Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Posted by Monica gentry on
Claude Kayser
    Top Expert:
  • Washing Mach... Master
  • 9,098 Answers
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Posted on Jan 27, 2016
My Kenmore Elite Quiet pak 2 # 11045872402 HE3 washer doesn't go through the complete Cycle it stops when drain and spin,or doesn't Tumble through the cycle? could I have confused it by trying to keep
Spinning is prevented when the cover is open. Possibly a broken "door closed" switch is or its wires are broken. Lift the lid platform and check the switch. May be just debris preventing it from engaging. Remember, the lid and the close switch must be engaged before the control circuit will allow the high speed spin from happening. This is an essential safety feature and should never be circumvented. A high speed drum can literally pull an arm from its socket if caught so make sure it's working properly
Feb 16, 2017 | Kenmore Washing Machines
After rinse cycle won't washer won't spin
Sound like it could be a lid safety switch.
May 24, 2014 | Kenmore 22422 Top Load Washer
Roper rab4132hq0 washer does not spin consistently. Most of the time, the spin will not engage, this isn't just for the spin cycle, but for the spinning during the wash and rinse cycles as well....
Sounds like a bad gearcase.You have a machine that is direct drive. The motor is hooked directly to the gearcase by a little coupler. Look under and make sure the coupler is in place if it is then you need gearcase.Again the coupler is located between the motor and gearcase. Hope this helped.
Jun 04, 2011 | Roper Washing Machines
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Kenmore washer mdl#110.23832100 spin cycle motor
Hello, looks like your lid switch is on it's way out, replace it...you will find it normally about half way down under the lid. If not there you will find it in the control panel on the right side next to the water level control. The reason it works some times and not others is because some times it fails to push the lid switch down far enough to engage. the lid switch is a safety divice inteneded to stop you opening the lid while in a high speed spin. If you have any other questions please feel free to comment again. Mike
Oct 01, 2009 | Washing Machines
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washer does not spin. What's wrong with the machine??
Sounds like a bad lid switch. If it works intermittently, could be loose. When you close the lid, the two parts of the lid switch line up which allows continuation of operation. You can bypass the lid switch by removing power to machine; locate the switch FOR THE LID ON THE MACHINE SIDE, remove the two wires and wire nut them together. MACHINE WILL RUN NORMALLY EVEN WITH THE LID OPEN.
Jul 02, 2009 | Washing Machines
Kenmore washer will not spin
KENMORE 80 SERIES 110.92582110 - NOT SPINNING. I REPLACED THE TRANI, CLUTCH, COUPLER BUT I FORGOT TO PUT BACK IN THE AGITATOR WASHER. IT STILL WON'T SPIN SO WHAT NEXT
Jun 12, 2008 | Kenmore 23822 Top Load Washer
Maytag Atlantis washer will not drain and spin unless you lift the lid
The cheaper thing to check first is is your lid bent? The lid switch is in the center of the lid. If it "droops" or has been bent, it shaft on the back of the lid cant hit the switch. Open the lid and apply pressure in the bottom, center of the lid. This usually corrects the problem without replacing the switch.
May 31, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Oct 19, 2006 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
172 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
