Question about Generac Guardian 20kW Model : 5875
It will turn over once or twice and stops it has a red light on where the braker panel is
Posted by john miknaitis on
L Pfaff
    Top Expert:
  • 11,573 Answers
Press the helpful button and follow me on Fixya for more helpful tips
The current models of automatic standby generators will have LED indicator lights on the side compartment of the generator. A green LED light will indicate that the unit is in AUTO mode and is ready to run, or is running properly during a utility outage. The yellow LED light will indicate that maintenance is needed. The red LED will indicate either that the unit is switched to OFF or that there is an alarm detected. If a yellow or red LED are present, you will need to check the generator's control panel, as it will describe the type of maintenance needed or the alarm present. This information can be found in the owner's manual as well. You can find a copy of the owner's manual online by searching the model or serial number of the unit here
http://www.generac.com/service-support/product-support-lookup
Posted on Jan 27, 2016
What does the #25, 10 amp fuse represent in our motor home. I think these fuses refer to our lighting system but am not sure as their is no info sheet there or in manual to explain.
hi that may have a short thats why the braker tripping so get an electrician to check that out but you dont have to change the braker just switch it off and on but please have someone check it for you you can have a fire ok
Nov 07, 2015 | Cars & Trucks
Need upstar TV Codes
I found that common LG codes (056) mostly work with UpStar (that uses LG panels, and generic electronics modules).
Watch out for stripped or missing hardware, including on table stand pod and VESA brackets, with UpStar's sloppy quality control. Also, they've reversed AC line Hot and Neutral and caused other problems in their California service facility, shipping fire and electrocution hazard TV's.
Aug 28, 2012 | Acer Televison & Video
I have a philips remote control and I need the code to control a pioneer DVD player
Though all remotes are differnet just try this it can be kind of standard. But not all remotes are always compatible
1. On the remote control, press DVD once and Turn DVD player off
2. Press and hold SET until the red light blinks twice, then release SET.
3. Aim the remote control at the TV and press SCAN. The red light will blink twice.
4. Continue aiming the remote control and click on and off at the DVD Player (which may take up to 5 minutes) until it turns off. Immediately press any key except VOL-, SCAN, or SET. If SCAN is pressed again after any key stops Auto Scan, the remote will continue Auto Scan of the next ID from where it stopped. If you have passed by the code that turns off the TV, press VOL- one or more times until the TV turns on again.
5. To lock in the code and exit Auto Scan, press and release SET the red light will blink twice.
1. Or if you have a code. Press Set
2. Wait for blinks
3. Put in code.
4. Test it and if it works click set if not try next one.
Jul 17, 2011 | Philips Televison & Video
Hi i have lost instruction manual for my total remote urc 11-4110 b02 Universal Remote could you tell me how to code it to tv manually please
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 10pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; } SET UP
TV
The Search Method
If your device does not respond to the TOTAL CONTROL after you have tried all the codes listed for your brand, try searching for your code. The Search Method allows you to find the code for your device by scanning through all the codes contained in the memory of the TOTAL CONTROL.
To search for your TV code:
1 Switch your television on (not on standby) and aim your TOTAL CONTROL at your TV.
2 Press the TV key on your TOTAL CONTROL.
3 Press and hold down SET UP until the red light blinks twice. (The red light will blink once and then twice)
4 Press 9 9 1. The red light will blink twice .
5 Now slowly, alternate between POWER and TV, over and over, until your television turns off. You may have to press these keys many times (up to 150!), so please be patient.Remember to keep pointing the TOTAL CONTROL at your television when you press these keys.
6 As soon as your television turns off, press SET UP.
The TOTAL CONTROL remote should now be ready to operate your device. Turn your device back on and try all the remote’s functions to ensure they are working
properly. If some of the TOTAL CONTROL’s commands are not operating correctly, try the search method again. You may be using the wrong code.
Once you have Set-Up your TOTAL CONTROL, you can blink back your SET-UP CODE for future reference.
Example: To blink out your Television code:
1 Press TV once.
2 Press and hold SET UP until the red light blinks twice (The red light will blink once and then twice).
3 Press 9 9 0. The red light will blink twice.
4 For the first digit of your four-digit code, press 1 and count all the red blinks. If there are no blinks, the digit is "0".
5 For the second digit, press 2 and count all the red blinks. If there are no blinks, the digit is "0".
6 For the third digit, press 3 and count all the red blinks.
7 For the fourth digit, press 4 and count all the red blinks. If there are no blinks, the digit is "0". Now you have your four-digit code.Make sure you write your Television code for easy future reference.
Aug 12, 2010 | Televison & Video
I need to program my one for all remote to my zenith tv
Try the following steps: 1. Turn on the tv. 2. On the remote, press the "tv" button once. 3. Press and hold "set" button until the red light blinks twice. Release "set" 4. Using the remote's keypad, type in the digits 9-9-1. The red light should blink twice. 5. Point the remote at the tv and slowly alternate between pressing the "power" button and the "tv" button. Stop when the tv shuts off. 6. To save this code, press and release the "set" key. The light should blink twice. Your remote should be programed to your tv.
These steps came from the following link. If you have any problems, I suggest consulting the manual on the link:
http://www.hifi-remote.com/manuals/manual.shtml?URC-3021
I hope this helps! Sincerely, Der Strom
Apr 13, 2010 | One For All URC-3021 Remote Control
Th-50pz80u turns off for no reason
you can shove your premium assistance program , i spent 2000.00 already
tv shuts off for no reason...red light blinks 4 times ...stops...blinks 4 times....stops....etc....what can i do before taking it back??
this is a brand new unit....fantastic picture....fix my problem
Dec 13, 2008 | Panasonic TH-50PX50U/P 50 in. HDTV Plasma...
Flashing lights on philips flat panel tv
This can be the main power supply has failed, and or there is a short on one of the processor boards.
The set will have to be brought in for service.
Jerry G.
Jun 08, 2008 | Philips Televison & Video
Generac Guardian 20kW Model : 5875 Logo
209 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
JOHN LAPIER
Bill Johnson
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
