Question about NEC Office Equipment & Supplies
How do I reset my nec projector model vt700 lamp time without remote
Claude Kayser
    Top Expert:
  • 9,098 Answers
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Posted on Jan 29, 2016
5 Related Answers
Anonymous
SOURCE: Preylahong NEC MT830+need help to reset new lamp
After replacing lamp in MT-830(NEC) press and hold "on" button for 10 seconds to reset lamp hours. If projector has beyond 2100 hours press the "off" button for 10 second.
Posted on May 18, 2008
Anonymous
SOURCE: How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Posted on Apr 12, 2009
Anonymous
  • 691 Answers
SOURCE: I do not have remote. Church inherited projector.
Hello
Thank you for using
FixYa for your problem
  1. you need to enter factory Menu.
    You do so by doing the following:
    1).Start the projector.
    2).Press keypad <Source> and <Auto> keys simultaneously, enter " Lamp Hour info" layer
    3). Press <Source> and <Auto> keys simultaneously again, then enter factor menu.
    Do not change anything till you reach Lamp Layer where lamp hour and usage hour is given. If you reset, then all data revert to default - factory reset. you may chage here or under (2).
    Let me know if this solves your problem.
  2. - Press exit for 3 seconds
    - The Menu to reset the Hours rises up
    - Folow the manual on your screen
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 19, 2009
projdoc
jasbo
  • 2239 Answers
SOURCE: Reset Sony VPL-CX6 WITHOUT REMOTE ?
if you can't through the menu, you do need the remote.
Posted on Dec 23, 2009
rommelalilin
Rommel Alilin
  • 2178 Answers
SOURCE: I need to replace a
http://www.necdisplay.com/LocateDealer/
Posted on Jan 26, 2011
I have a nec vt570 projector and it has gone into bypass mode because I let the lamp go to long. I've replaced the lamp but can't reset the hour meter.Is there any way to reset without the remote
Switch on the projector in standby mode.
press the HOLD button on the remote for 10 secs.
the projector will come out of protection and you are good to go!
ensure that u replace a new lamp!
This can be done only with the NEC remote!
Jun 04, 2015 | NEC Office Equipment & Supplies
Need to reset lamp usage time without the remote on NEC VT490
Hello
Press the MENU button on the projector's control panel to display menu options.Press UP/DOWN button to reach the RESET option window. There you can see Clear Lamp Hours and Clear Filter Hours option. Select the Clear Lamp Hour option and press enter. That is all. OK.
Oct 22, 2011 | NEC VT490 LCD Projector
Status light is blinking red, power button orange nec vt700
Hello
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
Sep 10, 2011 | NEC VT700 Projector
I have a NEC VT700 projector. I replaced the bulb and housing because it would no longer turn on and the status light would blink every 2.5 seconds indicating the housing on the lamp had an issue. I...
I have solved that problems by replacing the plastic Lamp Cover. NEC says they wear out over the years due to the heat. If you have a spare VT700 about, swap covers and see if that works. or order one from NEC, thay cost 5 dollars.
Jan 12, 2011 | NEC VT700 Projector
My Nec VT700 is projecting a pink image. How do I fix this?
Well first check the colour scheme of your monitor and of the projector.
If this doesn't work check the working hours of the lamp. Try cleaning the filters and if this doesn't solve your problem the best thing to do is to change the lamp of the device.
If you need further assistance please leave a comment. Cheers
Aug 25, 2010 | NEC VT700 Projector
Just replaced vt700 lamp. projector still indicating faulty lamp. i also reset the lamp hrs by pressing help on remote. can any one help thanks
Try the old lamp again and reset again and see if that works. When you originally replaced the lamp did it give you a warning that replacement was required or did it just stop? I haven't worked on that model before but you may require a new Ballast (power supply ) that runs the lamp (technician job usually)
Dec 26, 2009 | NEC REPLACEMENT LAMP FOR VT700
I replaced the bulb in my projector and now it
You need to hold the help button on the remote control for ten seconds, that should reset the lamp hour. NEC decided to make it inoperable after 2100 hours on the bulb.
Nov 13, 2009 | NEC VT700 Projector
Clean Filter - NEC VT700 projector
Need to go into the menu and find the option to reset. Choose the "reset filter hours" option.---Rick
Sep 04, 2009 | NEC VT700 Projector
seconds
Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
1,554 people viewed this question
Top NEC Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
Joe Goldman
Joe Goldman
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
