Question about Generac Electrical Supplies
What weight oil does a 5550 watt take? - Generac Electrical Supplies
2 Related Answers
vincob
vince janis
  • 718 Answers
SOURCE: what engine oil is used
The generator engine is shipped from the factory filled with
oil (API SJ or higher 10W-30). This allows for generator
operation in the widest range of temperature and climate
conditions. Before starting the engine, check oil level and
ensure that engine is serviced as described in Maintenance.
This is from toy bilt manual >Good Luck...
Posted on Aug 31, 2011
stewbison
Richard Morris
  • 577 Answers
SOURCE: What is the fuel capacity of the Briggs and
Hello, probably a really good guess is 2 1/2 to 3 gals. Oil type I would use cleaing additive multi-temperatur 10/15 or 10/20 well know brank. Synethic oil I don't know how well does it work in an air cool engine. GB...stewbison
Posted on Sep 29, 2011
What weight oil do I use for a 5000 watt Coleman generator
Depends on the temperature where yuo will operate it, but a good multi-viscosity oil like 10W-30 should work. 5W-30 for cold climates.
Sep 07, 2014 | Coleman Powermate 5000 Portable Generator...
Oil type
If you are asking about the engine oil, generators like the 10W 30 weight oil, which is good for winter and summer use. . The brand doesn't matter to any gret extent. Just don't buy the el cheapo brand in the dollar store.
Jun 02, 2014 | Groove Tubes Power Back 5,250-Watt...
The key is stuck up
You do not indicate which instrument, but I would guess in most cases it will be the result of the wrong oil being used on the key's pivot point, or sealing area. Sewing machine oil, Labelle light oil, or nondetergent synthetic motor oil 5 weight single viscosity should be used- nothing from a spray can as you can glue things together with a couple of them quite thoroughly.
If the materials are metal, warming the area with an incandescent light bulb of about 40 watts should loosen things up. If plastic is involved, nothing more than a 20 Watt incandescent.
Jun 11, 2012 | Music
Briggs 5550 model 030253 generator spits oil
I'll take guess here, broken ring. You did mention where it was spitting oil from? GB...stewbison
Sep 05, 2011 | Briggs & Stratton Power Products 5,550...
What engine oil is used for a model 01919, 5550 watt Troy-bilt genertor?
Aug 31, 2011 | Troy-Bilt Garden
What is the fuel capacity of the Briggs and Stratton 5550 watt generator and what type of motor oil does it neet?
Aug 23, 2011 | Briggs & Stratton Power Products 5,550...
What type and weight of oil do you use
Porter Cable recommends straight 30 weight synthetic oil for their engines. However, If you live in a colde climate or in a hot climate, the use of multi-viscosity oils is my recommendation. Straight 30 weight oil in my cold climate would not work. So, it really depends on where you live.
30/5 works well in a cold climate like mine.
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | Porter Cable 5,500 Watt Portable Generator...
Generator is burning oil and choking out
You have/had too much oil in it. After it is brought down to proper level, it may have to burn the oil that is in areas that it should not be in. Another thing that may cause this, is a dirty air filter, can cause enough suction to pull oil around valves, and other places a clean filter will not. It may have oil in the filter too.
Dec 19, 2008 | Briggs & Stratton Power Products 5,550...
Can't re-lock printer back cover.
You can use less greasy oil or something like the vehicle engine oil.
Any kind of thin lubricant is always yield good results.
Do not use vegetable oil or cooking oil/sunflower oil etc.
Oct 23, 2007 | HP DeskJet 5550 InkJet Printer
Electrical Supplies Logo
62 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
JOHN LAPIER
Bill Johnson
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
