Question about KLH DVD8350 DVD Player
Is there an illustration for hookup of cables on the KLH DVD8350 DVD Player to an RCA LED HD TV?
If no images are available, instructions will work. What I really need is a manual for the product. Can you tell me where I can locate one? Thanks!
Posted by Roxanne Manko on
ray gallant
    Top Expert:
  • KLH Master
  • 68,546 Answers
All you need to do is match the cable type of the DVD to the TV and set the input on the TV to the same type be it HDMI or rca cables
Posted on Jan 30, 2016
Testimonial: "Thanks for reaching out. I know, it seems so simple, but it won't work. Do the colors of the cables really have to be the colors used? I have cables hooked up to and from, for audio. When it comes to the video though, the cable in the DVD player is fine but the RCA TV has no other places for me to plug the other end of the cable in. The only remaining places to plug anything in are the composite PB PR and Y. I can't get past this to work on the input issue. If you could help, I'd be ever so grateful! Thank you."
  • Roxanne Manko
    Roxanne Manko Jan 30, 2016
Att uverse hook up hd tv
I do not own a blue ray player but my son has a PS3. The thick cable is most likely HDMI and it should work without the red/white sound cable...try unplugging them so the auto detect feature if available and activated is not trying to compete by finding 2 sources. If that works great! If not, you can get a yellow RCA for the video and just use those as a source - again, don't use the HDMI cable and try it. If you don't have a yellow RCA, I've used another red or white for video testing to see if I can get a video feed. Most newer red/white cable will pass a video signal just fine and are only color coded for ease of hookup.
Mar 04, 2014 | KLH Televison & Video
Hi, I'm getting only 720x480i resolution with component cables connecting this DVD and TV. My TV is full HD TV, but I cannot get 1080p with component cables. Tried almost every setting on TV and DVD.
720 is the usual output from a DVD. Usually if you futz with the settings long enough, you'll find where most TVs can at least fill the screen by re-sampling, and SOME DVD players will have settings that will do the re-sampling for you and output 1080i, again just to fill your screen. But don't be fooled... only Blue Ray disks will give you true 1080i resolution. .
Oct 14, 2010 | KLH DVD8350 DVD Player
Component video signal between KLH DVD8350 & Vizio 32" PlasmaHDTV
If the Visio TV has more than one input, don't forget to use its remote to make sure the correct input is selected. It probably wouldn't hurt to put a DVD into the player, confirm its running from the front panel counters) and let it keep running as you troubleshoot. At least then you'll know there is an active video source once you find it. Another thing you can try is to put in a music CD, if the player accepts these too (most do). Then when you get the TV set to the right input, at least you'll hear music, and can then go back to trying a DVD.
I know you're using component video, so remember that unlike HDMI devices, the TV is unable to switch to the correct source automatically. So it may just be that you've never had to switch the TV's input source before. Good luck! :-)
Jun 02, 2017 | KLH DVD8350 DVD Player
Recording from VHS to DVD
Appreciate the direct "Ask Me".
To my knowledge, a KLH DVD8350 is only a player, it has no recording capabilities, sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | KLH DVD8350 DVD Player
KLH DVD 221
My sincerest apologies. I was not made aware that you posted a direct request for assistance. It was only by chance that I saw your post.
To your concern should you still require information; most units would have a yellow, red and white connectors commonly called RCA. What is required then is a triple RCA to RCA connector as shown below. The yellow is normally connected to the video, while the red & white are for the R & L of the audio. An identical set would be on the rear of the TV unit henceforth the connection would be OUT from the KLH DVD 221 to the IN of the TV.
In some instances, a single cable is used to connect some models to the TV. This is called an RF patch cord and would look sonething like below. This would come form the RF OUT of the player to the RF/CABLE/ANT IN of the TV. Pls make sure that the style/form fits your units.
Aug 20, 2008 | KLH DVD8350 DVD Player
KLH dvd
A quick reply would be YES. They are normally available in any electronics supply store. They are about the same size as the old Sony Walkmans rubber belt. It would be preferable that you bring along the old belt so as to match the new one (as per sample).
Feb 11, 2008 | KLH DVD8350 DVD Player
Klh dvd 8350
same problem with component video cables... fine with composite
Nov 18, 2007 | KLH DVD8350 DVD Player
Klh tv codes
Hi my name is Lawrence Harris and i need some codes
for klh universiral remote control.
Thank You....
Sep 21, 2007 | KLH 13" TV
KLH DVD8350 DVD Player Logo
Top KLH Televison & Video Experts
ray gallant
Tom Chichester
Are you a KLH Televison and Video Expert? Answer questions, earn points and help others
