is no way to ground everything to the bridge. My pickups' wiring diagram (and my other guitars)...
If you have a metal bridge, then install a jumper from a convenient point to the rest of the grounds. These grounds help reduce hum pickup. If the guitar is working with no hum while using and handling it, don't sweat grounding the bridge... The purpose is REALLY to ground the strings which is where you will likely pick up hum when you touch them... you are an "antenna" picking up the noise from all the power lines, etc around you.
Apr 15, 2011 | Schecter Hellraiser Tempest Electric...
I have a washburn WI 14 guitar and trying to change pickups. the old one is two wire. white and bare. the new one have like 5 wires. anyone replace the pickups in their wI 14?
This is the way most aftermarket pickups are set up. Its to accommodate different wiring setups like coil splitting.
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2h_2v_2t_3w
Whether the pickup is a Duncan or not does not make a difference. Make sure you solder the red and white wires together(the ones together in the diagram) and cover the joint with heat shrink or electrical tape.
Jul 01, 2009 | Washburn Wi14 Electric Guitar
Music Logo
77 people viewed this question
Top Music Experts
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
