Cars & Trucks Logo
Steevi Diamond Posted on Jan 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have purchased a PT Cruiser 2001 (UK) and the previous owner has lost the alarm fob. I have purchased a replacement. Is there any way to reprogram this myself?
Jay Hafner
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Apr 04, 2016
 Jay Hafner
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
1509
Points
14
If the new fob is the only one you have, you will have to have a locksmith program it for you. If you have one working fob, then your manual gives you programming instructions, But you MUST have one working fob to program a new fob.
Malissa Dickerson
Level 2:
Sergeant:
  • Expert 257 Answers
  • Posted on Jan 29, 2016
Malissa Dickerson
Expert
Level 2:
Sergeant:
Answers
257
Questions
61
Helped
61099
Points
709
No, call a mobile locks smith. some have equipment to reprogram
How do I reprogram fobs that lost programming? 2005 Pt Cruiser
I think you have reprogrammed, with a different code, one fob and not the others.
Take it to a Crysler Dealership for advice.
2helpful
2answers
How to bypass 2007 PT cruiser lost key to reprogram system to start car?
you can't bypass computer set software. You can however reprogram the key transponder and receiver. If you have NO working key, you need the dealership.
2007 Chrysler PT Cruiser
  1. Insert First Programmed Key. INSERT a working remote head key into the Ignition and TURN it to the ON/RUN position.
  2. Remove First Programmed Key. ...
  3. Insert Second Programmed Key. ...
  4. Remove Second Programmed Key. ...
  5. Program Remote. ...
  6. Program Additional Remote. ...
  7. Exit Programming Mode. ...
  8. Test Remotes.
More items...
2007 Chrysler PT Cruiser Keyless Entry Remote Fob ...
How do I disarm the anti--theft alarm in my 2006 pt cruiser
DisARM, or DisBLE?
Disarm
Press the "Unlock" key on your key fob to deactivate the alarm and unlock the car doors. If you've lost your key fob, unlocking the driver's side door with the key automatically deactivates the PT Cruiser's alarm.
How to Disable PT Cruiser Factory Antitheft System ' It Still Runs
Disable anti-theft
Short answer, you can't!
Want to bypass your vehicle security system?
The short answer is you can't!
All modern cars have alarms and immobilizers. There is a chip in the key and a chip in the ignition lock. If both are present, the ECM (engine control module) releases power to the ignition circuit. When you turn the key, the starter spins the engine and you get a spark. If any one of those three items are not in the chain, you get the engine to turn, but no spark. There is no way to beat the system. You have to fix what is wrong, not find a way around it.
The immobilizer is in place to stop exactly what you are trying to do.
https://www.fixya.com/cars/r26142776-want_bypass_vehicle_security_system
My 2004 pt cruiser shut off and will not even try to start. Shut the car up and came back next day and the alarm will not stop sounding. What can be the cause and how can i fix these problems?
2001 PT Cruiser Cuts Out, Engine dies for no reason ...
? 2:04
www.youtube.com/watch?v=cG9qCHfBhGw
Jan 10, 2014 - Uploaded by michelle salazar
2001 PT Cruiser Cuts Out, Engine dies for no reason ... picked it up on October 18, 2013 only to have it die on me while on the interstate. After it ...
Turn off alarm on 2009 PT Cruiser - PT Cruiser Forum - PT Cruiser ...
www.ptcruiserlinks.com > ... > Sound and Security Forum
Aug 18, 2013 - 10 posts - ‎8 authors It's not an add-on alarm, it's just the factory alarm. ... then I go in to panic mode (because it's horribly embarrassing when it goes off and won't shut off) and try everything else - like pressing the lock button, ... 2004 Pt Cruiser GT Car alarm installation, operation, problems and solutions ...
May 17, 2013
KEYLESS ENTRY stop working
Nov 1, 2009
How to reset Security.....
Apr 26, 2009
Programming the keyless Remote
Mar 13, 2005
More results from www.ptcruiserlinks.com
How can i turn my security light off so i can start my car?
Jeremy: According to eHow.com: "
  • 1 Press the "Unlock" key on your key fob to deactivate the alarm and unlock the car doors. If you've lost your key fob, unlocking the driver's side door with the key automatically deactivates the PT Cruiser's alarm.
  • 2 Look for the black alarm box underneath the dashboard, on the driver's side of the car. Locate the override button on the box -- either a black or red button, depending on the year of the PT Cruiser -- but don't press it yet.
  • 3 Put the key in the ignition and turn the key so that the battery is on, but the engine doesn't start. Quickly push and hold in the override button until you hear the alarm sound once, indicating the alarm is disabled.
  • Read more : http://www.ehow.com/how_7739471_disable-cruiser-factory-antitheft-system.html"
    1helpful
    3answers
    MY PT Cruiser Functional transmitter and the one to be programmed both have no "PANIC" Button . How I programme the spare Fob
    If you don't have the Panic button then sorry, you can't program yourself, the dealer will have to program it to the RKE (Remote Keyless Entry) module in the vehicle, using their DRB scan tool.
    8helpful
    2answers
    My 2001 pt cruiser auto door locks no longer work nor does the key fob. The door locks were acting like sssharp's - doing their own thing and locking or unlocking on their own and rattling in the back door...
    As stated above, it is most likely your RKE (remote keyless entry module). It is easy to find and relatively easy to replace yourself. I just recently did so on my 2002 PT Cruiser. Got a used module from a 2005 at a salvage yard. Put in the module myself. However, you do have to take it to the dealer to reprogram so your remotes work with the module replacement. That cost me $50. If you are interested in doing the labor yourself, email me. [email protected]
    1helpful
    2answers
    Pt cruiser disable alarm
    battery of car is zapped of energy...not sure if alarm system to blame, after driving it for a few minutes..clock and radio display lights turn off, horn can barely be heard...sometimes, motor shuts down completely. have had to put in 2 new batteries in just a matter of 2 months?...any idea what this may be?
    The battery on my 2003 Chrysler PT Cruiser died and now I need a radio code to reprogram the radio.
    if the code was not put in the owners manual when origionally purchased, you can pull the radio and retrieve info from the back. provided to the dealer they can get you the code
    Pt cruiser alarm fault
    Try unhooking the battery for about 10 mins. That should clear any problems and give the alarm time to reset.
    Top Chrysler Experts
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Thomas Perkins
    Thomas Perkins
    Are you a Chrysler Expert? Answer questions, earn points and help others
