Question about Bionaire Heating & Cooling
Bionaire heater sometimes turns on at very low intensity and just kind of chugs along as the yellow button flashes. It works fine just wondering why it does that
Yellow light is still flashing after the chugging now, slightly concerned
Posted by Alex Ballagh on
Claude Kayser
    Top Expert:
  • 9,098 Answers
Amazon.com - Bionaire Heater with Rotating Grill ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Bionaire Heater with Rotating Grill, BFH2242M-SM - Space ... The ultraquiet Bionaire® Heat Circulator with Rotating Grill circulates warm air ... High-intensity, sun-like warmth, Gentle heat, Medium intensity, whole room .... When temperature reaches what you have set it to, the heater turns off and sometimes.
Bionaire Office Heater with Worry Free Motion Sensor
www.amazon.com > ... > Heaters & Accessories
Amazon.com, Inc.
Rating: 4.4 - ‎71 reviews
Amazon.com - Bionaire Office Heater with Worry Free Motion Sensor - Space Heaters. ... Heat turns off after 30 minutes of no motion detected. ... If you place it under the desk, your feet will be very warm, but not so much the rest ... CONS: The High setting gets too hot sometimes, while the Low setting doesn't get hot enough.
Bionaire® Electric Fireplace Heater BEF6500-UM - Bionaire
www.bionaire.com/bionaire-site.../bionaire...heater/BEF6500-UM.html
The Bionaire® Electric Fireplace Heater provides the ambiance and warmth of a ...Flame Intensity; 12 Hour OFF Timer; Free Standing or Wall Mountable; 2 Heat .
Posted on Jan 30, 2016
Bionaire BAP1300 -- Working fine for 2 Days then, Red Light
Try to do a hard reset by unplugging the device from the power outlet and wait for sometime to reconnect.
Jun 09, 2008 | Bionaire BAP1300 Air Purifier
Dodge durango chugging constantly, idle steady, lights dim with chug and engine light flashed 3 times when tried to accelerate at about 50 mph
A flashing check engine light means there is a serious problem (as opposed to a steady light which means there's a problem). You need to have the stored codes read before trying to figure out what's wrong. Most auto parts stores will read codes for free. Then simply Google your make and model and the code and you will probably get a few results that will point you in the right direction.
Oct 16, 2016 | Dodge Cars & Trucks
P0303 Flashing Service Engine Light when driving
P0303 ignition misfire on cylinder #3.
Possible Causes:
1.Fuel injectors, related wiring, sensors, computer issues
2. Running out of gas, or poor fuel quality
3. Evaporative emissions system (EVAP) concerns: fuel vapors leaking into engine
4. Incorrect Fuel Pressure
5. EGR system concerns: leaking EGR valve or restricted ports
6.Base engine concerns: low compression, valve train problems and timing issues
7. Ignition system concerns including, but not limited to:
Faulty spark plugs
Faulty coil or related wiring
Ignition module or related wiring issues
Ignition related sensor faults or wiring issues
You will have diagnose each element until you find root cause.
And it could be more than one element faulting out.
You
Jan 27, 2015 | 2002 Nissan Pathfinder
When accelerating car chugs
IS CHECK ENGINE LIGHT FLASHES WHEN THE CAR CHUGS????
Mar 25, 2014 | 2006 Volkswagen Jetta 2.0T
Chugging Expedition my 1999 for expedition is chugging non stop, the check engine light will flash going up hill but does stay on.
although the check engine light goes off, the code is most likely still locked in. stop by your local advanced auto parts, or mechanic to have them check it out.
Feb 02, 2013 | 1999 Ford Expedition
Chugging and running hot
If no yellow ck engine light is coming on to say that the car is missfiring Its possible you have a bad /plugged Catalytic Converter.
Aug 05, 2012 | 2003 Kia Rio
Steady yellow light
To reboot unplug the unit for 30 minutes. then plug back in. This may fix the problem, and try this link for troubleshooting PDF.http://homeappliance.manualsonline.com/manuals/mfg/bionaire/127176.html...
Apr 20, 2017 | Holmes Products BH3955-U Bionaire Utility...
Steady Yellow Light
Is it an old model? Should you try to have it replaced?
May 18, 2017 | Holmes Products BH3955-U Bionaire Utility...
The lights that are yellow in color are not coming on. the unit seems to work fine, but i was told it needs to be serviced.
http://media.onecall.com/Image_Products/Sunfire/ultareveiv2.pdf
Whoever told you that hasn't looked at the manual or the front panel.
Page 10 "PANEL DIM (button)
The front panel lights have four levels: bright, medium, low and
off (low intensity display with amber LEDs off)."
Aug 11, 2011 | Sunfire Ultimate Receiver
Heating & Cooling Logo
268 people viewed this question
Top Bionaire Heating & Cooling Experts
Dennis
Vernon Taylor
MODERATOR Canada
MODERATOR Canada
Are you a Bionaire Heating and Cooling Expert? Answer questions, earn points and help others
