How do I open PrintMaster Gold 16 in Windows 10?
PrintMaster Gold 16 worked great with Windows 8, but we upgraded to Windows 10 and it won't work at all.
Posted by Missy Williams on
5 Related Answers
ultimitloozr
  • 489 Answers
SOURCE: Can I upgrade the 8 GB SD card to a 16 GB SD card?
You should be able to use any size SD card you want to.
Posted on Apr 14, 2009
kirkx
Kirk Augustin
  • 2019 Answers
SOURCE: I have an old print
To run old DOS programs on Windows, you need an emulator program.
Try DosBox at the link.
Then just first run DosBox, and then run the Print Master program within DosBox.
http://dosbox.com/
Posted on Dec 21, 2010
maxcarson
max carson
  • 7627 Answers
SOURCE: missing webcam driver for windows 8
You stated " was working fine" , It was working fine in windows 7? windows 8? In Device Manager you can do a scan for hardware changes. Does the webcam show? if no, it might show unknown device if you will have to find the drivers for the webcam at the HP drivers and support. You can try a RE-Boot the software will try to locate a driver, if it cannot it wiil ID it as a unknown device, you will have to find the driver, this is common with a new OS or a upgrade on a machine.
Posted on Nov 09, 2012
maxcarson
max carson
  • 7627 Answers
SOURCE: How to get Drivers Updates after Windows 8 Upgrade for Toshiba C660D Laptop Please
This is a common problem with a new OS upgrade. Try to use Win 7 drivers. Modtify the drivers to be compatible with Win 8. Most times this will work, not always. Try here for Win 7 32 or 64 bit drivers: http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK&mode=allMachines&action=search&teddProduct=6017&selShortMod=1041
Posted on Dec 03, 2012
garytganu17172
Gary Tiedeman
  • 333 Answers
SOURCE: I am running windows 7 and I would like to know how to install an old version of printmaster silver 10 on windows 7
have you tried right click on cd exe propertys /compatability/windows xp sevice pack 2 . i'm using windows 10 and i use allot of older programs and this works for 99% of the time.
Posted on Dec 02, 2015
Will printmaster platinum 16 run on windows 8
It seems there is some problem, so listening to a friend's introduction to: https://www.facebook.com/Windows-81-Product-Key-389779677882215, to my surprise,I spent very little money and work together well.
Mar 07, 2013 | Broderbund PrintMaster Platinum 16
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
I cant get printmaster gold to work on my computer. i have windows vista
Broderbund PrintMaster Gold 16.0 is not compatible with Vista.
Platform: Windows 98 / 2000 / Me / XP
You can try to use Vista compatibility mode to run older programs in Vista. There is not guarantee that it will work!!! Please take note:- **The installation of an older program to run in a newer OS may also crash your PC too.
Link to How to "Use windows vista compatibility mode" - Use at your own risk!
Good luck.
Dec 07, 2010 | Broderbund PrintMaster Platinum 16
I tried to put print master 16 gold on windows vista and i got a message that i need a print driver where can i get it andwill it work then
Printmaster Platinum 16 is not compatible with Vista or Windows 7.
Presently there are not "patches" to make it works.
Your options is to use the newer version eg. version 18.1
Hope it helps.
Nov 14, 2010 | Broderbund PrintMaster Platinum 16
CAN'T INSTALL PRINTMASTER GOLD 10 ON VISTA COMPUTER
Maybe your edition of Vista is more bugged?
Try updating...
And take caps off. That's called flaming.
Jul 11, 2009 | Microsoft Windows? Vista Home Premium...
Problem loading Print Master gold 10 on windows vista
As I just posted on http://www.fixya.com/support/t2129564-printmaster_platinum_10_version_will_not I was able to get PrintMaster Platinum 10 to install on Windows Vista by right clicking on E:Setupis_Setup.Exe->Properties->Compatibility->Run this program in compatibility mode for Windows XP (Service Pack 2) and then running E:Setup>is_Setup.Exe FullSetup.ini from the command prompt.
Mar 24, 2009 | Broderbund PrintMaster Platinum 16
Computers & Internet Logo
382 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
