Vacuums Logo
Pablo Abreu Posted on Jan 30, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Electrolux EL/8602a. How can I replace power cord?
L Pfaff
Level 3:
Top Expert:
  • Electrolux Master 11,573 Answers
  • Posted on Jan 30, 2016
L Pfaff
Electrolux Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3585183
Points
181713
Take lower body covers off to access end of power cord , un clip the 2 wires remembering the proper routing and colors, hook up your new cord and re assemble
below is a link to new power cord
Electrolux Nimble EL8602 OEM electric power cord replacement part cable...
5 Related Answers
Anonymous
  • 373 Answers
  • Posted on Feb 04, 2009
SOURCE: electrolux model 1401
try a local vacumn repair center or web site
Anonymous
  • 76 Answers
  • Posted on Apr 19, 2009
SOURCE: Need to replace power cord on Hoover vacuum.
remove the dirt container and look for screws.
Anonymous
  • 5 Answers
  • Posted on Nov 22, 2009
SOURCE: Electrolux model LX vacuum- Problem, ejects empty
The vacuum is doing exactly what it is suppossed to do, on this model, the bag will eject when the suction is reduced due to the pores in the bag becoming clogged by dirt, dust, or fine powder. Try a NEW bag, and **** up less superfine dust such as baby powder or plaster dust that immediately clog the bag. Next, on later model LX's on the bottom of the canister near the bag door is a dial, setting the dial to a higher number will reduce the sensitivity of this automatic bag ejection operation and will allow the vacuum to continue to run until the bag is even more clogged, however, running the vacuum with a fully clogged bag causes the motor to overheat and reduces suction and damages the vacuum. If you have an early model LX, there may have been a "basement and attic" key mounted to the bottom, but often are lost by now and it is used to make such an adjustment. The 1952 model LX was the first with the diaphram automatic bag ejection system and the problem of the bag ejecting too soon was common. An improvement on the model LXI added the control dial with numbers 1 to 6 on it to adjust the sensitivity. I am looking up more info on adjusting a model without the dial because I just picked one up at an estate sale a few days ago and I've heard (some time ago) that the early ones with no dial had a "basement and attic" key that snapped to the bottom of the cleaner to make this adjustment, not sure where it is though and the one I have does not seem to have the key. Will let you know more if I find it! Thanks, I am an Electrolux fan and will use nothing else because I have used so many vacuums but love the convenience of Electrolux design and durability. They have been in my family since my grandparents came to America and are simply the best in my opinion.
Anonymous
  • Posted on Dec 27, 2009
SOURCE: Electrolux EL 7001 Oxygen 3 power cord continually retracts
The button has two parts - the inner part (button) and the outer part (surrounds the button). The press the outer part to deactivate (pop out!) the inner part.
It took me a while to figure this thing out, but I was glad the vacuum wasn't broken.
Anonymous
  • 438 Answers
  • Posted on Apr 03, 2010
SOURCE: need to reclace power cord
Greetings,
I have gone ahead and taken pictures of how to change the cord on a Dyson DC07 upright. Here's what you'll need to have handy in order to complete this repair:
- T15 Torx Bit Screw Driver
- Dyson DC07 Power Cord For All DC07 Models, Part 905449.
- A 2mm or Smaller Flat Head Screwdriver (width of the tip)
- Needle Nose Plyers
- Patience (haha)
The cord above is actually a link back to our site if you have yet to purchase your cord. We carry most every Dyson part.
IMPORTANT: MAKE SURE YOUR VACUUM CLEANER IS UNPLUGGED BEFORE DOING ANYTHING ELSE!
Step 1. First thing you'll want to do is to unwrap the cord from the machine, and remove the handle from the upright part, then slide the hose all the way down the wand, and remove the hose from the handle assembly completely and set it aside. Also remove the dust bin assembly completely from the machine as well.
Step 2. Once you've remove the handle from the machine I find it easier to work on if you lay vacuum on it's back, with the switch button facing upwards. Now remove the T15 Torx bit screw that is directly below the switch actuator. I have circled the location of this screw in the picture below:
Step 3: After you have taken off the screw, you're doing to need to remove the switch box housing from the vacuum that the screw was securing. Simply use your flat head screw driver, and pry the two small arms upwards. Be careful when prying, the plastic components on Dyson vacuums are really cheap quality plastic, and I can't tell you how many times I have seen these plastic parts break. Here's a picture of the location of where you should pry the switching off:
Here's what the vacuum should look like after the switch housing has been removed:
Step 4. Use your needle nose plyers to remove the terminals from both of the switch poles. Also be careful when removing these terminals, don't force it or it will break the pole right off of the switch, and you'll then have to replace the switch along with the cord. Also you'll need to remove the two white wires that are connected together apart, also using your needle nose plyers.
Step 5. After you've removed the two terminals connected to the switch, as well as the two white wires that were connected, follow the electrical cord up until the point that it enters the vacuum cleaner to the rubber cord protector. Lift straight up on this cord protecter to remove it from the vacuum.
Step 6. You'll have to now slide the cord out through the cord protector so that you may install the protector on your new cord. Unfortunately as you'll see, your new cord does not come with the plastic terminal protectors that are on the end of the wires, so you'll need to take off these plastic ends on both the black, and the white wires that come from the cord. The other wire that you see in there that has a white wire with no plastic cover, and a black wire that does have the plastic terminal. There's no need to remove the plastic terminal from the wire that runs down into your motor, just leave these alone. If you look closely at these plastic terminal covers, you'll see that one side of them have two little ridges on the inside, also that the bottom is flat, and the top rises upwards on one end. To remove these plastic parts, use your 2mm flat head screwdriver and insert it through the top part that has the two ridges on the indside. While your screw driver is in as far as it will go, lift upwards away from the wire while pulling out the wire at the same time. Repeat this on the other wire as well.
This is how the wires look like without the terminals:
Step 7. After remove the plastic terminal covers from the wires, pull the cord through the rubber cord protector and remove your old cord. Open your new cord, and now you'll have to feed the two wires through the cord protector. Simply push the cord through the ribbed end of the cord protector. You normally can push the cord hard enough so that the ends of the wires will come out the other end fairly easy. If the wires don't come out, use your needle nose plyers to pull the metal ends of the wires through the rubber cord protector.
Step 8. Reconnect the wires to the switch, as well as connecting the two white wires together. Here's how the wiring should look like when done properly:
Step 9. After reconnecting the wires to the switch, and to the other white wire, you'll need to put the switch back in place, along with the cords, and the cord proector. You can see little channels that the cords actually sit in to keep them from pulling out. Place both the wire on the bottom that goes to the motor, as well as the electrical cord into these channels. The two white wires that are connected together go to the left of the switch. Here's how it should look like when you're finished:
Simply put the switch housing cover back over the switch and cords, and screw the Torx bit back in, and then test the vacuum to make sure that the cord works.
I hope that this repair was helpful to you with fixing the cord on your Dyson DC07. If you have any questions about this repair, or need further help on replacing the cord, please use the Clarification Request, or leave a comment on this repair and I'll be more then happy to help you further. If this was helpful to you, please be sure to rate the review helpful by clicking the thumbs up incon in the top right hand corner. Again, if you ever need any supplies for your Dyson, we do carry most parts and accessories on our site under our Dyson Parts Section .
Thank you,
Chris J.
GoVacuum
How to replace el8602a power cord
Electrolux Vacuum Cleaner EL 8602A How to replace the ...
www.manualsonline.com/.../vacuum.../how-to-replace-the-power-cord-o...
Question About Electrolux Vacuum Cleaner EL 8602A. How to replace the ... How toreplace the power cord on Electrolux EL8602A. Asked by gerry nickel on ...
Rewiring the Power Cord for the Electrolux Model G ...
? 4:27
https://www.youtube.com/watch?v=4uqNa7mVBO8
Jan 30, 2012 - Uploaded by Jayson1940D14
Rewiring the Power Cord for the Electrolux Model G ... How tochange the Electrolux 725 Suspension Plate - And Get Access To The Motor ... Brown Vintage ELectrolux Canister Vacuum Cleaner 1401-b - Duration: 0:17.
Electrolux Nimble Upright Vacuum, EL8602A - YouTube
? 3:49
https://www.youtube.com/watch?v=-anwdD4fK-o
Nov 11, 2014 - Uploaded by Michael Callender
Electrolux Nimble Upright Vacuum, EL8602A Best Price ... Dirt Devil UD70095 Power Reach Multi Cyclonic Pet Bagless Upright - Duration: ...
Jan 30, 2016 • Vacuums
Fix power cord on electrolux recessed female plugin cord
just bring it right on in and I'll fix it.
Not sure what the problem is other than fix power cord?
2answers
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
I have an Electrolux Guardian Canister vacuum. The power cord was damaged but the cord winder still works fine. I have ordered a replacement cord and need to know how to remove the old cord and install...
I strongly suggest allowing a qualified service tech at an authorized Aerus Electrolux store take care of this. The disassembly and reassembly of the tank and cordwinder are tricky and complicated and incorrect reassembly can cause serious problems. Even to the extent of permanently damaging your vacuum, or worse, result in a shock hazard or fire.
1helpful
Is it possible to replace the battery (loosing charge fast, weak power) for Electrolux stick vac EL 1000? Wher to buy the battery an dhow much cost? Thanks LJ
Let me say this; The battery replacement for the Electrolux is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work. These types of battery's will cost about $15.00 on the web.
Electrolux el6985 cord brake does not hold how do
you have to replace the cord winder. Since eureka bought out electrolux their product quality has really went down the drain.
Frayed power cord on electrolux canister vacuum
1 screw in the front, two in the blower port. take them out and the top bezel comes off. one screw in the bottom and two on the top. need a flat blade screw driver to pry out the cord reel. 4 screws holds the sheild of the reel. take them out and there is a snap ring that hold the reel on the shaft. the reel assembly and drum spring comes out at the same time. 3 screws on the bottom of the reel holding a metal plate and there is also snap ring hold the spring on the metal plate take that off and will expose the cord connection. unhook the the cord and untie the knot and replace the cord and reverse the process
1helpful
2answers
Electrolux 6500 SR
The cord light just indicates that the machine is plugged in and has power. In other words, you did great!
Power cord will not retract
Your cordwinder is broken take it to your local Aerus Electrolux dealer. If you have any additional problems call Liz at 570-326-1731
Top Electrolux Vacuums Experts
eVacuumStore.com
Mike Cairns
Mike Cairns
Kolbrun...
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
