Heating & Cooling Logo
Diane Williams Posted on Jan 28, 2016
ELITE. Why doesn't timer turn off?
BEEPS CONSTANTLY AND DRIVES ME CRAZY
2 Related Answers
Anonymous
  • 291 Answers
  • Posted on Nov 25, 2008
SOURCE: Kenmore elite oasis hp washer
bad control board
John Morganti
  • 864 Answers
  • Posted on Sep 15, 2009
SOURCE: kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Oven turns it self on and off
you need to put it back on manaul setting it sounds like you have the timer on auto
My HP pavilion constantly beeps all the time. At least ten beeps per minute. It's a pavilion V6 2015. It runs fine, but the beeps are driving me crazy. I sent it back to HP, and it came back worse. Now at...
Maibe you have a bad keyboard and the keyboard buffer gets full (if a broken letter gets stuck and makes permanent contact). If i dont have more details i dont really be sure.
I have a Kenmore Elite Coffee Maker, I press brew, the light flashes and then it beeps but does not brew.
gotta have the correct time set, also check auto brew timer. Coffee pots usually beep when they are done brewing and then when it's turning off, usually after a hour. Play around with timer (hrs. and min.)
My wd passport has just stopped registering but lights on and beeps 3 times when turned on.
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure
hope this helps
1helpful
Freezer beeps constantly turned up the temp to the highest still beeping and not freezing its best.
its frozen up or low on gas....the defrost timer has failed or the defrost element has packed it in.the beeping is warning you of a temp failure.
Kenmore dryer beeps constantly
End of Cycle Signal
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
the signal.
Sep 15, 2009 • Dryers
1helpful
CYCLE SIGNAL CONSTANTLY BEEPS
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
