Question about Shop Vac Vacuums
SOURCE: old red and black Genie Shop Vac
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=659916
Old red and black Genie Shop Vac
Posted by girl power on Jun 10, 2008
A Wheel or disk has come off of the motor. I would like to get a copy of the user manual to see if I can determine where it came off of. This Genie Shop Vac was given to us from my father-in-law.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can always check with the manufacturer Shop Vac to get an owner’s manual for the older Genie Shop Vac would be @ the Shop Vac Website and or Customer Service of which I will give you @ the bottom of the response. Other wise check with your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 10, 2008
SOURCE: filter sub. for Genie 1.1hp jet vac.
C.R.Laurence model GO118 filter is available through INTRO HOME IMPROVEMENTS and AMAZON.COM. This filter is made to fit the Genie 1.1hp Jetvac. Problem solved, thanks anyway.
Posted on Sep 08, 2009
SOURCE: old shop vac
Yes there should be a filter fitted onto the top section.
For suppliers, it would be cheapest to find your nearest stockist, or buy online and have it shipped. It's still current stock - so spares should be readily available.
Sears stock it -
CRAFTSMAN FILTER
Thank you for using Fixya,
Posted on Sep 22, 2009
SOURCE: jhe4576. I own a Genie SV125Q, 5 gallon wet/dry
Where did you buy this unit from? Go back there and ask if they have filters for yours. Otherwise look in the Yellow Pages for vacume cleaner repair shops. Sometimes they have all kinds of filters for all kinds of vacumes. You can try places like Wal Mart. What you want to look for are filters that will work with your unit. The foam filter you refer to is called a pre-filter. It traps the bigger particles so they won't damage your paper filter or clog it up especially if it's wet stuff you're picking up. You can remove that foam filter and gently wash it out in the sink with a mild dishwashing liquid and warm water. And even sometimes if you have time you can wash a paper filter out by hosing it out from the inside, with just a gently rinsing on the outside. Don't use any solvents on it just soap and water. And don't use high pressure either, as it will destroy the paper. I have cleaned my paper filters several times before I finally had to replace them. You can also look at places like Lowe's. They carry shop vacs and a whole assortment of attachments as well.
Posted on Mar 08, 2010
SOURCE: genie 400PC 16 gal shop vac but can't find filters
If you need paper filters, you can easily use a bag filter cut in half, and have less dust clouds than the original filter. Remember to use the lock ring. Generic ShopVac mini's have the same filter in foam.
Posted on Mar 11, 2010
Testimonial: "I have a lot of upright vac bags from long gone vacs & I hadn't thought about cutting one down! Good idea, now I've just got to go get a foam filter."
Jun 02, 2018 | Vacuums
Sep 08, 2014 | Vacuums
May 28, 2014 | Genie Company GV150 Wet/Dry Vacuum
Aug 21, 2011 | Genie Company Vacuums
Sep 26, 2010 | Genie Company GV150 Wet/Dry Vacuum
Mar 11, 2010 | Genie Company GV150 Wet/Dry Vacuum
Mar 07, 2010 | Vacuums
Sep 08, 2009 | Genie Company Vacuums
Jun 10, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Feb 17, 2008 | Genie Company GV150 Wet/Dry Vacuum
Jul 26, 2019 | Shop Vac Vacuums
Dec 15, 2018 | Shop Vac Vacuums
130 people viewed this question
