Question about Jabra BT500 Wireless Headset
Is the rechargeable battery in the Jabra BT500 replaceable?
Is the battery in this device user serviceable?
Posted by Leonard Chandler on
Andrew Taylor
    Top Expert:
  • Jabra Master
  • 32,361 Answers
  • jabra headset battery swap - YouTube www.youtube.com/watch?v=MMLocSWjq8Q
    • BY THEDIECLAN2004
    • 3 MIN
    • 24K VIEWS
    • ADDED 2011-12-10
    Video embedded · jabra headset battery swap theDIEclan2004. Subscribe Subscribed Unsubscribe 15 15. Loading ... Plantronics Pro battery replacement - Duration: 9:15.
  • Jabra BT500 Bluetooth Headset - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16826552001
    • 4/5
    • 69 REVIEWS
    Buy Jabra BT500 Bluetooth Headset with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Jabra SPORT Bluetooth Battery Replacement - YouTube www.youtube.com/watch?v=Sm8cSkyTmfA
    • BY GREG PAJAK
    • 2 MIN
    • 27K VIEWS
    • ADDED 2013-09-23
    Video embedded · A quick video showing the ease of replacing the battery in the Jabra Sport bluetooth headphones. Jabra says when it it out of warranty they cannot be ...
  • Jabra BT-350 Disassembly and Repair - Instructables www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair Intro: Jabra BT-350 Disassembly and Repair. I wooted a few of these dandy devices a while back and they work great but the volume buttons are weak and the solder ...
  • Posted on Jan 26, 2016
    Testimonial: "Glad someone got back to me. But the information (Video) for changing the battery was for a completely different model (DIEclan2004). There is also information on battery change-out for the BT350 and the Sport but not the BT500."
    • Andrew Taylor
      Andrew Taylor Jan 27, 2016
      Mmm, I see the BT500 is very different to all the rest! Look at this video and do a search for the Fixya Expert mentioned.
      https://www.youtube.com/watch?v=EnO_77yN...
    How do you open the device to replace the battery?
    the 2 halves are like a clam shell . thin knife blade and try several places around it , gentle twisting of the blade sometimes it is easy and others not so much
    Sep 10, 2015 | Cell Phones
    How can I remove the battery from my Samsung u600 phone please ?
    hi just checking on my phone then ill talk you through it as i never needed to get the battery of before but will have a go now ok
    Feb 28, 2008 | Lands Phones
    Why does my RCA 7tablet have a exclamation mark on the battery when I plug it in to charge? It will not charge or turn on, what can I do.
    That exclamation mark means the battery is bad or has a bad connection inside the device. If your battery is user-serviceable you could try removing the back of the device and checking the connection for corrosion or looseness. Depending on how old your device is, it just might be time for a new battery.
    May 26, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
    How can I replace battery?
    Hi, if the device is under warranty you should send it in for service. The battery is not user accessible on this device unless you open the device up which would void the warranty. As far as I know the battery is not even orderable from Motorola.
    Apr 30, 2014 | Zebra CS3070 Handheld Bar Code Reader -...
    Change battery
    You'll have to contact apple support, their notorious for making it impossible for users to make their own repairs. Discussion threads on Apple iPhone Bluetooth Headset Battery Change Charge indicate that other users have the same issue on the only real recourse is to take it to an Apple authorized repair center or Apple Store for service. It's very likely that it will cost more to repair than it would to buy a newer BT device.
    Jun 11, 2013 | Apple MA817LL/A Bluetooth Headset
    Changed battery in remote for prestige aps620 not it doesn't work
    Hello
    BATTERY REPLACEMENT
    The transmitter incorporates a small LED visible through the case which is used to indicate battery
    condition. You will notice a decrease in transmitter range as the battery condition deteriorates.
    Transmitter battery replacement is recommended at least every 10 to 12 months, depending upon how
    frequently the transmitter is used.
    To replace the battery in the APS620TX:
    1) Remove the small # 0 Phillips head screw from the rear of the case.
    2) Remove the rear cover to access the discharged battery paying attention to the proper polarity
    orientation.
    3) Carefully remove and properly dispose of the discharged battery.
    4) Insert the new battery, close the case, then reinstall the small case screw removed in step 1.
    5) If you accidently dislodge the circuit board from the transmitter housing, be certain that the rubber
    membrane is seated properly, and the buttons are properly exposed from the front view of the case,
    then insert the circuit board, and return to step #4.
    APS620TX Uses GP23 Battery
    CAUTION: CARBON MONOXIDE GAS CAN CAUSE SERIOUS INJURY AND EVEN DEATH
    It is the sole responsibility of the user to operate the vehicle this system is installed in a safe manner.
    This device must not be used in an enclosed space like a garage, attached or detached, car port, or any
    partially enclosed areas. Also this device must be placed in the service mode when dropping the vehicle
    off for service to prevent injury to the service technician
    These are the information about the battery replacement to your device. There is no other details given. Check the battery contacts inside the remote for any dirt or rust, which prevents the good contact for batter y terminals. If there is, clean it . OK.
    Aug 11, 2011 | Prestige Remote Start
    Changing batterry in nuvi 200
    The Nuvi series does not have a User replaceable battery with a few exceptions and your device is shipped with a User non-replaceable battery.
    The exceptions include the nuvi 5xx, 8xx and the nuvi 900T. These devices have a replaceable lithium-ion battery.
    http://www.garmin.com/garmin/cms/site/us/support/searchsupport?search_key=nuvi%20200
    Contact a Service Center to replace the battery.
    Good Luck!!!!!!!!!!!!!!
    Sep 28, 2009 | Garmin nuvi 200W GPS Receiver
    C330 indicates low battery although plugged into charger
    The internal lithium ion battery is not user replaceable. You will need to have the unit serviced by Garmin.
    Apr 02, 2009 | Garmin StreetPilot C330 GPS Receiver
    My Garmin 760 can no longer be used on battery power alone. It only works with the power cord.
    Hi IlliniGuy,
    It sounds like the battery in your Garmin 760 has failed.
    Rechargeable batteries have a limited lifespan. The amount of time you can expect between charges will decrease until the battery eventually does not hold a charge. It sounds like you have reached that point.
    Although the battery pack in most MP3 players is not generally considered to be end-user serviceable you should be able to get service on the battery by contacting Garmin. If the unit is out of warranty there would normally be a fee for that service. Or, if you have experience repairing electronic devices you may be able to purchase a new battery and replace it yourself.
    Hope this helps,
    Ken
    "Go Ahead. Use Us."
    Jul 01, 2008 | GPS
    Jabra BT500 Wireless Headset Logo
    683 people viewed this question
    Top Jabra Radio Communications Experts
    Anthony Ward
    Anthony Ward
    Robek Thirtysix
    Robek Thirtysix
    Level 1 Expert
    Mosaub Al Masri
    Mosaub Al Masri
    Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
