Question about HP LASERJET P1006 Printer
In mailmerge, why does it keep indicating it is out of paper but there really is paper?
It prints OK otherwise
Posted by Bill Tyberg on
Brandan Heasley
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
Are you printing Labels or Envelopes?
Posted on May 31, 2019
My epson xp-312 will not print on photo paper.it keeps saying paper jam.how can i load when the back tray only allows one sheet of normal paper?
When a printer indicated paper jam, it means one of its sensors does not indicate a movement of paper, where it expects it. In only rare occasions the sensor is defect, but most of the time here is really a jam. This must not be a complete sheet of paper. Can be a little scrap left somewhere in the printer. Sometimes a paperclip fell in or just a paper tray was not put in place. Please open the printer and look careful using a flash light, to see if you can find anything that does not belong in the printer. Then switch it off and really unplug it for a few seconds. Reinsert the plug and switch on. If the error keeps coming back you should call a service centre, although ig you have to send it in for repairs, a new printer is probably cheaper, unless it is still under warranty.
Jan 13, 2015 | Epson Office Equipment & Supplies
LABEL PRINTING
you might try downloading a template from avery.com that is what I use.
Mar 12, 2013 | Office Equipment & Supplies
Paper block button keeps on but there is no jam
Title: Paper Block on Printer
Ok one icon will be shown on your Start Bar Right corner as printer Icon.
Right Click on it and page will be shown which are given by you for print.
Clear it. And give newly for printing.
Otherwise you uninstall your driver and install it.
May 07, 2011 | Epson Printer
Load and print envelopes
Generally NO. The reason is they have a manual slot and rear exit that keeps the path nearly straight for things like envelopes, labels, cardstock etc so they dont have to make the turn from the tray and from the fuser to the fact down exit tray. If you need to do a mailmerge with numerous envelopes you could 1) print a sheet of labels and stick those to blank envelopes or 2) go to a more advanced machine that has envelope feeder capability. Even a used machine such as a Laserjet 4000 - you can find envelope feeders that just attach on easily for almost nothing on ebay.
Jun 21, 2010 | Brother HL-2070N Laser Printer
Paper jam canon mx850. I cant find the paper.
The error indicates a black ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
If you ever buy any Xerox ink and you get a cracked ink stick call Xerox cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif800-835-6100cb_transparent_r.gif and they will replace it free of charge. Otherwise you risk this problem.
Hope this helps.
May 30, 2009 | Canon PIXMA MX850 Multifunction Printer
My computer says that my printer is offline.
Please follow the steps given below to perform a self test on the printer:
1. Switch off the printer.
2. Press and hold down the paper feed button.
3. While keeping the paper feed button depressed, turn the power back on.
4. When the printer starts to print, release the paper feed button.
5. When the first page is printed, switch off the power (otherwise the printer will keep on printing).
Apr 04, 2009 | Lexmark X73 All-In-One InkJet Printer
Konica minolta 600 has problem printing duplex mailmerge and tir
CAUSE: The tri-fold printed on side is set incorrectly on the machine.
SOLUTION: To change the tri-fold from printing inside fold to printing outside fold, perform the following:
1. Press the Utility key.
2. Select Admin mode and enter the password.
3. Press Copier Setting.
4. Press the down arrow.
5. Press Tri-Fold Printed on Side Selection.
6. Press either INSIDE or OUTSIDE.
good lock
Feb 28, 2009 | Panasonic DP-C264 Copier
HL-2030 printer won`t print labels with Word 2007
If it's the same as my Hl-5250DN, you have to use MP Tray mode. The MP (multi-purpose) tray is cleverly hidden on the front of my printer.
Feb 01, 2009 | Brother HL-2040 Laser Printer
MAILMERGE USING "WORD" & AVERY LABELS
If you have Microsoft Word, you can open a template of the label you're using (which is free from Avery if it isn't already in Word) and make that document into a mail merge document.
Dec 11, 2007 | Avery DesignPro Deluxe CD-ROM...
HP LASERJET P1006 Printer Logo
69 people viewed this question
Ekse
efs_perpends
efs_perpends
