Question about Haier Refrigerators
Model 18.2. Where is fuse located? - Haier Refrigerators
Posted by Anthony Matranga on
aaahandy
    Habit-Forming:
    New Friend:
  • 186 Answers
I'm not sure it has one, why what is the problem?
Posted on Mar 08, 2016
How to locate fuse for comfort zone fan?
Probably doesn't have one, usually the motor has thermal protection so no fuse required.
Apr 23, 2014 | Comfort Zone CZHV18B 18 Inch High Velocity...
I need the location of the power lock fuse for my 2000 Ford Explorer AWD V8
The power lock fuse on your explorer is fuse #18 25 amp located in the central junction box. The central junction box is located on the driver's side end of the instrument panel. Open the driver side door and there should be a access panel. Fuse # 18 is in the second row from the left and the fifth one down. Hope this helps.
Sep 04, 2011 | Ford Explorer Cars & Trucks
I have a kenmore model 665.13592k600 dishwasher and it won't turn on. Nothing at all works. Any suggestions?
Assuming you have tried to check the mains power circuit breaker/ fuse is still in tact, the most likely cause is the heat fuse tripping. This is located inside the control panel.
See item 18 on this diagram.
Hope this helps.
Jul 07, 2011 | Kenmore Dishwashers
My cigeratte lighter and car charger port dont work just need to know which fuse it is so i can see if it is blown
The fuse for the power outlets/cigarette lighter is located in the rear power distribution box located in the trunk (pictures of location below). Chrysler does not give pictures of the layout but they are numbered. The fuse you are looking for is in the number 18 position and should be a yellow 20 amp fuse. This should be in your owners manual if you have one. If you don't and would like a copy, you can email me at [email protected] with your make, model and year and I will be happy to email you a copy. I hope this helps and good luck.
May 01, 2011 | 2006 Dodge Charger
Fuse blown for interior dome light. which fuse and location?
The manual states the fuse location # for interior lighting is 18 and the amp is15a. I am showing 18 is from far left bottom corner it is the second fuse going up.
Dec 12, 2010 | 2007 Ford Crown Victoria LX Sedan
1999 porsche carrera horn doesnt work
Check the 25 A Fuse in location B3 of the fuse box in footwell (cheap part).
If the fuse is ok, check the relay in relay location 10 (should be located in fuse box area also) The relay should be labeled as part# 141951253B (may be other relays with same part# (you can swap with) in relay locations 9 and 18-22).
Jul 17, 2010 | 2000 Porsche 911 Carrera
Where is the fuse located for Main beam, both headlights have went out.
Fuses are located end of drivers dash,open door,unclip plastic panel
Diagram should be inside
If not fuse 18 10amp is rh main beam,fuse 19 is lh main beam
Jul 12, 2010 | 2004 Volkswagen Passat
Don't have a diagram, where is fuse 18 and 9?
if you look in your owners manual it will show all fuse locations and what each fuse feeds
Jan 09, 2010 | 2005 Dodge Magnum
I need to know where the horn fuse is on a 1998 lincoln town car. No manual
Hi, the horn fuse is located under the hood, number 18 and is a 15amp rated mini-fuse. To find the location look at the bottom of the plastic fuse lid for number 18.
Jul 14, 2009 | 1998 Lincoln Town Car
Headlights
The fuse panel is located below and to the left of the steering wheel by
the brake pedal. Remove the panel cover to access the fuses.
fuse #11 is right head lamps
fuse #12 is high beams
fuse #18 is parking lights
good luck
paul
Oct 02, 2008 | 2005 Ford Taurus
Refrigerators Logo
71 people viewed this question
Top Haier Refrigerators Experts
Marvin
Marvin
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
