Toshiba REGZA 47HL167 TV Logo
I
Ian Tibbetts Posted on Jan 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Which part do i replace on my Toshiba 47hl167 TV to repair my faulty HDMI ports?
After moving my television, all HDMI inputs stopped working. I tried multiple components and doing factory reset many times. Devices are not being detected.
Level 3:
Top Expert:
  • Toshiba Master 76,851 Answers
  • Posted on Jan 26, 2016
Toshiba Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15003895
Points
237762
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
1helpful
I have sound but no picture the menu still displays just nothing from any video inputs its a toshiba 47hl167
I am assuming you have already tried leaving it unplugged for 15 minutes and then trying to restart it. Does it work in the TV mode? I.m not sure if there is a rest button on that model. If you go to Toshiba Support there might be more info.
Fine red lines on screen
Redlines usually mark for a failing part.
You don't mention if this lcd is used from external source or just as a plain tv. I would suggest trying different input port if hdmi is used.
Possibilities: faulty external cable, faulty input port, faulty internal cable, faulty internal board or connection, faulty screen
HDMI Ports on Toshiba Flat Screen TV stopped working
That's highly unlikely!!! More likely is that the cable is having problems or that someone mistakenly changed the picture i the TV from HDMI to regular reception. If the HDMI ports are changed to regular TV reception they don't see the HDMI ports only the regular video ports!
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
Dear Sir, We have Toshiba REGZA 24PB1E LCD TV. I want to test our Gigabyte PC GA-G41M-Combo MB with VGA port (15 Pin Connector) Pls let us know how to connect & get the solution ASAP. For...
Hello
With either the PC IN or HDMI connection, you can watch
your computer's display on the TV and hear the sound from the
TV's speakers.
When connecting a PC to the PC IN terminal on the TV, use an
analog RGB (15-pin) computer cable and a PC audio cable.
To use a PC, set the monitor output resolution on the PC
before connecting it to the TV. The following signals can be
displayed:
Format Resolution V. Frequency
VGA 640 × 480 60Hz
SVGA 800 × 600 60Hz
XGA 1024 × 768 60Hz
Other formats or non-standard signals will not be displayed
correctly.
Note:
The PC audio input terminals on the TV are shared with the
HDMI-1 analog audio input terminals
Some PC models cannot be connected to this TV.
OK.
Is my regza tv model 32rv635d hd ready or full hd.
Hello The Toshiba Regza 32RV635D is a Fully HD TV. with four HDMI connections.
Connections
The location of the connection ports is in keeping with today's standards. They are easily accessible and well constructed.
Port Listing: 4 HDMI, 2 SCARTs, Headphone Jack (with Independent Volume Control), S-Video, Composite Video, Common Interface, Component Video, Digital Audio Out (Optical/Toslink), RF In and D-Sub.
You can read the reviews here:-
http://reviews.cnet.co.uk/tvs/toshiba-regza-32rv635db-review-49302355/
and
http://www.techradar.com/reviews/audio-visual/televisions/plasma-and-lcd-tvs/toshiba-regza-32rv635db-679432/review
Hope this helps, if so do rate the solution.
Have a Toshiba 42hm66 tv. The HDMI port has quit
The best thing to do is to call Toshiba at 1800-631-3811 and see if they could refer a Service Facility to you to check it out. I would guess that that Board that has the HDMI Port on it needs to be replaced but it is not a easy or simple job.
I hope this helps,
Skyassoc
1helpful
Conecting to pc
there are 3 ways you can hook up your pc to this tv. VGA, 15 pin D-Sub PC Input and DVI convert to HDMI. when using the DVI convert to HDMI, you will also need to hook up an analog audio to get sound since DVI only put out video output.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
