1997 Buick LeSabre Logo
Posted on Jul 15, 2009
Air does not flow from the vents on my 1997
Air does not flow from the AC Vents on my 1997 Buick LaSabre Limited auto system. Cold Air does flow from the floor and defrost ducks.
Charles Teich
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Jul 24, 2012
Charles Teich
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
7
Helped
3563
Points
7
Look for vacuum hoses by the throttle body that are either off or pitted
Anonymous
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Aug 26, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
Helped
7465
Points
29
Driver side blowing warm air with ac on , passenger side cold...2007 Impala
The 2 vents on the drivers side have warm air blowing out. ... But a system that is 1/2 pound low will cause the passenger side vents to blow cool or cold air, and the drivers side to be less cool or even warm on this car. There is simply not enough freon capacity in the system to cool the air to the drivers side.
https://www.justautorepair.com/buick/century/cool-passenger-warm-driver
Location of blend door actuator for a 2005 Buick LaSabre. I am having issues with hot air blowing out of drivers vents and cold air out of passenger vents with the AC on.
The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagram s and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
3helpful
2answers
I have a 98 Buick Lesabre Limited. It blows Cool air, but not Cold.And also, I can't seem to make it blow out of the Center Dash Vents.
Cornelius, vent problem could be a pinched or loose vacuum line on controller,faulty AC vacuum motor, faulty AC programmer,etc. needs to be checked out by a good Tech, diagnosed and estimate on repair.
As far as vehicle only blowing cool air, issue could be blend door issue, plugged AC condenser core dirt/debris, low AC refrigerant, plugged AC lines internal, failing compressor, etc., again should be checked out, diagnosed and estimate for repair by a good Tech.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
1998 Buick Lesabre No Air From Dash Vents
http://repairpal.com/ac-vent-problem-346
Car AC Not Blowing Cold Enough Car Repair Information From MasterTechMark
My Car Is Not Cold What Could be Wrong Elite Auto Repair
2004 Honda Pilot hot & cold
Sounds like a blend door problem under the dash.
Heat blows out of floor and defroster only not vents 93 buick lasabre
Under the dash you have the vacuum motors or servos or
electric door motors, for the hvac switching of air flow
So a vacuum leak or bad motor, whichever you have or binding
doors,also there may be linkage to some of them that gets into
trouble.
Hard to work or see things under the dash
If you have any electronics with an auto heat & a/c system then you
will need manuals to diagnose
2answers
1995 Buick Park Avenue - A/C air flows through windshield vents only and not midcar or floor vents.
You have a vacuum problem either to the AC control head or a problem with the ac control head.
14helpful
Heat wont blow through heater or defroster vents
common problem, check under dash by the gas pedal if control arms are muving went selecting from ac to heat cuz this it is the control for the vents to go from ac to heat and to defrost.
1helpful
2answers
Air conditioner blower
I found the vac lin broke under the battery
A/c vent issue
heater blowing cold when engine idleing,works good when rpm are up. what is problem? pete
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
