Question about Philips Coffee Makers & Espresso Machines
I used milk instead of water, when making coffee using Philips senseo twist HD 7870 coffee machine. Now it has a very bad smell,how can I get rid of this problem? How to clean the water reservoir??
Posted by Rashedul Shourov on
5 Related Answers
Anonymous
SOURCE: Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Posted on Jan 08, 2009
Anonymous
SOURCE: GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Posted on Apr 03, 2009
Anonymous
  • 6 Answers
SOURCE: The indicator light continues to blink rapidly
you are correct in thinking the problem is caused by the valve. Use a magnet to connect to the valve from the outside of the machine, slide the magnet very slowly upwards along the water level, the rapid flashing should stop and the water should begin to heat, if not try again as you have not connected the valve to the magnet
Posted on Oct 16, 2009
bansheracer
  • 1089 Answers
SOURCE: Our Saeco Magix Deluxe (old
Hi
When the machine is done brewing some water is relieved into the drip tray. This is the pressure relief. Some coffee residue is also taken into the drip tray. This is normal. As long as nothing is under the machine your OK.
Posted on Oct 23, 2010
biotin80
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
Posted on Feb 28, 2011
Machine not in use for a long period of time. Concerned with remaining water inside machine
Water stays in it, true, putting the senseo upside-down for a longer period of time, might drain the boiler. Let's hope it did not freeze up.
try following: switch on Senseo, and push both One + Two cups buttons, this will drain the boiler.
Jan 26, 2014 | Philips Senseo HD-7810 Coffee Maker
Accidently left coffee pod in coffee pot while went on vacation now the machine smells really bad . tryed vinegar but nothing seems to help
Try the rinsing procedure that's in the manual, and use citric acid. The parts that usually come into contact with hot water or coffe can also be cleaned in a dish washer.
Sep 01, 2010 | Philips Senseo HD-7810 Coffee Maker
How do I prime an old machine that's been sitting in my cupboard for awhile??
De-mothballing a Senseo check-list:
  • Get some citric acid & prepare it as prescribed,
  • Fill the Senseo's reservoir with the citric acid suspension,
  • Place a large bowl underneath the coffee outlet,
  • Press and hold both small buttons, and
  • Press the Power button.
The citric acid suspension will now be pumped through the machine, into the bowl. To stop the rinsing, press the Power button again. I suggest you repeat this a few times, don't forget to swap the pad holders somewhere in between so they both get some suspension as well.
After that, repeat the procedure a few times with fresh water only to get rid of any citric acid in the machine - it will make a poor cup of coffee if you forget that step!
Jun 19, 2010 | Philips Senseo HD-7810 Coffee Maker
HOW DO I DESCALE MY SENSEO?
run vinegar thru it... go buy a gallon of it... and run a couple cups thru it...
then use filtered water or distilled water to flush that vinegar out...
then go buy yourself a Brita Pitcher... and use that... cheaper then using distilled water...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 06, 2010 | Philips Senseo HD-7810 Coffee Maker
Senseo coffee maker
http://www.eserviceinfo.com/downloadsm/19109/Philips_Senseo%20HD7810/10.html
OK above is a service manual, this is what the techs use to fix, it. Use the exploded diagram,and troubleshooting guide, and you will no doubt sort it very quickly.
http://www.devicemanuals.com/guide/Home%20Appliance/Philips/Philips-SENSEO-Coffee-Maker-HD7810-75-54-User's-TXpBNE1qTT.html
Download the user manual above.
Apr 03, 2010 | Philips Senseo HD-7810 Coffee Maker
Coffee comes out as weak as coloured water! far too weak.
you probably are not putting enough coffee in to strengthen the coffee
Apr 25, 2009 | Philips Senseo HD-7810 Coffee Maker
Senseo stuck after using coffee pods that have "milk" built in....5 days later
I had the same problem. I waited for a while as the instruction says but didn't open. But, I got it open!!! by turning and slightly pulling a small plug behind the water tank on the backside. (remove the water tank then you'll see the little plug. see attached photos) I think it will let air in and vacuum seal get released. After it opened, I gently turned the plug back and push it in as it was. Now, it is running perfectly again. I just had a great coffee. :-)
58c3f6de-9c9e-437e-b419-0533bdf0a452.jpg562b78da-5cdf-43fe-afb9-546e2ba78530.jpgb5d600f7-721a-4b74-a954-ef849424bf28.jpg
May 14, 2008 | Philips Senseo HD-7810 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Philips Coffee Makers & Espresso Machines Experts
Ross Keen
Piers Carter
Piers Carter
Harrie
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
