The television turns on by itself and changes channels by itself. What part do I need to replace?
Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
SOURCE: LG tv turns on by itself
this problem is with the inner small micro-swtches ,the side buttons inside are getting intermittantely short...changing of those switches will solve the prob. tc--
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
SOURCE: 52LG70 sometimes turns off and on periodically
I had the same problem. I changed the 4-3 setting on the motorola cable box. Turn off your cable box and press menu. My 4-3 setting was set to auto. If you turn it off, you lose the 4-3 aspect on most channels. I changed mine to 480p and so far it seems to be working. Worth a shot.
SOURCE: tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
SOURCE: My LED LG TV 42" turns on/off by itself. Channels do not change.
Sorry to tell ya but your power supply panel or chip is going out! Mine done the same stuff! Freakin flat screens dont last as long as the older t.v's
